SeM
Hi, I am wondering if there exists some general initial conditions for solving the Schödinger eqn. for 1D free electrons ?
Thanks!
Thanks!
Hi, I am doing a time-independent analysis, and thought of using the zero-point energy for E, in the Schrödinger eqn, and then solve it with the two initial conditions:stevendaryl said:Typically, in solving Schrödinger's equation, you are either doing a time-dependent analysis, in which case the initial conditions are part of the problem statement, or you are doing a time-independent analysis, in which case, people are usually looking for energy eigenstates.
SeM said:Hi, I am doing a time-independent analysis, and thought of using the zero-point energy for E, in the Schrödinger eqn, and then solve it with the two initial conditions:
1) assume that the wavefunction is 1 at position zero (x=0), as it would be normalized to.
2) its slope, Psi', is zero at the same point, x=0. Does this sound reasonable?
Thanks
I know, there is another procedure to find the eigenstates. This is just to find the analytical solution to the ground state.stevendaryl said:If you already know a complete set of energy eigenstates then you can find a solution having those properties. Those properties don't help you find the eigenstates, though.
