What causes latency from audio signal in to out in computers
The discussion revolves around the causes of latency in audio signals as they travel into and out of computers. Participants explore various factors contributing to this delay, including the role of buffering, digital signal processing, and the differences between digital and analog systems.
  • One participant suggests that electromagnetic waves carry audio signals and that the speed of these signals varies based on the conductor type, proposing that this could contribute to latency.
  • Another participant identifies buffering as the primary cause of delay, explaining that input samples are accumulated in a buffer before processing, and the size of the buffer affects latency.
  • A later reply emphasizes that the actual travel time of signals in wires is negligible compared to the buffering delays in audio processing.
  • One participant questions the electrical components in digital systems that introduce delays compared to analog systems, seeking to understand why digital systems require buffering.
  • Another participant references a source discussing the fundamental latency introduced by digital filters and the role of delay elements in the digital signal path.
  • It is noted that digital signal processing operates on blocks of samples, which inherently introduces sampling time delays and contributes to overall latency.
Participants express multiple competing views regarding the causes of latency, particularly between the roles of buffering and the inherent properties of digital signal processing. The discussion remains unresolved as participants explore different aspects of the issue without reaching consensus.
Some participants acknowledge limitations in their understanding of electrical engineering concepts, which may affect the depth of the discussion. Additionally, the complexity of digital versus analog systems introduces various assumptions that are not fully explored.
mooseboi
I am just a beginner so if I am asking in the wrong forum please move it to the more relevant one.
From my understanding, electromagnetic waves are what carry audio signals and dependent on the conductor, this speed varies. I have read coxial will carry at about 2/3 speed of light, and fibreoptic at about 96% speed of light.
So my question is, what are the main causes of the delay of an audio signal going into the computer and coming out?
My hypotheses, which i am hoping will be proven to be wrong:
components that cause the most delay
-the actual time it takes electromagnetic waves to travel along the physical distance of the wiring from audio input to output
-the limitation of a computer processor only being about to process, in my case, 2.5GHZ x 64 bit blocks per second
I feel I'm asking a much bigger question that what I know about the science behind it, but I thought there's no harm asking.
Cheers
Buffering is the main cause of delay. A number of input samples are accumulated in a buffer before the software is notified about the buffer being ready for processing. It then does whatever processing you want it to do and sends another buffer to the audio interface which will output it 1 sample at a time.
So basically the minimum latency is the size of (input buffer + size of output buffer) * period of sampling rate
On a typical computer rather large buffers are needed since the computer will take time to transition from whatever it's doing to processing a new audio buffer. On PC, sound cards for use in music production typically come with an ASIO driver that let's the user choose the size of the buffers. The lower the size of the buffer the lower the latency, but that comes at a price. The computer must process those buffers more frequently and if it fails to do so in time, you will hear some really bad audio artifacts.
On specialized hardware you can get away with much lower latency by using chips designed for signal processing
(DSP) and not having to worry about all the other things a general purpose computer must do.
Actual travel time of the signal in the wires is negligible for audio processing.
hi codexus, thanks for the reply.
Yes, i understand the buffering which affects and causes the delay of audio processing. I suppose I'm asking the question on a lower level.That is, what electrical components in digital systems which use buffering are not present in an analogue system like a all valve guitar amp which doesn't need to buffer the signal, and why is it that these components introduce delay while analogue circuits don't?
Again, i have to reiterate that I might be asking a question that is beyond what I can comprehend as someone who doesn't have electrical engineering knowledge.
Cheers
here is an excerpt from http://en.wikipedia.org/wiki/Digital_filter#Comparison_of_analog_and_digital_filters.
"However, digital filters do introduce a higher fundamental latency to the system. In an analog filter, latency is often negligible; strictly speaking it is the time for an electrical signal to propagate through the filter circuit. In digital systems, latency is introduced by delay elements in the digital signal path, and by analog-to-digital and digital-to-analog converters that enable the system to process analog signals."
This is relevant to what I am trying to find out. But I am finding it very hard to find anything on the internet relating to 'delay elements in the digital signal path'
Digital signal processing operates on blocks or samples of the analog signal inputs for a period of time so there is always some sampling time delay. It then executes DSP 'math' on the digital blocks that must be completed in time for the next sample or buffered in memory for later processing. The 'latency' is from a number of factors in that sampling/processing chain.
The Linux audio latency is an example of mainly OS software/hardware portion of those delays.
https://www.osadl.org/fileadmin/dam/rtlws/12/Rodriguez.pdf
thanks for the response nsaspook,
that is an interesting paper you've linked, very relevant breakdown of the various parts, thankyou!
  • · Replies 30 ·
