What Causes the Change in Direction of Induced Current in Magnetic Fields?
The discussion revolves around the change in direction of induced current in magnetic fields, particularly focusing on the forces involved when a current-carrying wire interacts with a magnetic field. Participants explore concepts related to electromagnetic induction, including Fleming's Left Hand Rule and Lenz's Law, while examining different scenarios of wire movement and induced current direction.
  • One participant notes that a current-carrying wire experiences a force in a magnetic field according to Fleming's Left Hand Rule and questions why the induced current direction changes when the wire moves in the same direction as the force.
  • Another participant prompts a reflection on whether the induced current would flow in the same direction as the original current or opposite when the wire moves in the direction of the force.
  • A different participant expresses confusion over the use of the left-hand rule, stating that they are more familiar with right-handed orientations and emphasizing the importance of vector products in electromagnetism.
  • Some participants mention various mnemonic rules for determining current direction, indicating a lack of consensus on which rule is most applicable or clear.
  • A later reply suggests that an emf would be induced in the opposite direction to the original current in the first situation, raising the question of whether this would result in a drop in current if an ammeter were connected.
Participants express differing views on the use of hand rules for determining current direction, with some favoring the right-hand rule and others discussing the left-hand rule. The discussion remains unresolved regarding the implications of induced current direction and the effects on current measurement.
Participants reference various rules and principles without fully resolving the assumptions or definitions involved in their applications. The discussion includes unresolved questions about the relationship between induced emf and current direction.
jkena04
Hello everyone
Ive got myself into a muddle over the forces involved in magnetic fields.
I understand that if a current carrying wire is perpendicular to a magnetic field then it will experience a force according to Flemings Left Hand Rule.
Now if a wire is to move in the same direction as the motion 'induced' above. at right angles to the same magnetic field (this time with no current flowing in it) the emf induced is in the opposite direction to the current in the top example. (If you try to use flemings left hand rule here the current goes in the complete opposite (wrong) direction.
What causes this change in direction? Surely both situations are identical, since the direction of motion and the direction of the magnetic field are the same in both, yet the current in one is in the opposite direction to the induced current in the other situation? Is it a product of Lenz Law?
Hopefully you can understand what I've said!
Look forward to your responses!
OK. Now ask yourself: If the wire were to move in the direction of the force, what direction would the induced current flow? Would it be in the same direction as the original current or opposite?
I've never heard of a left-hand rule. That's very confusing. Usually everything is right-handedly oriented. In the context of electromagnetism the most important rules are those for the vector product (in the magnetic part of the Lorentz force) and the relative orientation of area and its boundary in the integral form of Faraday's Law, which reads in the most general case of moving wires
[tex]\mathcal{E}=\int_{\partial F} \mathrm{d} \vec{x} \cdot (\vec{E}+\vec{v} \times \vec{B}) = -\frac{\mathrm{d}}{\mathrm{d} t} \int_{F} \mathrm{d}^2 \vec{F} \cdot \vec{B}=-\frac{\mathrm{d}}{\mathrm{d} t} \Phi_{\vec{B}}.[/tex]
There are many mnemonic rules (unfortunately) for various situations. (See: "[URL Left Hand Rule[/URL])
I agree. The only rule I ever use is the right hand rule for computing cross products.
(But I don't think confusion over the hand rule is the issue here.)
Ok so in fact in the first situation an emf would be induced too in the opposite direction to the original current. So does this mean if you were to connect an ammeter to the wire in the first situation you would notice a drop in current?
