What Causes Time Dilation in the Twin Paradox?
250 replies · 38K views
neopolitan said:
Ok.
Given that all measurements are made in the stayathome twin's frame, where is the pedagogical advantage in ignoring that, under the circumstances, Sh = Tt = Th and so then substituting we can arrive at:
St2 = Sh2 - Xt2
and so
Sh2 = St2 + Xt2
Well, if you do that then the first equation reduces to the trivial 0=0. But in general I don't think there is a pedagogical advantage. I would just stick with the standard expression for the spacetime interval.
Which first equation? Do you mean ... Sh² = Th² - Xh²
In this situation, what advantage is there in discussing Th and Tt at all? You have from experimentation (in the mind experiment at least) the values of Sh, St and Xh.
Additionally, you have the concept that Th, Tt and Sh are all equal from the perspective of the person doing the maths. Why go through the process of discussing Th and Tt, when you don't need to?
The only advantage that I can possibly come up with is forcing the use of a pseudo-Riemannian manifold and dissuading the student from using a more intuitive, bog standard vector concept.
The more intuitive, bog standard vector concept bring with it something that most people here will not be happy with, namely a geometry which requires hyperspherical curvature. The use of the pseudo-Reimannian manifold effectively flattens the hypersphere. And I know, not using the pseudo-Reimannian manifold could equally be said to create the hypersphere. The thing is that both methods work, so I am not sure that we can dismiss either.
(Think about the equations for working out the figures on a surface which is a plane that advances through spacetime with t, then think about doing the equations for working out the figures on the surface of a sphere which expands with t. Alternatively, work out what a vector joining two events will look like in both geometries and compare that to a pair of non-parallel vectors which together join those two events.)
I am sure there are arguments for why the standard equation is used, but I would prefer more proof than 1. it works, if applied correctly (since the other method works too, if applied correctly) and 2. it is what we use (tradition does not always give us the best way to do things).
Of course to use another method, one would have to present a good reason to do so. I have a reason, it was presented at the end of a very long thread on simultaneity and I reproduce it here:
neopolitan said:
While we have covered a lot of ground in this thread, and brought in a lot of different issues, some of which I have possibly not been as careful with as I could have been, I have tried to be very consistent about how I talk about dimensions. I didn't talk about going from 2 dimensions to 3 dimensions, or from 3 to four. I have tried to always talk about it in terms of 2 dimensions to 2+1 dimensions, or 3 to 3+1.
I have done this on purpose. The reason for it is that while we can nominate an x, y and z axis at random, or select axes which are most convenient for us, we can't do that with time.
You have done the same, at least effectively. You remove a dimension to make it easier to grasp what is being modeled, but you only ever take away a spacelike dimension, never the timelike dimension.
You can't take an inertial perspective (an inertial frame) and choose your four axes at random. There are three dimensions in which you can select axes however you like and one which is inviolate. Say you and I are at rest relative to each other. There is also a television in our frame, at rest relative to both of us and not lying on the line defined by our two positions. I could choose me-TV as my x axis, with myself as the origin. You could chose you-TV as your x-axis with the television as the origin. We could then assign internally consistent orthogonal y and z axes that are not common to each other. Your x, y and z axes would be a blend of my x, y and z axes. What we would be extremely unlikely to do is chose axes such that your x, y and z axes correspond to a blend of my x, y, x and t axes. If we did, then everything would have to be moving in order to stay still in this strange coordinate system. Can you see that is a problem?
So, what I am saying is that time is special, you have to treat it specially.
Now if time could be represented by just another othogonal plane, you could look at it from another perspective and end up with the problem of having blended spacelike and timelike axes.
If the timelike dimension has more of a circular (really hyperspherical) nature then, no matter what perspective you took, the timelike dimension would be unaffected. Yes, your altered perspective would affect the spacelike dimensions, making my x-axis a blend of your x,y and z axes. But our timelike dimension would be unaffected.
Now this might be something completely new, but I sincerely doubt it. I am probably just using clumsy almost physics-like terminology to express something that is already accepted. In any event, this is the physical aspect of what I am discussing. It leads to "an interesting coordinate system" but I think that coordinate system does make sense, even if it may be difficult to grasp.
For the context, see https://www.physicsforums.com/showpost.php?p=1681656&postcount=279" post in the original thread.
cheers,
neopolitan
This whole economic model is your idea and I have already told you that I don't think there is any advantage to it. I was just trying to help you out by showing you how to derive it.
Ok, ignore the economic model.
Even so, why go through this process:
Student says "I see three quantities, time elapsed for A, time elapsed for B and distance traveled by B according to A. Or that could be four, if I say distance traveled by A according to A, but that is zero. Using the three non-zero values I can make an equation which makes sense to me. Can you tell me what it means?"
Teacher says "Ah yes. Here is another way you can make that equation. First you make two other equations, but you have to add two more variables, both of which the same value as one of the variables which you have already used. Then you can subtract one of these equations from the other, to eliminate those two variables I just added, and then you end up with the same equation as the one you just came up with. Now do you understand?"
Student looks at the teacher in a new light. Emboldened by the teacher's masterful complication of what seemed quite straightforward, could the student then ask:
"Can you please explain something else? I am aware that B's journey consists of two inertial journeys, not one single one. Even so, I was interested to see what happens if I run the same sort of equation as we have been discussing, using B's perspective. When I do that, I get an odd figure, 25.6 years (assuming that B travels for 24 shipboard years, at 0.8c, 12 years in each direction - according to B though, this means that A has a speed of 0.8c for 24 years). This is odd because this is precisely the difference between the proper time experienced by A (40 years) and the dilated time that B would calculate that A experiences in 24 years of traveling at 0.8c (14.4 years). What does it mean?"
Will the teacher give the same response as I got to my earlier post when I posed that very same question?
(It may be difficult to answer and take some time to formulate a response, I am happy with that. I am sure the teacher is allowed to say "I don't know, but it is important to me that people understand SR properly, so I will get back to you when I have figured it out myself." Science is strengthened, not weakened, by its proponents admitting when they are not certain about their subject material. :smile: )
cheers,
neopolitan
I'm sorry but I don't know how I can be more clear about this. It is your equation developed by you. It is a product of your mind written and invented by you. As you say, it "makes sense" to you. So it is up to you to explain the meaning of your "straightforward" equation.
A derivation doesn't explain or give meaning (nor does it complicate anything), it only establishes an equation's validity and any underlying assumptions. You are acting as though you have never seen a derivation before, and I know that is not the case.
This site is screwing with me again. It logs me out while I am posting a reply and deletes the content. Very annoying.
Dale,
I am clearly not making myself clear. It is the equation that needs some interpreting, not the derivation. The difference between a physics equation and a mathematics equation is that the physics one has a real application. The numbers mean something.
Let's continue to use the scenario Fredrik gave right at the beginning, twins A and B, B travels off at (relative) 0.8c for 12 years shipboard time then turns around and travels back at 0.8c, A stays at home. We can use subscript h for values pertaining to A, and subscript t for values pertaining to B.
The equation I had the student wanting to understand was, in my words:
(total time elapsed for stayathome)2 = (total time elapsed for traveller)2 plus (total distance traveled by traveller, according to stayathome)2
You presented an equation, in your words:
Sh² = Th² - Xh²
and stated that Th = Tt and, effectively, that Th = Tt = St
so that, with a rearrangement
St² = Sh² + Xh²
where St is B's proper time (time elapsed on B's clock), Sh is A's proper time (time elapsed on A's clock) and Xh is the coordinate distance (distance traveled by B, according to A).
Now, for the purposes of explaining to the student, I would have thought we could say that we know that the square of the proper time in a single inertial frame which is taken to be at rest is equal to the sum of the squares of the proper time and coordinate distance in another inertial frame (or set of inertial frames) - between any two simultaneous events (simultaneous as defined by Einstein).
Is that true (even if clumsily worded)?
I would think it would be useful to explain to the student why you can do this from A's perspective, and it works, but you can't from B's perspective, because it doesn't quite work out the same way.
If you try to do the same thing from B's perspective you end up with this equation (using time elapsed on clocks - proper time; coordinate time and the names A and B):
(total time elapsed on B's clock)2 minus (total distance traveled by A, according to B)2= (coordinate time for A, according to B)2
which I think is:
St2 - Xh2 = Th2
or in figures
242 - 19.22 = 14.42
I imagine that this results from Th = Tt = Sh, from B's perspective. (It certainly works at first glance, following the pretty much the same logic as the earlier derivation. The problem I come up with though is that Th does not equal Sh if Sh is time elapsed on A's clock, since in the scenario that is 40, not 14.4. My understanding would be that this is a result of treating a non-inertial frame as an inertial frame.)
Interestingly enough I made a huge blunder in an earlier post and no one challenged me on it, so I get the pleasure of admitting I was wrong.
in https://www.physicsforums.com/showpost.php?p=1901524&postcount=202" I was fiddling with figures and came up with something which I both misrepresented and also typed incorrectly.
minus (total time elapsed for traveller)2 plus (total distance traveled by stayathome, according to traveller)2
= - (242) + (0.8 x 24)2 = -655.63 = - (25.62)
Add the 14.4 years, then you have 40 years.
I can only say in my defense that it was typed at about 2am.
I have since worked out where the figures come from, they are:
minus (coordinate distance, according to A)2 plus (coordinate distance, according to B)2 = minus (missing years)2
Now that I have the right label on the figures, it makes a lot more sense. If there is spatial disagreement (about distances travelled), this can be balanced by an equal magnitude temporal disagreement.
cheers,
neopolitan
I understand all that. Perhaps I am too used to dealing with my 2-year-old where the concept of ownership is clear and has preeminence in all interactions. This is your equation so it is your job to do the explaining and interpreting.
Please, repeat after my 2-year-old, "mine, mine, mine"
B's frame is non-inertial. I wouldn't expect it to work out the same. You should worry about if it works in other inertial frames, not non-inertial frames.
I did, at least in my last post. Then I asked for opinion with "Is that true?". It's not your job, but many like to critique here, so I thought I might get some response.
I didn't specifically ask for comment on the idea of two equal magnitude disagreements cancelling out, but I thought I might get some there anyway.
I guess it is possible that no-one feels qualified to comment if it is not part of the standard curriculum. (Note that "not being part of the standard curriculum" does not necessarily mean "wrong". It may imply that, but there are plenty of right things, and valid perspectives, which are not taught because lecturers don't have the luxury of determing the best way to teach the subject for each student, or even the best way for students in general, or the time to cover all the myriad ways that equations can be derived and interpreted. I suspect that much is taught in the way that is most convenient to the lecturer and the teaching environment. It's the poor tutors who usually have to put up with awkward questions like mine :smile: ).
cheers,
neopolitan
Wouldn't it greatly simplify things to just calculate a one-way trip, ship leaves Earth and comes to rest with Earth a specified distance away, then multiply the results by 2? Not only simpler, but some aspects of the problem would then have to be explained instead of avoided.
Al
Al
I have tried that elsewhere and was a rigorous as I could be, trying to eliminate the acceleration entirely and only consider the two one-way trips there and back again. I was able to show that if B travels from a spot which is at rest in A's frame (where A is) to another spot which is at rest in A's frame, then back to A, then both will agree with the timings on the clocks.
What they won't agree about is distances traveled and when events occurred.
Naturally, people didn't like that.
cheers,
neopolitan
cheers,
neopolitan
Everyone would agree on the distance traveled in each frame, and when the events occur. For example, if the ship travels 10 ly at 0.8c, everyone will agree that the distance is 10 ly in Earth's frame, 6 ly in the ship's (inertial) frame, 12.5 yrs on Earth's clock, 7.5 yrs on ship's clock. The ship and Earth end up in the same frame with the ship's twin younger. Of course people don't like it because the standard resolution doesn't fit.
And with any realistic acceleration, the ship's clock reading 7.5 yrs is simultaneous with Earth's clock reading 12.5 yrs. This is exactly what you have pointed out before, neopolitan, in other posts, referring to the midpoint of the turnaround. If we just cut the trip in half, we could avoid obfuscating the issue with simultaneity issues associated with the turnaround.
I don't know why anyone would object to analyzing the problem as a one way trip. Then to get results for a 2 way trip, just double the results.
It really could be that simple, if done correctly.
Al
sorry I missed that. I will go back and look, but not today.
The only frame where that works is the stay-at-home twin's frame. In all other inertial frames the journey is asymmetric so you can't just multiply by two.
Well, if the distance in Earth's frame is 10 ly, v=0.8c, then a one-way trip will take 12.5 yrs Earth's clock, 7.5 yrs ship's clock. A two-way trip will be 25 yrs Earth clock, 15 yrs ship's clock. Looks like multiplying by two works just fine to me.
Al
That's why DaleSpam said "The only frame where that works is the stay-at-home twin's frame", because it does work in the Earth's frame, just not in other frames. And the whole point of the twin paradox is to ask "what if we look at things from the traveling twin's perspective rather than the Earth-twin's perspective?"
Al
A confusion comes in when you try to talk about the distance from the non-travelling twin to the turnaround point and are not rigorous about which frame you are using to discuss this distance.
In the frame of the traveling twin, the maximum separation obtained is 0.8x7.5=6 light years.
If you are able to think about the traveling twin actively trying to travel to a spot 10 light years away (ie start at rest with non-travelling twin, obtain a velocity of 0.8c, travel for 12.5 years) then you will end up with other figures.
We normally use the figures from the non-travelling twin's perspective, with the assumption that despite the fact that the traveling twin does all the work, that that twin is somehow passive, or at least purely reactive.
I think it is that combination which leads to confusion.
You could try to think of it like this: I am the traveling twin, I accelerate to 0.8c, I travel 10 lightyears (12.5 years traveling in my rest frame), I turn around and I travel back 10 lightyears. Then I can see what my non-travelling twin thinks.
The non-travelling twin will think that I traveled for 20.83333 years and must have traveled a total of 16.6666 lightyears. Which is right, in his frame. If I had stopped, relative to my non-travelling twin at maximum separation, I will find that a message from him will take 16.6666 years to get to me.
Now, go back to thinking about it the normal way. To travel 10 lightyears in my non-travelling twin's rest frame, I need not travel 10 lightyears in my chosen cruising inertial frame ("cruising rest frame" just doesn't sound right). I need to travel for 12.5*0.6 years, or 7.5 years, covering a distance, in my frame, of 6 light years.
Yep, I guess it is confusing :)
The positive thing is that when we do get interstellar transport at significant percentages of c, we won't have to travel for as long (shipboard time or distance) to get to our destinations. The question will then arise as to how you measure the mileage on such a spaceship, which frame? :smile:
cheers,
neopolitan
perhaps using proper velocity would make it less confusing
Proper velocity only applies if there is a third observer, doesn't it? I made an error. I was thinking of relativistic composite velocity (since simple addition doesn't work). edit by neopolitan
If that is us, and we consider either of the twins to be at rest (and A is the de facto privileged frame since it is the only contiguously inertial frame), then the proper velocity is the velocity according to that twin. And that is the same magnitude as, different direction to, the velocity of the other twin.
Or are you thinking of some sort of post facto velocity calculation? B comes to rest at the rest point, relative to A, notes the separation, divides the separation by the proper time elapsed (time on the clock) and comes up with a higher velocity?
I don't like that.
That would mean superluminal speeds. And that is not good.
(Using Al's figures, traveling 10ly at 0.8v in A's rest frame, B reaches that in 7.5 years giving a post facto speed of 1.333c. Really, really not good.)
cheers,
neopolitan
PS I looked up proper velocity, aka celerity, and found that yes, it is coordinate distance divided by proper time of traveller and can, therefore, be superluminal. Its usefulness seems to be set a few paygrades above an undergraduate when first introduced to the twins' paradox though.
Personally I am not that keen on calling a velocity which is a mix of coordinate time in one frame and time elapsed in another frame "proper". "Improper" velocity sounds more sensible to me. But, if I ever need to use it, I will call it celerity.
It works in every frame. All frames would agree on the result.
Al
Hi neopolitan,
Sure, but that's just more reason to recognize the simple fact that the result is identical if we just consider half the trip at a time. It's the exact same problem with the same answer.
Al
OK, now let's do the same thing, but using the coordinates of the frame where the ship is at rest during the outbound trip and the Earth and the destination are moving at 0.8c. In this frame, the distance from the Earth to the destination is only 10*sqrt(1 - 0.8^2) = 6 light years, so the ship's clock reads 6/0.8 = 7.5 years when it reaches the destination in this frame, and the Earth's clock reads 7.5*sqrt(1 - 0.8^2) = 4.5 years at the same moment in this frame (i.e. according to this frame's definition of simultaneity). If you double these numbers you still get 15 years for the ship's clock, but only 9 years for the Earth's clock, which is not the right answer to what the Earth's clock reads when the ship returns to Earth.
You only get the right answer considering a one way trip if you do it correctly, not if it's done incorrectly. Which is why I think it would be very useful.
If we did use the 4.5 yrs, we would have to add 8 yrs to that when the ship came to rest to get 12.5 yrs. The ship would see the Earth clock "jump ahead" by 8 yrs when the ship comes to rest with earth. Only after the ship comes to rest with Earth is a one way trip half of a two way trip.
Al
But you said it would work even if you didn't use the Earth's frame--so, explain how you could do it "correctly" in the frame where the ship is at rest during the outbound trip and the Earth is moving at 0.8c. Do you deny that according to this frame's definition of simultaneity, when the ship's clock reads 7.5 years the Earth's clock reads 4.5 years? If you want to instead use the definition of simultaneity in the Earth frame, then you're admitting that your method only works if you make use of the Earth frame rather than any other frame.
That's not an inertial frame. Obviously you can make it work there, but also obviously you won't be using the standard intertial frame rules.
You didn't add this until after I had already responded:
Based on what? You certainly aren't using a single inertial frame here. If we allow arbitrary non-inertial coordinate systems, there's no reason that the coordinate system's definition of simultaneity at the moment the ship comes to rest relative to the Earth would have to match up with the definition of simultaneity in the inertial frame where the ship is at rest at that moment.
I think that you are thinking the right thing and just writing it wrong (clumsily), but no, what you wrote is not correct. First, proper times are frame invariant, so it doesn't make much sense to say "the proper time in a single inertial frame". Second, simultaneity is frame variant, so you need to specify which frame. What you have described here only works in the rest frame of one of the worldlines, in any other rest frame you will have to consider the distance traveled by both worldlines. Third, I don't know if this is general for arbitrary paths or if it only applies for straight worldlines. Finally, it sounds like you are considering scenarios where the twins do not start together and reunite at some other time. If so, then there are 4 events of interest, the two events of each worldline starting and the two events of each worldline ending. Those two starting events must be simultaneous with each other in the rest frame of one worldline as must the two ending events.
No. I would just point out that after the ship is at rest with earth, everyone will agree that Earth's clock reads 12.5 yrs. The difference in simultaneity between the two frames is 8 yrs. 4.5 + 8 = 12.5.
My method in this example is the same method used in the standard resolution. The twins end up in the same frame with the ship's twin 5 yrs younger than Earth's twin.
Al
I've never heard of a twins paradox variation where the ship stays in a single inertial frame. I'm using the same rules as the standard resolution.
Al
Only if you choose to use the inertial frame where the Earth is at rest, and the traveler is instantaneously at rest at the midpoint of the acceleration. But this was exactly my point, that your method only works if you use the coordinates of a single inertial frame, which you seemed to be disagreeing with when you said "It works in every frame. All frames would agree on the result." If you still maintain it works in every frame, tell me how it works in the inertial frame where the traveler is at rest during the outbound journey before accelerating (which is not the same as a non-inertial frame where the traveler is at rest at every moment, including during the acceleration).
Well if the ship is at rest with earth, they're in the same frame by definition. t=12.5 is simultaneous with the ship's clock reading 7.5 yrs after the ship comes to rest at the end of the trip.
Al
