What Defines Induced EMF in Circuit Analysis?
88 replies · 12K views
Amplitude
First part is easy . Area of the triangular loop is A = (1/2)(2R)(R) = R2
Induced EMF in loop ABC = Rate of change of flux = dΦ/dt = AdB/dt
= R2(dB/dt) which is correct .
Now the second part has stumped me .
I would really appreciate if somebody could help me with this .
Thank you .
My interpretation of part (ii) is that it is asking for the magnitude of the line integral ##\int \mathbf E \cdot \mathbf {dl}## along the straight line AB.
If so, then use the result from (i) along with symmetry arguments.
Thanks for replying .
The induced electric field lines will be concentric circles . So I can't see how line integral can be calculated .
How would we use symmetry in this ?
What's the value of the line integral for the entire triangular circuit?
What's the value of the line integral for the horizontal segment AC?
You made it look so easy :) . I have been thinking about it for last couple of days .
R2(dB/dt)
As we move along from C to A along CA , direction of induced electric field would be perpendicular at every point of the path CA as CA is a a diameter and induced electric field lines would be concentric circles .The line integral would be zero along CA .
Since field lines are circles , the paths AB and AC would look similar and their line integral would be equal .
##\int \mathbf E \cdot \mathbf {dl}## along the closed loop ABC =
##\int \mathbf E \cdot \mathbf {dl}## along the straight line CA + ##\int \mathbf E \cdot \mathbf {dl}## along the straight line AB +##\int \mathbf E \cdot \mathbf {dl}## along the straight line BC .
##\int \mathbf E \cdot \mathbf {dl}## along the straight line AB =
R2(dB/2dt) .
Is that alright ?
Thank you . Please clarify some points .
1) Is KVL applicable in a closed circuit in the presence of induced EMF ? It does seem to apply in closed circuit ABC in this problem but one of the books I have suggests otherwise .It states that when electric field is non conservative Kirchoff's Voltage Law no longer holds true .
2) In the branch AB what does the product iRAB signify ? It surely isn't the potential difference between points A and B . i2RAB is the power dissipated in wire AB .But what does iRAB tell us ?
3) The line integral ##\int \mathbf E \cdot \mathbf {dl}## along the straight line AC is zero whereas the line integral along AB and BC is non zero . Is it something like having a battery in each of the branches AB and BC , but no battery and only resistance in branch AC ? Current is determined by the net EMF of the loop ?
4) Is there an induced electric field line also on the circumference of radius R , i.e on the solenoid ?
You'll have to modify the equation. In absence of a varying B-field, the closed loop integral of E.dl (in any loop) is zero. If there's a varying B-field, closed loop integral of E.dl is equal dΦ/dt, where Φ is the magnetic flux through that loop.
It is the resultant emf in branch AB i.e.sum of electrostatic emf(conservative) and induced emf (non-conservative).
Amplitude said:
The line integral ∫E⋅dl∫E⋅dl\int \mathbf E \cdot \mathbf {dl} along the straight line AC is zero whereas the line integral along AB and BC is non zero . Is it something like having a battery in each of the branches AB and BC , but no battery and only resistance in branch AC ? Current is determined by the net EMF of the loop ?
Yes.
Yes.
Is there an electrostatic EMF in branch AB ? I think there is only non conservative EMF along the entire loop ABC .
If the branches BC and CA are removed so that only AB is sitting there, then charge will be induced on the surface of AB to create a static E field that cancels the induced E field everywhere inside AB. This will happen almost instantaneously. So, Enet = 0 inside AB. Thus, no work would be required to move a test charge from A to B inside the branch AB. In that sense, there would be zero "net emf" between AB. (@cnh1995, please correct me if this is wrong.)
That's one of the reasons I wasn't sure of the interpretation of part (ii). I interpreted it to mean: find the line integral of the nonconservative field between A and B for the straight path from A to B. I interpreted it that way because I thought it made an interesting question.
Does the answer obtained in post 5 depend on whether BC and AC are present or not ?
Why did the question asked to remove BC and AC ?
If you interpret (ii) as asking for the line integral of the nonconservative field along path AB then the answer does not depend on whether or not BC and AC are removed. But, maybe my interpretation of what (ii) is asking for is incorrect.
Your interpretation must be correct as the answer obtained matches with the answer given in the book :smile:
Do you think KVL can be applied in a closed loop where induced EMF is present irrespective of whether DC battery is present or not ?
OK, good.
Yes. The induced EMF in the loop just gets added in with the DC battery emf. That's esssentially what you are doing when you use emf = -LdI/dt for an inductor in the loop.
This is worth watching:
Wouldn't that depend on the resistances of AB and the circumference?
I have worked it out using some numerical values for dB/dt, radius and resistances of the segments and I am not getting zero net field inside AB.
If you have time, I will post it here. (It's a bit lengthy to followo0)).
@cnh1995, Here's how I'm thinking about it. With sections BC and CA removed, you just have an isolated piece of wire AB that is sitting in the induced E field of the solenoid. This E field will induce a complicated surface charge density on AB such that the net field is zero everywhere inside AB. It's like putting a chunk of metal between the charged plates of a capacitor. Induced surface charge on the chunk will create an E field such that the total field is zero at every point inside the chunk.
Here's how I thought about it: The induced charges will create an electric field in all the three parts (two arcs and segment AB), such that the sum of currents through smaller arc and AB is equal to the current through the larger arc. The field due to induced charges will depend upon the resistances of the segments.
Does that sound correct?
I interpret the circular arcs as representing the current in the windings of the solenoid. The circuit that we are interested in is the triangle ABCA. In (ii) this is dismantled with BC and CA removed so that just AB is left.
Here's my working with some actual numbers.
Let's assume radius=1. So, the area of the circle= 3.1415 unit, area of the smaller loop=0.2854 unit (π/4-1/2) and area of the bigger loop=2.8561 unit.
Assume dB/dt=5.
So, emf induced in the entire circle=AdB/dt=3.1415×5=15.70V.
Emf induced in the bigger loop=(2.8561/3.1415)*15.70=14.2736V
Emf induced in AB =R2/2*dB/dt=5/2= 2.5V (from A to B).
∴Emf induced along the bigger arc= 14.2736-2.5= 11.7732V. (B to A)
Emf induced in the smaller loop=15.70- 14.2736=1.4264V
∴Emf induced along smaller arc= 2.5+1.426= 3.9268V (A to B).
Now for each loop, these values satisfy closed loop ∫E.dl= dΦ/dt.
Is this correct so far?
I agree with your numbers. I'm interested in where you are going with this :oldsmile:.
Edit: Added figure for reference
Ok.
Let's assume the resistance of the entire circumference=1 ohm and resistance of AB=1 ohm as well.
Therefore, resistance of smaller arc=0.25 ohm and resistance of bigger arc=0.75 ohm.
Current in the circuit is counterclockwise and there is current division at points A and B, such that
Current through AB+current through smaller arc=current through bigger arc...(1)
Now, assume point B at an electrostatic potential V w.r.t. A.
Using KCL at point B (refer 1), we get
(2.5-V)/1 + (3.9268-V)/0.25= (11.7732+V)/0.75.
Solving this, we get V=0.3970V, from B to A i.e. B is at 0.3970V w.r.t. A.
As you can see, the net field inside AB is not zero and current flows from A to B.
Did I miss something here?
We are interpreting the problem differently. I was taking the large outer circle as representing the solenoid and I was not thinking of it as part of the circuit in which there is an induced current. I was taking only the triangular circuit as the circuit with an induced current. So, in part (ii), the only part of the circuit left was the straight piece of wire AB. This piece of wire is an open circuit and can't carry current. So, total E is zero inside the piece of wire.
But you are taking the outer circle to be part of the circuit. After removing BC and CA, you have a closed circuit consisting of the outer circle and the segment AB. So, you have a circuit with a "larger loop", "smaller loop", etc.
That makes an interesting circuit to think about.
OK. I think I'm with you up to here.
As you know, this is a dangerous assumption when we have a nonconservative E field.
I don't think it's correct to say IABRAB = 2.5 V for the wire AB. (See your first term in the equation quoted above.) From part (i), we know that the integral of the induced E field of the solenoid along the straight path A to B is 2.5 V. But IABRAB will be the integral of the net E field along the straight path from A to B. The net field inside AB will include contributions from induced charges at various parts of the circuit.
Does this contradict your use of 2.5 V in the first term of your KCL equation?
If my calculations are correct, the value of IABRAB would be about 2.1 V instead of 2.5 V. To get this I used two loop equations (for voltages) and one junction equation (for currents).
It is 2.1V in my calculations as well.
See the green term in my equation.
Induced emf along AB is 2.5V and V is 0.397V. That means, the net emf or iABRAB=2.5-0.397=2.1V...
OK. I was misreading your expressions. I was going too quickly and interpreted 2.5-V as 2.5 Volts rather than a subtraction of 2.5 and V. Sorry about that. Glad we actually agree.
TSny ,
I came across a much simpler question than this which has left me a bit puzzled .
Induced EMF ε across circular loop = Rate of change of flux = πR2B0
Current i flowing in the loop = ε/r . r is the resistance of the loop .
Resistance of semicircular wire AB = r/2 .
∫Edl between A and B along the circumference = ε/2
Now how do I calculate potential difference between A and B ?
Is Potential difference between A and B = (Induced EMF between A and B) - (iRAB) ?
The two terms are equal resulting in 0 potential difference .
I am quite perplexed by this result .
It is zero. There is no electrostatic voltage present because of the uniform resistance of the ring. The electrostatic potential difference appears because of non-uniform resistance and the fact that KCL has to be satisfied at every point. Here, the resistance is uniform, so there is no electrostatic voltage.
Sorry , I find this line of reasoning quite unconvincing .
What has uniformity/non-uniformity of resistance got to do with the presence of voltage ?
Does @TSny agree with the above post ?
@Amplitude. cnh1995 posted a reply while I was constructing a reply. I’ll go ahead and post my thoughts with the warning that the way I define “emf for a path” in the remarks below is not the same as cnh1995’s “electrostatic voltage” that he refers to.
Let me start with some basic remarks just to clear the way for addressing your question. I apologize if you’re already familiar with this.
When you have a changing B field, it doesn’t really make sense to ask for the potential difference between the points A and B.
In electrostatics with no changing B field, you have a potential function V such that the work needed to move a unit charge from A to B is independent of path and equal to VB – VA. The concept of potential difference between A and B is meaningful.
In the situation you have posed, the work needed to move a unit charge from A to B cannot be written as the difference in value of a potential function V. Such a function does not exist in this case because the work needed depends on the path from A to B. (I guess you could try to separate out the part of the E field that is due to static charge and define a potential function associated with that field, but I don't see any use in doing that.)
Now, even when there is a changing B field, there is a value of the net E field at each point of space. So, for a particular path from A to B, there is a well-defined value of the line integral of Enet. I don’t see anything wrong with calling the negative of this integral “the emf for this path”. The emf will be path dependent. I guess you could call this emf, “the potential difference for the path”. But that’s kind of misleading since it does not represent the difference in a potential function.
OK, with that out of the way, how do we interpret the problem you have stated in post #25 where it asks for the “potential difference between two diametrically opposite points A and B”? Once you pick a path between A and B, you can ask for the emf of this path (defined as the negative of the line integral of Enet along the path). But the answer will depend on the path. If you take the path to be the diameter of the circle from A to B, then you will get zero for the emf of this path.
Thanks a lot !
I agree with you . It doesn't make sense to ask for potential difference but that is the way questions are asked .
What will a voltmeter read when put across A and B ?
Suppose half of the ring has a resistance R and othe other half has a resistance 2R.
"Induced" elevtric field in the ring will be same at every point, regardless of the resistance. So, for both the halves, the emf induced will be E/2.
Now, compute the currents through both the halves assuming just the "induced" field as the driving quantity. The currents are not same in both the halves. To make the currents same in both the halves, there is an electrostatic voltage developed in the circuits such that it increases the net electric field in the part of high resistance (2R) and decreases the net electric field in the part of lower resistance (R), so that the currents through both the parts become equal.
Check out your original problem worked out with some actual numbers in #21.
