What determines if wave components are independent vs coherent?
The discussion revolves around the conditions that determine whether wave components are treated as independent or coherent, particularly in the context of energy calculations for wave systems. Participants explore the implications of phase relationships and the summation of amplitudes versus energies in both light interference and three-phase electrical systems.
  • One participant presents a scenario with three wave components at 120° phase separation, noting different energy calculations based on whether the waves are treated as coherent or independent.
  • Another participant suggests that coherence depends on whether the waves are in phase, indicating that in-phase waves will constructively interfere.
  • A further contribution questions whether the distinction should be based on the type of quantity being summed (amplitudes versus energies) rather than the independence or coherence of the waves.
  • It is noted that in three-phase electrical systems, the phases are not independent due to their common source and fixed phase relationship, yet power is summed rather than amplitudes.
  • Participants discuss the idea that energy may be additive regardless of phase relationships, while amplitude summation depends on coherence.
Participants express differing views on the definitions and implications of coherence and independence, with no consensus reached on the underlying principles governing these concepts.
There are unresolved questions regarding the definitions of coherence and independence, as well as the conditions under which different summation methods apply. The discussion reflects a complexity in understanding the interplay between phase relationships and energy calculations.
ChrisF
TL;DR
Asking about the physical conditions that determine whether wave components should be treated as independent (sum of squared amplitudes) or coherent (square of summed amplitudes).
I'm working through something and want to make sure I understand the physics.
In a system with three wave components at 120° phase separation, the total energy calculation depends on how we treat them:
If coherent (add amplitudes first, then square):
E = (A₁ + A₂ + A₃)² = 0
If independent (square each, then add):
E = A₁² + A₂² + A₃² = 3/2 = constant
In three-phase electrical systems, we treat the phases as independent — total power is sum of individual powers.
In light interference, we add amplitudes first.
What physical conditions determine which treatment applies? Is it whether the waves share a common source? Whether they're bound vs free? Something else?
Trying to understand the underlying principle.
It's simply whether they are in phase or not.
If you know they are the same frequency and in phase, then they will "constructively interfere".
The method for determining that they are in phase can be anything. For example, two lasers could (in principle) be properly regulated to hold to a specific frequency and phase - and would therefore not be independent.
Thanks — that makes sense for two waves.
But here's what prompted my question: In three-phase electrical systems, the phases are definitely not independent (same source, fixed 120° relationship). Yet we sum the powers, not the amplitudes.
So is the distinction not "independent vs coherent" but rather "what quantity are we summing"?
With three waves at 120°:
  • Amplitude sum = 0 (coherent cancellation)
  • Energy sum = A₁² + A₂² + A₃² = 3/2 (constant)
Both are true simultaneously. The system is coherent, but the energy doesn't cancel — it stays constant.
Is this because energy is always additive regardless of phase relationships, while amplitude depends on coherence?
It turns out that this OP joined PF to push their personal theory, which they did in several other threads. The OP is gone now and this thread is closed.
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 78 ·
  • · Replies 76 ·
