What determines the maximum weight an electric motor can lift?
The discussion revolves around the factors that determine the maximum weight an electric motor can lift or move relative to its size. Participants explore various aspects including power, energy, gearbox efficiency, and the physical properties of the motor components.
  • Some participants suggest that the maximum weight an electric motor can lift is influenced by the power available after accounting for losses in the gearbox and other mechanical components.
  • Others argue that the relationship between energy, power, and time is crucial, with motors rated by power (KW or HP) and the power-to-weight ratio being significant for sizing a motor.
  • A participant notes that the weight of the structure to which the motor is attached also limits the lifting capacity, emphasizing the importance of torque and the strength of connections.
  • Some contributions highlight that the maximum power an electric motor can achieve is determined by factors such as copper mass, iron mass, heat discharge, and the arrangement of materials within the motor.
  • A later reply mentions the Lorentz force as a fundamental principle affecting motor performance, along with the conductivity of coil materials and the structural integrity required to manage heat generation.
Participants express multiple competing views on the factors influencing the lifting capacity of electric motors, and the discussion remains unresolved regarding the most critical determinants.
Limitations include the dependence on specific definitions of power and energy, as well as the unresolved nature of how various factors interact in different motor designs.
Tabaristiio
What determines the maximum amount of weight an electric motor can lift / move for its size? So assuming the electric motor weighs a specific amount, what would be the limiting factor to how much weight it can move / lift for the weight it weighs?
Hi,
Bit of a funny question: in a lifting device there is usually a gearbox that introduces power loss.
If you want to lift something heavy with a small motor, you need a big gear ratio and the loss will be considerable.
Power of the motor minus power loss in the gearbox is what power ##P## you have left over to do the lifting.
(and there may be some friction in pulleys, etc).
The power ##P## needed to lift a mass ##m## with a speed ##v## is ##P = mgv##. The smaller ##P##, the smaller ##v##.
In practice, you don't want to wait a few days to lift a refrigerator to the fifth floor.
Ideally a "motor" can lift any amount of weight
Maximum weight lifted "x" distance = an amount of ENERGY.
Motors are rated by POWER = Energy x Time. So without talking about how fast you want to lift it, we can not size a motor. They are rated by KW or HP.
To compare size to power - is power to weight ratio.
I kind of agree.
Funny answer = the weight of the thing to which the motor is attached. no more than that.
If the motor is not attached to anything, it would be able to lift something only a little bit less than its own weight with, for example, a rope slung over a pulley, as long as the motor had the torque to do so and did not stall. Add a gearbox to increase torque, and then the weight that can be lifted would be a little less than the motor and gearbox weight. Need more weight lifted, increase torque and bolt down to a heavier base, such as a bed ( tow truck - could be an electrical motor driving a hydraulic system ) or even the earth. In that case the limiting factor besides the torque, would be the shear or tensile strength of the connection of the motor/gearbox to the base.
Maybe I should've rephrased the question instead. What determines the maximum amount of power an electric motor can have, given its size?
Much more interesting ! You did some googling already, I suppose :rolleyes:, and found at least this table and maybe also this ?
Deep inside something like the Lorentz force is the originator, so conductivity of the coil material, permeability and saturation of the core material etc. will come in.
You need to keep the thing together, which requires a sturdy structure. And you need to carry off the heat generated internally, with a fan or something.
The mechanics of an electric motor revolve around three things, copper mass, iron mass and heat discharge.
The arrangement of copper determines current draw and speed, iron determines the amount of magnetic field strength and to some extent how much heat can be absorbed and dissipated.
This applies to most motors in general, however there are ways to work around these things in very special cases.
  • · Replies 74 ·
9K
