What Determines the Pressure at Mid-Point in a Siphon Tube?
  • Thread starter Thread starter utkarshakash
    Point Pressure
The pressure at the mid-point (point P) of a siphon tube is determined using Bernoulli's Equation and the Equation of Continuity. By assuming the initial flow rate (v1) to be zero and knowing the height of the water column, density of water, and atmospheric pressure, one can calculate the velocity (v2) at the exit of the tube. This velocity can then be used to find the pressure at point P, confirming that water behaves as an incompressible fluid in this scenario.
  • Understanding of Bernoulli's Equation
  • Familiarity with the Equation of Continuity
  • Knowledge of fluid dynamics concepts
  • Basic principles of siphon operation
  • Study the derivation and applications of Bernoulli's Equation in fluid mechanics
  • Learn how to apply the Equation of Continuity in various fluid flow scenarios
  • Research the properties of incompressible fluids and their implications in fluid dynamics
  • Explore practical applications of siphons in engineering and fluid transport systems
Students of fluid mechanics, engineers working with fluid systems, and anyone interested in the principles of siphon operation and pressure dynamics in fluid flow.
utkarshakash
A wide vessel and a tube is connected as shown in the figure(see attachment). Water is filled inside vessel and tube. When tube is opened the water flows out as shown in the figure. The pressure at point P,at mid-point of the tube is (cross-section of the tube is very very small)
Bernoulli Equation
Applying Bernoulli's Equation at the top of vessel and at point P and assuming datum level to be the base of the vessel
[itex]P_o + \rho gH+\frac{1}{2} \rho v_1 ^2 = P_p + \frac{1}{2}\rho v_2 ^2 + \rho g (-H)[/itex]
Assuming area of cross section of vessel and tube be A and a and applying eqn of continuity
[itex]Av_1 = av_2[/itex]
Substituting value of v1 in prev eqn
[itex]P_o + \rho gH+\frac{1}{2} \rho \dfrac{a^2 v_2 ^2}{A^2} = P_p + \frac{1}{2}\rho v_2 ^2 + \rho g (-H)[/itex]
Now there comes another unknown variable v2 the value of which is unknown to me :(
You might want to consider this as a simple siphon, and given the wording of the question, you should take the first flow rate to be zero. V1 = 0. You know the height between the surface of the water and the exit point, the density of water, atmospheric pressure, etc. The pressure at the exit is atmospheric also.
So you calculate v2 from that. Once you have v2, you can use the equation of continuity to get the velocity at point P (hint: it's super easy 'cause water is incompressible). Then you can work out what the pressure is at point P from there.
http://en.wikipedia.org/wiki/Siphon#Velocity
Cool! That worked. Thanks for your help.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 36 ·
