What did i do wrong in my integration?
  • Thread starter Thread starter dnt
    Integration
9 replies · 3K views · last reply
dnt
(dont know how to make the integral sign so bare with me please)
i will use | to signify the integral sign:
here is my problem:
|(sinx)(cos)dx
n/a
ok this is what i did:
first i changed it to (1/2)sin2x because sin2x=2sinxcosx
so now i have:
|(1/2)sin2xdx
then i said u = 2x and du=2dx
so now i have:
|(1/4)sinudu
which is:
(1/4)(-cos u) + C
which is:
(1/4)(-cos2x) + C
where is my error?
also, can someone give me a brief overview of the best strategy to figure out what type of integration to use? what do you look for to know when to use trig substituion, integration by parts, u-substitution, etc...
ie, how do you know? thanks.
let u = sin x. then du = cos x dx.
Integration is just experience. You just need to practice.
Alternatively, since you know the integral of sinx=-cosx, you should know that the integral of sin(nx)=-cos(nx)/n
I had the exact same problem when I started integration, there really is no "trick" to know what type of integration to use. It all comes with a lot of practice. Eventually you will just recognize things and you'll know what type of integration to use.
There are general tips you can use.
If you have a square root in the function of the form sqrt(a-x^2), sqrt(a+x^2), or sqrt(x^2-a), each has a different trig substitution.
You use substitution to create a square trig function which will undo the root.
By parts is best used if nothing is obvious (can't be more vague than that :P). Specifically if one part of the function is easily integratable (eg e^x, sin(x)).
Use byparts when you see a product of somekind (hint: |f(x)dx can be considered a product of f(x) and dx)
Partial fractions is merely an algebraic method for rewriting a function in an easier-to-integrate form. You largely only use this if you see a rational expression of one polynomial divided by another. (it may be particularly advantageous is the degree of the numerator > degree of denominator)
substitution is useful if you see a function and it's derivative in the same function (eg: |ln(x)/x dx) But most times substitution can be done by inspection.
What ChaoticLlama said is pretty good, but you'll learn those over practice as well. Only thing I have to add is Trig substitution is only good if you can do trigonometric integrals as well. I can always get it down to the trig integral, which is the aim, but i can't solve that one at the end..
i should have added that i do know what the correct answer is and i knew how to get it. my question was in what step of my above work is wrong? i can't find it yet i know it comes out incorrect.
I don't think it is, expand the double angle formula for cosine and I think you will find that your solution is equivalent to the other.
What makes you think you have an error?
Yes, the way most people would integrate [itex]\int sin(x)cos(x)dx[/itex] would be to let u= sin(x) so du= cos(x)dx and the integral becomes [itex]\int udu= \frac{1}{2}u^2+ C= \frac{1}{2}sin^2(x)+ C[/itex]
But it is perfectly correct that sin(2x)= 2sin(x)cos(x) so that [itex]\int sin(x)cos(x)dx= \frac{1}{2}\int sin(2x)dx= \frac{1}{4}cos(2x)+ C'[/itex].
Have you considered the possibility that
[tex]\frac{1}{4}cos(2x)+ C'= \frac{1}{2}sin^2(x)+ C[/tex]
possibly with different values for C and C'?
Since you used sin(2x)= 2sin(x)cos(x) you might consider now using
cos(2x)= cos2(x)- sin2= 1- 2sin2(x).
dnt said:
/snip
You look at the answer and go :confused: You look at your answer and theirs again, and realize it's entirely equivalent because of the double angle formulas, I've been their :biggrin:
:eek:
