What does a single photon look like
  • Level: Graduate
  • Thread starter Thread starter quasar987
    Photon
34 replies · 21K views · last reply
Homework Helper
I've always wondered what is considered to be 1 photon. We always see things like "When two of these particle collide, they produce this and that particle, and ONE photon." The hell does that look like?!
Is it like a monochromatic plane wave but just a line.. like a frozen segment of a sine wave propagating at c in some direction..?
i think photon is like a "pulse"... a sine wave "bump"...
well, what do i know...
Come to think of it, what does any particle look like?
Is an image of a particles wavefunction the best we can hope for? Though some would argue that the wavefunction IS the particle.
Quantum Physics was never my strong suit...
Claude.
I think this is like asking what does a tree look like when nothing is looking at it. I am guessing what something looks like will depend on how we decide to 'look' at it.
Sure, someone might look at a tree from the top and say a tree is a gree circle. Someone looking at it from the ground would say it is a green ball elevated by a brown trunk. Both would then have a definition of a tree which would enable them to recognize a tree when they see one.
The same should be true about photons. If physicists say "When an electron and an anti-electron collide, the result of the collision is a photon.", it must be that they have some way to recognize a photon, otherwise, how could they be making this affirmation.
What are then, these characteristics of a photon? What does it look like as seen from a bubble chamber (besides being invisible and caracterised by certain reactions that involves it, what else can we say about it)? Etc.But what interests me the most are its electromagnetic properties.
Light and photon are particular substances exerting chemical reaction on our eyes;What does it look like seems to be more likely a biological than a physical question;We should now make another question,maybe what a photon appears?
A single photon looks like a poker hand before it is dealt. It's a probability function - a concept, not an entity with predictable, deterministic properties.
photon? that's simple, its just a thing which is two things, yet one thing. what can be simpler?
Electron-positron annihilation produces two gamma rays.
Photons interact differently with matter (usually atomic electrons) than charged particles do. That's how we tell the difference between gamma rays and beta or alpha particles.
To realize the apearance of photon,i think the pic which quasar has for its name is a very good imagination.its energy in some shape but when seen from different angles give different pictures of a same things(e.g.a sphere looks like a circle when seen from a side).OR
its nothing but STILL a lot.it is there ,but u can't see it though there is not vacuum or cavity there.
good idea:its like air ,which we can't see ,but we know its there(though experimentally proved)
Doesn't your correction to the particulars simply adjust the question, which now might be phrased as, "What does a gamma ray look like."
It does seem that a particle “looks” like whatever the detector is designed to do when the particle enters. For example, when radiation such as a photon, enters an ionizing chamber it ionizes one or more gas molecules. The ions are attracted to the oppositely charged electrodes; where their presence causes a momentary drop in voltage, which is recorded by an external electrical circuit. The amount of voltage drop helps to identify the radiation because it depends on the degree of ionization, which in turn depends on the charge, mass, and speed of the photon. And all of these properties are pre-determined by the mathematical physics. In other words, the physicists calculate what a photon’s properties are, then set a trap for one based on those properties. If a particle arrives that exhibits said properties, it is deemed to be a photon.
This seems to be something that is being over-analyzed. The retina of the eye records the impact of a single photon. That flash of light is what a photon looks like.
In keeping with the spirit of “over analyzing” this subject: :-p
There are two types of receptors on the retina at the back of the human eye. Colour vision is possible because of the cones while vision in low intensity light is possible because of the rods. In an experiment performed in 1942, it was established that on average, an individual rod was sensitive to a single photon! However this does not mean that we can consciously detect a single photon. In fact, if our eyes were that sensitive, our brain would be swamped with noisy stimuli. Indeed, we have evolved to the stage where at least between five to nine photons must reach the rods within a time period of one hundred milliseconds before filters will activate a signal to the brain and for us to be conscious of seeing something [1].
It is also important to note that only about 10% of the light that reaches the eye actually is received by the rods: 3% is reflected from the cornea, 47% is absorbed by various non-sensing parts and an incredible 40% actually falls between the rods and goes undetected. Therefore one deduces that between 500 to 900 photons must arrive at the eye every second for our brain to register a conscious signal.[2]
Very cool post, Schroder.
I knew that the retina is sensitive to a single impact, but I hadn't heard anything about the filtration system that causes the brain to ignore it. Thanks for the info.
This is the only image I could find.
Rieke and Baylor, Single-photon detection by rod cells of the retina, Rev. Mod. Phys, 1998: "...Sakitt asked her observers to rate the strength of each and every applied flash on a scale of 0–6 rather than indicating only whether the flash was seen. ... Sakitt’s work suggests further that the rods produce signals that allow neurons in the brain to discriminate between 1, 2, and 3 absorbed photons, and her experiments give an estimate of the rate of photonlike noise events that limit the reliability of this discrimination."
So I think you were right the first time round :smile: - except for the over analysis part. Apparently it was realized in the early 1900s that we might see single photons, but it took another 60 years :wink: of experiments to make that our current view.
But, is that our current view?
"The human eye is very sensitive but can we see a single photon? The answer is that the sensors in the retina can respond to a single photon. However, neural filters only allow a signal to pass to the brain to trigger a conscious response when at least about five to nine arrive within less than 100 ms. If we could consciously see single photons we would experience too much visual "noise" in very low light, so this filter is a necessary adaptation, not a weakness.
Some people have said that single photons can be seen and quote the fact that faint flashes from radioactive materials (for example) can be seen. This is an incorrect argument. Such flashes produce a large number of photons. It is also not possible to determine sensitivity from the ability of amateur astronomers to see faint stars with the naked eye. They are limited by background light before the true limits are reached. To test visual sensitivity a more careful experiment must be performed."
References
[1] The Sensitivity of the Human Eye:
Julie Schnapf, "How Photoreceptors Respond to Light", Scientific American, April 1987
S. Hecht, S. Schlaer and M.H. Pirenne, "Energy, Quanta and vision." Journal of the Optical Society of America, 38, 196-208 (1942)
D.A. Baylor, T.D. Lamb, K.W. Yau, "Response of retinal rods to single photons." Journal of Physiology, Lond. 288, 613-634 (1979)
The review by Rieke and Baylor I cited depends on Sakitt's 1972 work to suggest that single photons influence perception. They obviously have reservations drawing a stronger conclusion. I don't think the review's available free, but a detailed discussion is available on another review on Greg Field's site, on which Rieke is also an author:
Field, Sampath and Rieke
Retinal Processing Near Absolute Threshold: From Behavior to Mechanism
http://www.snl.salk.edu/~gfield/Site/Welcome_files/Field2005.pdf
"The human eye is very sensitive but can we see a single photon? The answer is that the sensors in the retina can respond to a single photon."
I'm skeptical. A grain of silver nitrate in photographic film can require several photons to trigger the grain to blow up. This depends on grain size. Film can by bathed in weak light to 'sensitize' it without setting off too many grains prematurely.
But the claim does sound reasonable, if the dyes within the eye are small enough in size; it would also be reasonable if they are single molecules.
As I recall, sensitized film can remain sensitized for years. How do these researchers know that these spots of dye have not been sensitized?
The receptor cell in the human eye contains huge amounts of light sensitive molecules. presumably one photon exciting one molecule would not be enough to trigger an electric discharge to be sent via the neural network. There is a clear need for more photons. Taking into account the incredible number of photons that pass through our iris we would be simply blinded if it was not so.( even with reflections and diffraction )
If i would imagine a photon it would look like this: the X spatial axis would be the direction; the Y (or Z does not matter) would present an electrostatic tension at it's maximum for the photons given energy. This electric tension then triggers a magnetic tension on the Z axis (Y if inverse) that rises to the point that the electrostatic becomes 0 in a sine function. the magnetic tension then triggers the electrical etc... electric to magnetic and back would be one wavelength. It's speed is then determined by the permeabilty and permeativity of the medium.
You cannot say anything meaningful about a photon in between the time it is emitted and the time it is absorbed. If you are aksing what does it look like once we have "detected it" by some means, it always looks like a particle.
Personally I think this question has no true answer just like my old bio teacher said once on the subject of sound waves "What defines sound? Sure the waves kind of do,but is it not just waves until registered by human or animal ears?" ok so the retina is very sensitive and we can not consciously see photons but does that mean that they actually look like somthing until we DO see them? I mean the electron microscope able to see atomic structure rendered in a 2-d image does that truly mean that the picture we all love to visualize of a bunch of spheres huddled together surrounded by a ever going cloud of smaller spheres really a atom? or is it wat we perceive to be an atom because as humans usually do we wish to classify it. To end my rant i say this "Why do we classify a photon? Why not keep it simple as this; We need it to see."
Since a photon travels at the speed of light it has no spatial existence in the way
we interpret all other physical particles to have. According to Einstein, who originated
the concept, the photon is not the wave but the particle of light which has a
definite quantified value of momentum.
Life and death of a photon:
http://www2.cnrs.fr/en/824.htm
The answer is fairly simple. A photon is a plain electromagnetic wave whose existence has a certain probability. This wave can give it's Energy in a single point to another quantum object. Mathematically this is it.
The confusion in the Feynman diagrams stems from the fact that they depict what happens in momentum space. The lines that are shown are not a tiny object anihilating with another tiny object producing a photon which flies distance and does something else. At least mathematically it's about infinite waves meeting in the universe and exchanging energy. On the other hand the tiny particles are, what you actually see in the detectors. This is caused by the fact, that you never have pure plain waves, but always spatial and temporal "envelopes" around them. So if you do experimental particle physics a photon is a tiny wavepacket. If you do quantum optics it's more often a standing wave in a box. And if you do theory it's an infinite plain wave filling the universe.
0xDEADBEEF said:
The answer is fairly simple. A photon is a plain electromagnetic wave ... Mathematically this is it.
Mathematically? That is not the question? The question is what is the physic(al)s object we term the photon?
The problem is that the present mathematics is a model of behavior not a model of the photon.
The present theory can not tell you if the EM mathematical description is a description of the photon (a property of the particle) or a description of the interaction of the photon (a property of the interaction - an inter-particle property) and thus lacks clearity.
That the EM description is likely not the photon is also evidenced by the fact that these can not be used when one tries to combine the photon and matter particles (QED), but requires the use of the vector potential. This unification can not be done using the EM description. Lastly the EM photon fields rise and fall together and thus do not continuously conserve total field energy.
To quote Einstein, ``Today every Tom, Dick and Hary thinks he understands the photon but they are wrong.''
If you want to know what a photon looks like, then you must see it. And, virtually all methods of "seeing" a photon result in the destruction of the photon -- or substantial modification thereof. That's how our visual system works; photons create photo-dissociation currents in rods and cones, which lead to nerve pulses traveling up the optic nerve-- if the current is strong enough (this is a very simplified description).
Everything you see is generated by photons. It could be said that vision is seeing a bunch of photons as they impinge upon the retina; and that seeing is mediated by electric currents in the retina.
The photoelectric effect sees a photon by emitting an electron.
Regards,
Reilly Atkinson
So you are replacing the well defined term photon with a fuzzy one that represents your idea of a photon. Sorry the name is taken, you may call your photon the enotstrebor-photon, and define it any way you like.
It is a description of a state of the em field. Just like an electron is a state of the electron field. Your apparent disparity does not appear to me. I agree that introductory texts into particle physics, which don't use QFT are misleading, but once you read some dedicated Quantum optics books things should clear up.
Photons are excitations of the A-Field (aka vector potential). This is why we do quantum field theory. Electrons are also an excitation of the electron particle field. Still no contradictions.
Whatever that EM description might be. Maybe you are trying to tell us, that the fact that we use the Lorenz gauge in QFT which is something we are free to choose in classical EM. This still doesn't show that we don't understand photons.
I thought there were no photon fields in EM. If you are talking about QFT again, than I assure you that the em field conserves energy just like anything else in QFT.
And he liked dreaming, and had a lot of stupid ideas too:
I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.
Albert Einstein
To summarize: We know the photon pretty well by now. Phenomenological textbooks and many QFT intros suck for reasons I don't understand, and this confuses many people, but once you have quantized the A field by hand and checked out things like quadrature squeezed states, I think you will have a better grip on the photons.
Many people falsely believe, that photons can only be measured by absorption, this is not the case. Theory gives no reason to assume this, and there are new experiments which manage to do these http://www.nature.com/nature/journal/v448/n7156/abs/nature06057.html". Half truths stated here are state of physics research many years ago. We have progressed people, photons are real and not just some clicks in a photomultiplier.
