What does disk defragmenting do?
  • Thread starter Thread starter Kutt
    Disk
36 replies · 9K views
Kutt
Turns out that my HDD and SSD are badly fragmented as they have never had a defrag run on them in more than two years. So someone recommended that I run a disk defrag.
What exactly does this do? Will it make my computer run faster?
This is what it does. It will speed up all processes that require file reading/writing and that's a lot.
However when it actually runs, it tends to slow down the computer. So it might be helpful to have it run on command, when you're not busy yourself.
Some alternatives.
See if you have any large specific file intensive task that you actually regularly do and which doesn't require finger input while running. Save your original data. Time the task with a stopwatch. Defrag your drive. Then time the task on the original data again. Then please, please, post the results here.
There is folklore that one decibel is about the minimum relative change that a person can detect, unless they are doing the two tasks side by side so they are subtracting rather than actually estimating the time. Google
decibel just noticeable difference
It is my guess that almost nobody will ever see at least a decibel decrease in real actual honest non-contrived work time from defragging their drive. I'd love to see good data on that.
I agree there is a lot of BS talked about defragmentation, but that is a very poorly designed experiment because it doesn't measure how fragmented the drive was beforehand, and unless the data files are significantly larger than the RAM size, most of the data access will be cached in RAM so the disk speed is irrelevant.
On the other hand if you DO have a data-intensive application that continuously accesses data randomly from a large database (hundreds of GBytes) in real time, and where delays of a few milliseconds are obvious without using a stopwatch, quite likely you will see the effect. One such application is computer music generation using a sound sample library. (Of course you don't so much "see" the effect as hear it, as glitches in the audio being generated).
The standard recommendation used to be to defrag the drive before installing the sample lilbrary, to ensure there was a contiguous free area of disk big enough for all the data. But these days, a better solution is to use a solid state disk, where the data transfer rate is only limited by the capacity of the data cables, not by the mechanical design of the disk drive.
Does it make a sense to defrag SSD at all? Internal data structure has nothing to do with what we see from the outside.
AlephZero said:
I agree there is a lot of BS talked about defragmentation, but that is a very poorly designed experiment because it doesn't measure how fragmented the drive was beforehand...
And how would anyone tell a novice, or most other folks for that matter, to carry out an excellently designed experiment in this?
My only goal was: X asks if defrag will help him. I tell him to time it before and after and get some actual concrete numbers that show whether it did or not. (And if you have a "hundred gigabyte audio file" then you have much bigger problem that I could ever hope to address)
I have a 128GB SSD with three games installed on it.
Battlefield 3 with all of it's expansions (over 50GB of space)
Diablo 3
Fallout New Vegas
This drive was 35% fragmented before I ran the defrag. Will this make the games I have installed on it run faster?
That is very high fragmentation. Theoretically, but you may not notice the difference. Maybe it speeds up loading by 4%. That is nice, but you may not really notice it.
I will ask again: does the defragmentation of SSD make any sense? I know the logic behind HDD, but SSD?
As far as I have read defraging an ssd will have a minimal effect on speed and because it will cause loads of write accesses to the drive it will shorten the life of the drive.
TRIM is the ssd equivalent of defragging: http://en.wikipedia.org/wiki/TRIM
I do partition backups via a file / folder copy from a partition to a folder on another hard drive. In this case, defragmenting saves a lot of time. Since the program I created to do the file / folder copy does this in directory tree order, (all files within a directory as a group), then if I do a backup / verify / format / restore / verify, then the restore and any later backups will go much faster as it's almost all sequential I/O operations. This works for Windows XP (using another instance of OS to do the backup), but not for Vista and later (my program doesn't handle junction points yet, but there may be additional issues I'm not aware of). (Note, I also save and retore partition volume id's of partitions since a quick format changes them, which can trigger re-activation or re-install issues).
In the case of a Windows 7 or 8 image backup, defragmentation wouldn't save that much time. I'm not sure if there are any file / folder oriented backup applications available for Windows 7 or 8.
It won't let me defrag my hard drive partition for some reason. :confused:
Does it give you any information about why not?
Or does the information it gives just not make any sense to you?
Is your drive more than 90% full? Sometimes that is a reason for Defrag quitting.
Are you using Windows and the built-in defrag?
Have you used or considered the free
http://www.auslogics.com/en/software/disk-defrag/
instead? It warns about nearly full drives, but you can tell it to go ahead and do a less quality job anyway.
If your drive is very badly fragmented, it might not be possible to defrag it in-place. Defragging moves file segments around, and it needs contiguous blocks of empty space in order to do this. Defragging a highly-fragmented drive is somewhat like playing Towers of Hanoi.
You didn't tell us the error you're actually getting, but if the cause is over-fragmentation, then the only real solution is to copy the data elsewhere, wipe the drive, and copy it back so it will be all neat and tidy. However, as others have pointed out, whether this is actually worth doing is questionable.
Defragging your games drive will not make your games run faster. It might make loading times slightly faster, but that's all.
SSDs have a limited number of cycles and formating one won't make a significant difference so it is almost always considered counter productive. People who need more speed can buy SSDs that plug into a pci-e slot for faster data transfer rates.
No, I have a 2TB HDD and a little more than 100GB of data stored on it. Mostly photographs, music, and miscellaneous software.
My 128GB SSD has battlefield 3 (with all of it's expansions) Diablo 3, and Fallout New Vegas.
It is more than 60% full.
then
So start your defrag program of choice, select the 2TB HDD, click Start and then tell us
1. What defrag program you are using, who made it, what brand is it.
2. Did it start defragging or not.
3. If it did not then exactly what did it tell you.
It is sometimes difficult for a person with a problem to think in a way that they then realize the people on the net hundreds or tens of thousands of miles away cannot see what is on your screen or what the minutes or even months of work have done or not done or what is in your head.
It is very difficult to tell from all the things that you are not telling anyone about this that you tried to defrag the SSD. Perhaps the defrag program is smart enough to simply refuse to defrag SSD drives.
First, that sounds like you did successfully defrag the drive. True?
Second, since I think some or maybe most gamers are fascinated by whether they are getting 54.13 frames/second or 55.26 frames/second and since you have the game in front of you, tell us, what was the old f/s and what is the new f/s. That is going to be much easier for you to tell us than it is for anyone to psychically remote view your computer and tell you those numbers.
Hmm... I once was involved in a project to answer a similar question (not specifically about defragging, but how to get the maximum disk transfer rates for an application).
We had both the computer manufacturers and the software developers involved. Since they were trying to sell us the system on the basis of its performance, they were quite interested in the results we were getting (or not getting).
We spent about four weeks getting to the stage where the numbers we were measuring didn't look like random noise. But after that "success", we didn't get anywhere much towards finding the "best" setup, though we did find a few ways NOT to configure the system.
If you have a process where the order that files are read or written in is a known order, then placing those files on a disk in that order will result in the streaming transfer rate from the disk drive, except for the overhead of accessing the cluster information for the files. One example of this is the file and folder copy operation that I use to backup partitions from one hard drive to folders on another hard drive.
At one company I worked for, we wanted to be able to boot from tape, and to simplify this operation, we added a monitor to check the file order during a boot process, and the duplicated that order on the tape. Some files got read more than once, so we have duplicates of those files on tape, so that the boot process was a streaming read from tape without any random access. The additional cleverness was allowing the command interpreter to read it's batch / script lines from the tape, so what ended up on the tape was a booter, command interpreter, then a stream that alternated between batch commands, programs, and data files.
I used to defrag religiously back in the early 1990s but haven't done it but twice in the last decade.
I notice no performance degradation because of the nature of what I do.
Other uses will be greatly improved by defragmenting such as on my digital audio workstation or anything that requires a good and uninterrupted high sustained data transfer rate.
Sadly, some files "grow" which causes a huge amount of reorganization if they had been previously moved into a space between immovable system files...and defrag decides they will fit better elsewhere.
Proper defragmentation starts right after you finalize your operating system installation and continues throughout the life of the system on the disk.
There are other things you have to consider such as whether you make your swap file static or not so your defrag strategy will change depending on what you are doing with your computer.
No. The SSD controller literally doesn't care on which NAND the wanted data sits. All locations are accesible equally, therefore defragmentating a SSD doesn't make any sense.
To the contrary - since the SSD's NANDs have only a limited number of read/write cycles a defragmentation is very high stress for your disc and will decrease its life time. It's highly recommended to turn automatic defrag and indexing OFF (Windows 7 should do this automatically).
Actually, since there are only a limited number of read/write cycles for every NAND chip of the SSD, its controller is actively scattering data all over the "disc" to distribute the burden to all NANDs evenly. Which means that it's fragmentating data and that this is an intentional process.As for normal HDDs, defragmentation is a good, meaningful thing. If logical coherent data is scattered all over the disc, the disc's reading head needs more time to access the information since it physically has to travel between those two locations. This therefore increases mechanical stress and reading times. So you want to make sure that coherent data isn't scattered. That's what defragmentation is for. But it doesn't make any sense for SSDs where there aren't moving parts anymore.
Actually my question was kinda a rhetoric one.
Not sure if anyone actually answered this, so:
An HDD has read-times dictated by physical motion of a disk and read-write head so if files are fragmented, it takes a lot of physical motion of these parts to read/write to the file, which can take a lot of time. An SDD does not have this limitation: you can access different parts of the device with no time delay in between accesses, therefore there is little or no improvement to be had by defragmenting.
SDD's are random access, and that's one of the main defining features of RAM:
Random-access memory (RAM) is a form of computer data storage. A random-access device allows stored data to be accessed quickly in any random order. In contrast, other data storage media such as hard disks, CDs, DVDs and magnetic tape, as well as early primary memory types such as drum memory, read and write data only in a predetermined order, consecutively, because of mechanical design limitations. Therefore the time to access a given data location varies significantly depending on its physical location.
http://en.wikipedia.org/wiki/Random-access_memory
What operating system are you running? Which partition is your boot drive?
russ_watters said:
An SDD does not have this limitation: you can access different parts of the device with no time delay in between accesses.
Even with an SSD, random access does have an effect on performance, specs from an example SDD: 415MB/s Sequential Read, up to 175MB/s Sequential Write and 35K IOPS for Random 4k Read . That 35K IOPS for a random 4KB read translates into 140MB/s transfer rate.
If you or your defragmentation program are not able to move system files or your virtual memory settings have a dynamic swap/page file, you will always have issues with some files that will always be fragmented.
I said earlier I haven't defragged in a 10 years but all of my systems are/were "ghosted" after a "perfect install" and defrag strategy designed to ensure system files are not fragmented or permanently fixed in places that will cause defragmentation of additional files added to the drives later.
Other guys who did not take this care during install will defrag endlessly and it takes a billion years as the program tries to work with settings that will never allow it to really do a great defrag job.
If you know which files "grow" and/or are replaced by the OS, and properly organize your physical drive, then you defrag only needs to work with the files you are adding to your drive after your perfect install.
Using default settings of your OS and defragmentation program 450 times a year is a huge waste of time and hard drive life.
This is why my hard drives are still buzzing away 16 years later on some systems.
I believe you may be confusing two completely different problems here.
I believe the first case makes a single call to the OS asking for a read.
I believe the second case makes thousands of single calls to the OS asking for a read.
As I said several posts ago, show us the numbers. Get your stopwatch. Take an SSD, defrag it, put a gigabyte text file on it, time a gigabyte copy of the file to /dev/null. Then time it with 250,000 calls each copying a 4 kbyte segment to /dev/null. That will measure the overhead of the 249,999 OS calls because your gigabyte file is perfectly defragged. Post the numbers. It isn't hard. But everyone desperately resists putting up the real numbers. (I'd do it but I don't have an SSD or I'd show you the numbers). Then you can try to create a fragmented drive that will satisfy anyone here and repeat the process. That should demonstrate your claim that a fragmented SSD is three times slower than a defragmented SSD. Problem settled.
Show the numbers.
Even if the difference is not noticeable, it can be useful. You won't see the difference between a 60-minute-task and a 61-minute-task without a clock - but the first gives you 1 minute more for other tasks, with (sometimes) a noticeable result.
On a larger scale, Google (as an example) has large groups of employees to reduce searching times by fractions of a percent, or increase ad click rates by some per mill - too small to notice it without a statistical analysis, but worth millions or even billions.
And if you take a teacup of water out of the ocean it will help with sea level rise.
And if you save a penny it will help with your $40,000 credit card debt.
And if you overclock your system from 1.8 Ghz to 1.8 Ghz+1hz it will help, even if you don't have the equipment able to measure that.
There is something called "opportunity cost", the price you pay by not doing one thing because you chose to do something else instead. Will spending five minutes defragging your drive provide you enough return to more than make up for that five minutes and be worth more than the other things you could have done instead. My rule of thumb is that if the return isn't significantly well above the noise then I'm just wasting my time. OR you could focus your time and energy on things that will make at least a decibel difference and accomplish far far more.
I remember a friend of mine, now gone, who used to pick up a penny laying in the street. When I said I didn't think that was worth doing he explained "yes, but 100 of them make a dollar" and I replied "yes, but 10,000 of those won't make one of your chiropracter's visits" and he replied "yes, there is that."
I am still betting that defrag will result in far far far less than a decibel change on any SSD and will result in less than a decibel change on a rotating drive under any but the most extreme contrived circumstance.
http://social.technet.microsoft.com...e/thread/c4cca52e-81c3-4139-b600-502b0fbd32fc
says "The automatic scheduling of defragmentation will exclude partitions on devices that declare themselves as SSDs."
http://social.technet.microsoft.com...l/thread/f97425f8-3857-4aa4-9cf5-437d5e212c9c
says "I saw the defrag schedule was enabled on my system too and I have an SSD installed. If you look closer at the defrag utility though and run it, at least in my case, it only takes a few seconds and actually runs the TRIM command on the drive, not the spindle disk type of defrag routine."
