Andreas C said:
Well, thanks for the reply, but through it all, when there was doubt, I ate it up and spit it out, I faced it all and I stood tall and did it my way, as Frank Sinatra would put it. Actually I don't think I did anything different, but anyways, here's what I did, stop me if I did something wrong:
Let's call r the distance from the center of the Earth the end of the strand closest to earth, x the distance of a point of the strand from that point, and l the length of the strand. As such, the local g at any point will be GM/(r+x)^2
So you are hanging the strand somewhere outside the Earth rather than buried deep in the inner core. And you are parameterizing the string by x with x=0 at the bottom end and x=l at the top end. That's all just fine.
I first found dF, which is the force on a point with mass dm on the strand. dm/dx=ρ, therefore dm=ρ*dx, so we've got ##dF=\frac{ρGM}{(r+x)^2}dx##.
That all looks good.
Now ##∫dF=F## so ##F=ρGM\int_{0}^{l} \frac{1}{(r+x)^2} dx⇔F=ρGM\frac{l}{r^2+rl}##.
You've factored the ##\rho G M## out of the integral. That's good.
You've evaluated the definite integral, subtracted the bottom value from the top value and simplified. That looks correct.
The total mass of the strand is m=ρl, and if we divide the two we get the final result:
##a=\frac{GM}{r^2+rl}##.
That looks correct as well. It is independent of the density, as it should be and is dimensionally correct as it must be.
As a sanity check, if we put l=0 we get the standard inverse square law for a point particle.
Perfect. I love it when folks sanity-check their work. Yes, that result seems correct.
Now we are ready to work the second part of the exercise. The strand is assumed to be in free fall -- not suspended from any point. The tension at each end must be zero. We assume for the moment that the strand falls together as a unit. The acceleration of every portion of the strand is identical. That is, it stays straight, does not stretch (much), does not break and, most importantly, does not bunch up anywhere. We can eventually sanity-check the bunch-up condition by making sure that tension is positive everywhere.
If we consider an infinitesimal section of the strand of length dx then this section must be accelerating at the same rate as the rest of the strand. That is, at a rate equal to ##\frac{GM}{r^2+rl}##. The section is subject to a downward pull of gravity based on its incremental mass (##\rho dx##) multiplied by the local acceleration of gravity ##\frac{GM}{(r+x)^2}##
By inspection it is clear that the downward pull of gravity on the top portion of the strand is too weak to account for the calculated acceleration. Similarly, on the bottom portion of the string, the downward pull of gravity is too strong. The discrepancy is made up by a gradient in the tension along the strand. The tension must change along the length of the strand.
Let us work from the bottom up. The tension on the top of an incremental section in this region will be greater than the tension at its bottom. Call the tension T. Can you see how to express ##\frac{dT}{dx}## in terms of the data you have available or have already calculated?
Can you see where to go next?
