What does momentum intuitively represent?
  • Level: High School
  • Thread starter annie122
    Momentum
57 replies · 11K views · last reply
annie122
I know momentum is mass times velocity, and that it is a conserved quantity, but I can't get the intuition of what momentum is, unlike mass and velocity.
Mass relates to how heavy an object is, and velocity is how fast an object is moving.
One idea I had is that momentum is how hard an object hits me, but I'm not entirely sure if that's an okay thing to say.
Yeah, momentum is how hard something hits you ... that's not a bad way to think of it.
If it's moving faster, it hits you harder. If it's heavier, it hits you harder. If it's both heavier and faster, you really should get out of the way.
You could also think of it as "the quantity of motion" of an object.
The easiest way for me to think of it is "mass in motion." Momentum is just how much "mass in motion."
Momentum can also be thought of as Kinetic energy.
KE = p2/2m
p = SQRT(2m*KE)
The higher the KE, the higher the momentum.
True, for two objects of the same mass.
Neandethal00 said:
Momentum can also be thought of as Kinetic energy..
Not true.
Well they each have the same unit... the eV :p
Not sure what you mean.The eV is a unit of energy,not momentum.
momentum p is indeed mass m x velocity v
p = mv
mass... is not actually the weight... weight is mass x gravity... so mass of something is its weight then deduct any gravity it was weighed in ie earth, moon etc
velocity... though is not actually speed... it is a speed and a direction... 50mph east
Kinetic energy scales at 1/2 mv^2. When you double your speed you quandruple your kinetic energy. This does not happen with momentum. It scales linearly at p=mv.
If 2 objects made of the same material have the same momentum, but different KE, the little one will be harder to stop. If they both have the same KE but different momentum, the big one will be harder to stop.
? Momentum has the Unit Ns (Newton seconds) but KE has the unit J (Joules). Not the same at all.
Momentum is a Vector quantity - it has a direction associated with it. KE has no direction specified because it is a Scalar, not a Vector.
Momentum is conserved in all collisions. Kinetic Energy is not.
But, as an object speeds up, both its momentum and KE increase - so there is a kind of association between them.
That article claims that "in high energy Physics, electron-volt is often used as a unit of momentum". I really doubt that, unless they are talking in some very isolated context. It sounds so wrong that I can't take that sentence seriously. Wiki can often be wrong and, more often, be written badly or with insufficient editing.
Whatever the article says, it is important to realize that they are two distinct quantities. I can't think anyone would claim otherwise.
I had the same reaction when I first read it but then the paragraph goes on to describe that momentum can be described by eV/c.I'm guessing that if there are people who use the eV as a unit of momentum then it is implied(though not stated) that c is included as above.If so it seems a bit sloppy to me.
Sloppy, yes. But you get this sort of thing with terminology within specialised fields. Very confusing for the outsider. (Perhaps that's why it's used?)
We used natural units in just about every physics class we had. Its pretty common.
Good King Hal established the only system of Natural Units of any importance and the Americans, God bless their cotton socks, are still using some of them.
ModusPwnd said:
The system of natural units.
http://en.wikipedia.org/wiki/Natural_units
?? I am not sure where the confusion lies. Have you really not heard of natural units before? Your professors are doing you a disservice!
HAHA. My professors are nearly all dead by now, I reckon.
I still think that a system of units which draws no distinction between Momentum and Energy is asking for trouble.
But I can't find a reference to Momentum in that link. The link itself seems to make good sense. Is there some confusion somewhere in this thread, perhaps?
There is a distinction, but they are also intimately related. Both energy and momentum are the constituents of the 4-momentum. You boost between the two and turn your energy into momentum and back. In this sense, I think you can think of momentum as energy (or vise versa).
I think modus is referring to the four vector pμ for a relativistic particle formed from its three spatial momenta and its energy divided by c.
pμ = the four vector {px, py, pz, iE/c}
The scalar product pμpμ is invariant
pμpμ = p2x + p2y+ p2z - E2/c2
= -m02c2 = a constant
I have yet to see anything to tell me that momentum and energy are the same, though. I know that mass and energy are equivalent but are they also both equivalent to momentum? I don't think so.
I didn't say they were the same.
The equation I quoted leads to another
E2 - p2c2 = m02c4
This doesn't say you can trade momentum for energy directly but tells us that a change of mass must also be involved to achieve this.
Incidentally, (someone correct me if this is wrong) I think a boost is the spacetime 4vector analog of acceleration ie what you obtain if you (vector) differentiate 4velocity. This differentiation is a linear transformation.
sophiecentaur said:
What does "boost" mean, please?
Boosting is when you change your inertial frame, when you do a lorentz transformation.
You get into your rocket and turn on the engines, you mean?
That requires energy, surely, which nullifies any implied equation between momentum and kinetic energy.
I got into this thread in response to a bald statement that the two are "the same". If a statement like that is left unchallenged then all sorts of people will go away with the wrong idea. I really can't see the point in posts (from several different people) which just play with words an dissemble about the topic. Some of the points are interesting, of course, and take us into more advanced Physics but I think it is only fair, when making them, to point out their context and that they don't mean that, in a car crash or a game of snooker, momentum and KE are the same.
I have done my share of 'showing off', I know, but it is helpful, when airing some extra knowledge, if people put the new stuff in context and don't imply that 'old' Physics got it wrong - which is what has been happening on this thread.
Is it correct to say that momentum is of no use unless we are talking about collisions of a sort?
Can momentum have any useful applications in a system where objects/particles move but are not liable to collide/interact at all? Need it be defined in the first place in such a system?
IH
Islam Hassan;3739114 Can momentum have any useful applications in a system where objects/particles move but are not liable to collide/interact at all? Need it be defined in the first place in such a system? IH[/QUOTE said:
Can you think of an example of such a system and how it could be of interest in Physics?
