What does the 'not equal to' sign mean?
  • Context: High School
  • Thread starter Thread starter kinkaid
    Mean Sign
The 'not equal to' sign ( =/= ) indicates that two objects are not equivalent, without implying any further mathematical relationships such as equating to zero. For example, the statement "blue =/= red" simply means that blue and red are not the same, and does not suggest that blue equals zero red. This distinction is crucial in programming and logical comparisons, where the expression denotes a lack of equivalence rather than a numeric relationship. The discussion emphasizes that the 'not equal to' sign should not be overanalyzed to imply philosophical or mathematical equivalences beyond its basic definition.
  • Understanding of logical operators in programming languages
  • Familiarity with mathematical notation and terminology
  • Basic knowledge of programming concepts in languages like C/C++ and Perl
  • Awareness of philosophical implications in mathematical logic
  • Explore logical operators in programming languages like C/C++ and Perl
  • Study mathematical logic and its applications in programming
  • Research group theory and its non-numeric branches of mathematics
  • Learn about the implications of truth values in programming and their representation
Mathematicians, programmers, and anyone interested in the logical foundations of equality and inequality in both mathematical and programming contexts.
kinkaid
the 'not equal to' sign ( =/= )? If I say, blue =/= red. could you simply say: blue = 0 red? Or: life =/= death... mean life = 0 death? Does the not equal to sign mean merely 'incompatible' or does it mean 0 of the thing =/=?
How do you use that sign?! I may be far off
Mathematics news on Phys.org
It simply means that the two objects are not equivalent. It is not valid to derive any equalities from that statement. For example, 2 \ne 3 does not imply that 2 = 0*3 = 0.
then what is the 'not equal to' sign used for. Progamming?
And not equal to what? What if i had a statement blue =/= red... pretty much means blue and red are logically incompatible. Almost like there is 0 red in blue and 0 blue in red. But that's not the function of Not equal to? Not equal to is only 'not equivalent'?
don't forget my question above.
Sometimes it's just as useful to know two things are not equal as it is to know two things are equal.
- Warren
It means "not equal", not "incomparable". 2 is comparable to 3 (in particular, 2 < 3), but they aren't equal. Incomparable things should be not equal -- as in apple =/= 7 -- but then again maybe not... aleph_1 is incomparable to beth_1 in ZFC, but the statement that aleph_1 =/= beth_1 can't be proven in ZFC (since aleph_1 is equal to beth_1 in some models of ZFC, namely those with the continuum hypothesis).
The expression "blue =/= red" is basically shorthand for "it is not the case that blue=red." You can draw no other conclusions from it.
The "not equal sign" isn't really used in the context you are trying to use it for.. saying blue does not equal read is not same as blue equals zero red. It's actually means literally "not equal" as in two things are not equal to each other. You are attempting to over analyze the meaning.
This may be too philosophical for this forum. contextually there is 0 so it has actual math. But I believe the idea is out of mathematical context, more philosophical.
1) 'not equal to' = no (ex. not equal to blue = no blue)
2) no blue = 0 blue
3) therefore, 0 = 'not equal to'
2) no blue = 0 blue
By your logic...
Would you say that purple =/= blue?
If so, then purple = 0 blue?
This simply is not true, purple is made of blue and red, so it must have some blue in it right?
Not equal to in no way implies zero of something or zero in anyway. It just means that two objects are not the same exact thing. I think Manchot hit the nail on the head with his definition, you can not draw any other conclusions.
diffy, this may be hard for you. but it either equals blue or it does NOT equal blue. There's no inbetween.
Ad hominem. I see no problem with Diffy's reply.
Thanks for insulting me, that's fantastic.
There is no relationship between the 'does not equals sign', and the number 0.
You can't say that, I'll go for reductio ad absurdum this time. Because then Green =/= red would imply that Green = 0 Red by the same logic. So now we have Blue = 0 Red, and Green = 0 Red, so by transitive Blue = Green.
To be honest, I have no idea what kinkaid is trying to do with the number 0 and \neq, but it reminds me a bit of how some programming languages such as C/C++ and Perl treat true and false.
In C/C++ and Perl, a true comparison is assigned the number 1 and a false comparison is assigned the number 0 (and any other integer is also consider false). However, it doesn't change anything inside of the comparison at all, it assigns the number to the entire comparison.
I.e, (A != B) is either 0 or 1 (depending on whether it's false or true respectively). This also has no mathematical basis; true and false cannot be considered integers. It is just how the results of operations are stored in memory, and giving the programmer access to this let's him do a few tricks to optimize the program.
But I've never before seen anyone get confused by this and think that this treatment of true and false had any mathematical relevance.
kinkaid, you said "it has 0 so it has actual math". However, you don't need numbers to do math. There are in fact a lot of branches of mathematics that don't have any numbers in the basic theory at all and don't depend on the existence of numbers as we usually think of them in any way. For instance, look up http://en.wikipedia.org/wiki/Group_theory" . While some familiar sets of numbers form groups, so do a lot of things that have no numbers in them at all.
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 30 ·
