What does the parameter a represent in a Taylor series?
12 replies · 2K views
abdo799
i watched a lot of videos and read a lot on how to choose it, but i what i can't find anywhere is, what's the physical significance of the a, if we were to draw the series, how will the choice of a affect it?
What a ? We at PF are bad at telepathy, so we need an example or something to guess what you mean with a...
Variable names are arbitrary. You can call everything you want "a".
Sometimes it is possible to guess what is meant if everyone uses the same variable names, but that is not the case here.
:smile: actually, in a flash of telepathic insight ( and googling 'taylor series' :rolleyes: ) I'm almost sure what abdo means, but rewarding bad practice isn't good practice ...
Probably, Abdo means the ##a## in the representation ##f(x)=\sum_{n=0}^\infty c_n(x-a)^n##. This ##a## is simply the point about which the expansion is taken. The sum will be different, and will perhaps not converge, if we change this point.
For example, expanding ##e^x## about ##0## gives ##e^x=\sum_{n=0}^{\infty}x^n/n!## but expanding about ##1## gives ##e^x=\sum_{n=0}^{\infty}e(x-1)^n/n!##
hahahahhahaha, sry, it's just that everybody calls the center of the series a, nice video though :D
u see, this is what i love about PF, everybody is friendly enough to joke about it if i made a mistake instead of keep reporting me or removing the thread
If the series converges to the function everywhere ("infinite" radius of convergence), then the full taylor series is the same everywhere, although the terms look differently - so if you just take a few of them, the approximation will look differently. Typically the approximation is good close to "a".
If the series does not converge to the function everywhere, it can look completely different for different "a".
Without a this the Tylor series and we don't have informations on it ... :biggrin:
ok, it is a stupid joke. As said before I agree assuming ##a## the center of the Taylor series. Physical interpretation is that around ##a## you can approximate, well as you want, your function by a polynomial expressions .. This is good because polynomials are simple to treat instead other functions ...
I denote it by ##x_0## or when lazy ##c## for centre. So you are wrong, not everybody calls it ##a##.
wrobel said:
he perhaps means this "a":
I don't get it. What "a"?
