What force should be used to calculate Young's Modulus?
17 replies · 3K views
gianeshwar
If a rod with cross section area A and length L is lying on a smooth table with one end being pulled by f Newtons and other end by 2f Newtons.
What force I can use in calculating Young's Modulus and why?
my doubt is whether it will be 3N or 1.5N and why?
Stretched length is given.
It will be accelerated by a = F/m, not sitting still on the table, no?
Thanks! I want to know value of force i.e., 1.5f or 3f.
Then how can I calculate Young's modulus only under these given conditions.
There is no physical condition with stable object by non zero external force. If I understand your problem.
I need to find tensile stress on rod as I want to find elongation for calculating young's modulus
The tensile stress will vary throughout the length of the rod...density & some calculus is needed.
Have you done any elongation or stress of a rotating rod type questions? This are similar.
According to my understanding so far rod is moving here with acceleration (2f-f) /m and it is also stretched having tensile stress f/2.
Thanks billy! I have not done many problems as you asked.
Stating same problem in a different wayhttps://mmi240.whatsapp.net/d/yywezFW6TcxsIWacjmME81VjKfY/AunnYXfkq2P8Blmy__wJQyRLQ4aL4z8kQXlZUs2wGVPB.jpg
https://mmi130.whatsapp.net/d/l-CffzhTrS1R5PpPeDk30FVjLnU/Ard1QFFL7XB255nzwRl_0yw8Xxy2I-ChbVHnl1qLgWAY.jpg
No, as was stated earlier, you need to take into account that the tension varies throughout the rod.
gianeshwar said:
Then here in new case answer is F?
No.
Imagine accelerating a long chain by pulling one end. Where is the chain most likely to break?
The first link must support every other link. The last link supports only it's own self weight. Therefore, the stress & elongation in each link is not the same.
Your problem looks at a chain with an opposing force on the last link.
You need to analyse an infinitesimal section of your bar, set up an integral, find the integration constant from the boundary conditions, perform the integration over the length of the bar. (Or similar, It's been a while for me..)
Every decent mechanics of materials textbook (I found Hibbeler good) will likely have multiple examples of the very similar rotating bar situation.
Thanks!Why are you saying "very similar rotating bar". Specifically rotating.
Also I want to know whether my question has a simple answer or the question is not complete or the question is irrelevant...(restated question)
They are very similar because they are analysed in a similar way.
http://www.mathalino.com/reviewer/m...als/solution-to-problem-218-axial-deformation
and exe 1.296 here
http://exir.ru/solutions/Elastic_Deformations_of_Solid_Body.htm
There is enough information given to reach a meaningful answer. Whether it's simple or not would depend on the student.
