What Forces Act on a Pulley System with Two Masses?
  • Thread starter Thread starter Jahnavi
    Pulley Two masses
65 replies · 7K views
Jahnavi
[/B]
When the right mass moves horizontally towards right , the vertical force acting on it is Mg - Tcosϑ , where ϑ is the angle which right string makes with vertical . The left mass experiences a force Mg - T . Since vertical force experienced by right mass is more , it moves closer to ground .Hence B) should be correct .
Is that right ?
What do your relevant equations have to say about that ?
Motion of masses in vertical direction are governed by respective net forces acting on them in vertical direction .The corresponding net forces have been mentioned in the post .
Is there anything more you would like me to explain ?
Yes. I don'see the speed that is imparted to the mass appearing in your reasoning. So if the speed is zero, does it stilll apply ?
And you don't say what T is either ...
Did you try to do the experiment ?
Tension in the string connecting the two masses .
Why would speed appear in force equations ?
We may consider any arbitrary horizontal speed being imparted to the right mass .
Jahnavi said:
Tension in the string connecting the two masses .Why would speed appear in force equations ?
Please write down your force balance in the horizontal direction for the mass on the right.
Tsinθ = Max
T is tension in the string and θ is angle which right string makes with vertical .
At the instant after the mass on the right has received its horizontal velocity, what is the angle theta, and what is its centripetal acceleration with respect to the point of contact of the string with the pulley?
zero .
v2/L
L is half length of string .
Jahnavi said:
zero .v2/L
OK. So, initially the vertical force balance on the right mass should really be: $$T-mg=m\frac{V_h^2}{L}+m\frac{dV_v}{dt}$$where ##V_h## is the initial horizontal velocity of the right mass and ##\frac{dV_v}{dt}## is the rate of change of its vertical velocity component.
Ok . What should be the next step in the analysis ?
Write the force balance on the left mass.
T - Mg = May
Jahnavi said:
T - Mg = May
So, what do you get if you subtract the two equations, recognizing that, for the left mass, ##a_y## is the same as ##-dV_v/dt## for the right mass?
##\frac{dV_v}{dt} = - \frac{V_h^2}{2L}##
Good. So what does this tell you about the initial vertical movement of the right- and left masses?
Lengthening and shortening of a string is given by the expression ##\frac{dV_v}{dt}## .Isn't it same for both the masses ?
No. They are moving in opposite directions. The total length of string is constant, so the length of string on the right gets longer, and the length of string on the left gets shorter.
Since you took positive upwards and from the above expression of vertical acceleration of right mass has a negative sign , it's initial acceleration is downwards .Likewise acceleration of left mass is positive means it's acceleration is upwards .
Right ?
Right ?
right.
Bestfrog said:
Can I ask you where did you take this problem?
Don't know the source .It was given in one of the Mechanics Practise sheets.
Chestermiller said:
right.
Thank you so much :smile:. Your analysis was amazing :ok:.
So , basically the left mass moves upwards and the right mass moves downwards and rightwards simultaneously .
Right ?
Could you point out the exact flaw in my reasoning in first post ?
In light of your analysis , even though my initial attempt looks odd , I can't clearly see the exact problem with that reasoning .
I think the basic approach in your first post is good. However, you seem to assume that Mg - T is positive so that both masses will initially have a downward component of acceleration. Is that possible if the string is not allowed to stretch?
Good point .
But isn't it interesting that net force on the right mass is upwards , yet it moves downwards ?
Mathematically , it is fine , but looking from an F = Ma perspective , it is quite puzzling .
Is it because the acceleration has two components and net acceleration for right mass is still upwards (despite moving downwards ) ?
If ##y_2## is the height above the floor of the swinging mass, then does the symbol ##V_v## equal ##\dot y_2##? If so, then initially wouldn't we have $$T-mg= m \ddot y_2 = m\frac{dV_v}{dt} \,\,\,\,?$$
Jahnavi said:
Good point .
Does it really move downwards initially?
It seems I am still unsure of how things are moving .
I thought right mass moves rightwards and downwards .
If left mass moves upwards shouldn't right move downwards ?
