What is 1/7 in base 2?
  • Context: Undergrad
  • Thread starter Thread starter zeebo17
    Base
8 replies · 5K views
zeebo17
What is 1/7 in base 2? How would you solve for this?
Thanks!
Mathematics news on Phys.org
The same as it is in any other base.
I assume you meant to ask how to compute its infinite binary expansion? Use long division.
As perhaps a hint, what is 1/2 in binary?
Just multiply your fraction by 2 repeatedly, writing a 0 for products less than 1, and a 1 for products greater than 1 (for the latter, subtract out 1 before continuing with the multiplication). For example:
1/7 * 2 = 2/7
2/7 * 2 = 4/7
4/7 * 2 = 1 1/7
1/7 * 2 = ... (repeats)
The binary value is 0.(001), where () indicates the repeating part.
For a little more detailed explanation, see heading "dec2bin_f()" in my article "http://www.exploringbinary.com/base-conversion-in-php-using-bcmath/".
Thanks!
wouldn't it be:
Code:
1/111
But in decimal form it would be:
Code:
0.100010111000001001
I'm not sure if it's the correct answer though. My logic was to take the result of 1/7:
Code:
0.142857
remove the decimal (by multiplying it by 1,000,000) then converting that number to binary and then re-placing the decimal.
Is my method correct?
Steve.pf said:
wouldn't it be:
Code:
1/111
sure but not real interesting.
Code:
Code:
0.142857
No your method is not correct nor is your result. See the post by DoctorBinary for the correct algorithm. Following his process the integer part of each computation yields a digit of the binary number.
Steve.pf said:
wouldn't it be:
Code:
1/111
Perhaps another way to look at it, what is 0.537 as a decimal fraction? 5/10 + 3/102 + 7/103, so what is 0.111 as a binary fraction? 1/2 + 1/22 + 1/23 = 0.87510
But .111 is NOT the same as 1/111 in decimal or binary.
