What is force? How can we interpret the full definition of force?
  • Thread starter Thread starter wondu12345ABCD
Force is defined as an interaction that can cause an object to change its velocity, calculated using the formula F=ma, resulting in units of Newtons (N). Newton's third law illustrates that for every action, there is an equal and opposite reaction, exemplified by an astronaut throwing tools to return to a ship. The discussion highlights that while force is often associated with movement, it can also exist without it, such as in structural stress scenarios. The interconnectedness of force with other physical concepts complicates its definition. Understanding force requires considering its relationship with momentum and other related principles.
wondu12345ABCD
Definition of force: force is push or pull.The force is when applying to object the object start to move in direction of force . Force is vector quantity due to fact that it needs both magnitude and direction. The unit of force is newton.By second newton law force is define or express like this ; Force is the product of mass times acceleration.one newton equals one kilogram meter second.The dimension of force is ML/T2.
Q1: How much force needed to move 3kg object accelerate 2m/s2.
Solution: Given mass=3kg & a=2m/s^2.
F=m*a=3kg*2m/s^2=6kg.m/s^2=6N.
Force is the measure of interaction between 2 or more bodies.
Newton's third law of action-reaction
Example
If an astronaut in space accidentally detaches from the ship and moves away from the ship,
How does he manage to get back to the ship?
He throws his tools in the opposite direction.
Example
Your example is more to do with momentum than with force.
@wondu12345ABCD, what are you asking of the forum? Are you just looking for confirmation of your answer?
Likes MatinSAR and PeroK
Pisica said:
That is correct, but not excluding.
But, ...force without movement can exist.
Example, internal structural stress of a bridge resisting bending loads.
Not that scientifically, I would explain it as a physical action—so it may not have a 'significant' effect, but it is produced and exists.
However, scientifically, it is hard to define it without any reference to other related concepts, as they are all interconnected. Just think of dimensional analysis.
  • · Replies 19 ·
  • · Replies 17 ·
14K
