What is negative electric potential energy?
The discussion revolves around the concept of negative electric potential energy, exploring its meaning and implications in various contexts. Participants share their understanding and confusion regarding the nature of negative potential energy, drawing parallels with gravitational potential energy and discussing the relative nature of potential energy.
  • Some participants express confusion about the meaning of negative electric potential energy and seek clarification.
  • One participant suggests that negative potential energy may indicate being surrounded by a negative potential.
  • Another participant explains that potential energy is relative to a chosen datum, and negative values arise when energy is lower than this reference point.
  • A participant uses the analogy of gravitational potential energy to illustrate how moving an object can result in negative potential energy when it is moved below a reference level.
  • One contribution discusses the idea of negative energy as a convenience for representing confinement, stating that it can be redefined to set negative values to positive or zero energy states.
  • A later reply introduces a scenario where a charge moves in the direction of an electric field, leading to a deficit in energy, which is described as negative potential energy.
  • Another participant questions the possibility of negative kinetic energy, referencing a textbook that suggests it is not feasible.
Participants generally express confusion and uncertainty about the concept of negative electric potential energy, with multiple competing views and no consensus reached on its interpretation.
Participants reference relative potential energy and the importance of a chosen datum, but the discussion includes various assumptions and interpretations that remain unresolved.
matt85
I am trying to get this concept, but I can't figure out what exactly this means. Can anyone explain what it means if something has negative electric potential energy?
Do you understand negative gravitational potential energy then?
Zz.
Does it just mean that it is surrounded by a negative potential? I'm pretty lost on this concept overall. I have never dealt with negative potential energy before.
Potential energy is relative. Relative to some datum where the potential energy is zero. If you add work to the charge to move it against the forces (from fields), you are increasing its potential energy with respect to that datum. If you extract potential energy from the charge by letting it fall with the force, then the potential energy is getting lower than the datum value, and hence negative. Just remember that potential energy is with respect to a datum. Think about ZapperZ's question in this context, and think about the tradeoff between potential energy and kinetic energy, for example.
Thanks for the help.
We usually think of (gravitational) potential energy at the Earth's surface to be zero. If we raise an object we consider it to have gained potential energy because we did work against the force of gravity. But dig a hole on the beach and move the object into it and it's now at negative potential to where it was at the Earth's surface. It's all relative.
Energy is a concept for which only the differences between two well specified situations play relevant part. Force, for instantce, is defined as the spatial derivative of energy, which clearly means that global addition of a certain fixed amount of energy will cause no physical result.
Nevertheless, as we can always sum a constant value to the energies of all positions (potential energies in the case of a conservative field) we may, for convenience, decide to attatch negative values of energy to those situations where the particle is confined and positive energy to non confined states.
Therefore, if in a pure gravitational situation, a particle have total energy negative, then it means that there will be a moment where all the energy will be in the form of potential energy due to gravitational force and the it will be at rest and/or at a limited distance from the gravitational center.
But if the particle have zero or positive total energy then, even subjected to the gravitational pull, the particle will be likely to be observed at arbitrarily great distances from the gravitational center.
In short: negative energy is just a matter of convenience to represent confinement. You can always redefine it to set some negative value to positive or zero.
Best Regards
dont think that energy is negative
think like this
there is a pt A where the charge has potential energy of 10J
now when it is moved against an electric field u supply energy by doing work and move it to anothere pt B .U have supplied 5 J so now potential energy of the charge is 15J.
which means that work done =increase in potential energy
now consider ur case
if the charge is at A with 10J and u allow it to move in the direction of E field in this case in order for the charge to move it has to spend its energy so it moves to a pt C such that it has used up all its 10J.but it still continues to move by using some internal energy and now energy decrease and becomes less that 0 and finally the charge settles at a pt D.here u find that energy is -5J.
the meaning of -5J is that it has a deficit of 5J and has to make up its deficit in order to be in the base level ( 0 J)
An analogy for this is that in order for a student to get promoted he has to score min (base level) of 30/100.if he scores 25 he has to make up his deficit of 5 marks to be in the base level
i.e base level is 0 J it has to make up its deficit and somehow has to attain the base level.
THerefore from nowonwards the -ve sign in energy indicates deficit i.e it is below base level and has to make up its deficit. Hope u understood
wat about negative Ke, i don't think its possible to have it, at least that's what my textbook said in a problem
  • · Replies 18 ·
  • · Replies 21 ·
