What is negative heat capacity ?
5 replies · 22K views
magnetar
what is" negative heat capacity"?
what is "negative heat capacity"? what is the example of it?
I can't imagine there would be such a case! For a negative heat capacity would imply that as you put more energy into a system, the system gets colder. Or as you take energy away from a system the system gets hotter. Both of these scenarios violate conservation of energy. AFAIK.
But, I haven't studied all of physics, so correct me if I'm wrong...
1) Negative heat capacity is simply when as you put energy into a system, its temperature decreases
2) One example is a black hole... I cannot think of any others.
i believe there are certain paramagnetic systems that have negative heat capacity (with constant pressure) at low temperatures.
Any gravitationally bound system will have negative heat capacity - it doesn't have to be a black hole.
Can you give a reference for this? I thought gravitationally bound systems were the only example, and would like to learn more.
