What is Negative Work and Energy?
10 replies · 4K views · last reply
fogvajarash
How can we define negative work to be? I can't get my head around negative work or energy. However, I'm thinking that it must be work that is done opposite in the direction of motion of a particle or body (say, friction). Could someone please help me understand this concept?
Yeah. I'll give you a simple example hopefully you understand. If you pick up and object with weight you are doing negative work against gravity. If you let go of the object gravity is doing positive work.
No, in this case the work you do is positive. The force you exert and the direction of motion are in the same direction: both upwards.
If you lower an object while holding it in your hand, then you do negative work on the object. In this case the force is still upwards, but the direction of motion is downwards, i.e. in opposite directions.
Another way to look at it is that "you do negative work on an object" is equivalent to "the object does positive work on you." Practical application: the weight that drives a grandfather clock. The clock does negative work on the weight, and the weight does positive work on the clock, as the weight is slowly lowered.
Have a look..
That's not right. The weight does no work on the clock because the clock is not moving. The law of action and reaction doesn't transfer from forces to work because the work also depend on whether or not the object on which the force acts is moving (displacement).
jtbell said:
Practical application: the weight that drives a grandfather clock. The driven pulley of the clock does negative work on the weight, and the weight does positive work on the driven pulley of the clock, as the weight is slowly lowered.
Suppose I changed jtbell's statement to add the text in boldface above... then it would be right (and I expect that's what he intended anyways).
Yes, the clock as a whole does not move, so I made a poor choice of words.
So what was wrong with my statement again?
Since the force you exert and the displacement are both upward, you are doing positive work.
When the object falls, gravity does positive work.
But doesn't it depend what context you say you're doing work? The example I gave was relative to gravity. You are saying exactly what I'm saying. I said and you said gravity does positive work when letting go. Okay that is settled. Now if you pick up an object you are doing positive work. Another way to say that which has the same physical meaning is that picking up an object is equivalent to gravity doing negative work on the object since gravity is a conservative force. I do positive work, simultaneously gravity does negative work. Gravity does positive work, simultaneously I do negative work when lowering down the object. I know this because I read three different texts and saw Walter Lewin explain it in his classical mechanics lecture. Do you see what I am saying?
But doesn't it depend what context you say you're doing work? The example I gave was relative to gravity. You are saying exactly what I'm saying. I said and you said gravity does positive work when letting go. Okay that is settled. Now if you pick up an object you are doing positive work. Another way to say that which has the same physical meaning is that picking up an object is equivalent to gravity doing negative work on the object since gravity is a conservative force. I do positive work, gravity does negative work. Gravity does positive work, I do negative work. I know this because I read three different texts and saw Walter Lewin explain it in his classical mechanics lecture. Do you see what I am saying?
All good.
So why didn't you say that the first time? :wink: Read what you actually wrote earlier.
You said that when you pick up an object you do negative work against gravity, which was incorrect. As you said correctly in your last post, you do positive work against gravity.
