- 159
- 13
Complex power has two components the "active" and the "reactive". I am comfused. What is the physical interpretation of the complex component?
Also what is the reactance?
Power = energy/time. For reactive power this means in first semicycle of sine oscillation the energy is delivered from a source to a load, and in next semicycle returned back from load to the source.Can you please elaborate, what does oscillating power mean?
So called reactive power is due to the energy that's stored in the reactive components. Personally, I don't like the term as I think it is used to describe something 'the opposite' to the power that is dissipated. It isn't really Power at all. All you need is to follow the Maths and avoid the name.Can you please elaborate, what does oscillating power mean?
The German version of the Wikipedia has a good article: 'Blindleistung':
http://de.wikipedia.org/wiki/Blindleistung
It has its counterpart in English, but not as detailed...
Because my understanding of reactive power is that it keeps bouncing back and forth between source and load and never gets used up.
See my post #5 in this thread about the power reversing direction for half of each cycle, I think that's what you mean by bouncing back and forth.
But that's not the whole story, a load such as a motor must be supplied with some reactive power as well as real power. It "consumes" both kinds. Reactive power is also consumed by the inductive impedance of the power lines causing the voltage to drop at the far end of the line. In some cases we must provide capacitors near the ends of those lines to replace those lost VARs and keep the voltage up.
Industrial customers are charged penalties by utilities if their loads draw too much plus or minus reactive power. That is called low power factor. Regarding your question though, those loads "consume" reactive power.
Devices called synchronous condensers are like generators that make zero real power but they make a controllable amount of plus or minus VARs. They are used to help control voltage. We also use shunt reactors (inductance between line and ground) or shunt capacitors to add plus or minus VARs to help control voltage.
So, the Primary purpose of the grid is to supply real lower, but reactive power is a necessary secondary need. Management of reactive power is the primary means of controlling voltage magnitude on the grid.
I think I am confusing reactive power with the fact that in an AC current, electrons are flowing back and forth. So I am thinking with the electrons, the reactive power is also going back and forth with the electrons and never gets used up. Only the Real Power gets used up. Maybe this thinking is incorrect?
Also can their be a AC current that has no reactive power?
With AC power, the electrons go back and forth with both real and reactive power.
Also I keep hearing about reactive power that causes heat losses?
Wouldn't that technically mean that the reactive power converts into active power, when it is lost as heat?
