What is the acceptance of the detector?
  • Context: Graduate
  • Thread starter Thread starter tsinghua
    Acceptance Detector
The acceptance of a detector in high energy physics is defined as the integration of the aperture over the solid angle, measured in cm2-steradians. For instance, using two 10-cm diameter scintillators spaced 1 meter apart results in an aperture of approximately 79 cm2 at zero degrees incidence. The maximum detectable angle of incidence is about 0.1 radians, but the effective aperture can approach 0 cm2 due to mechanical or cost limitations. Acceptance also varies based on the energy of the particles being detected, making it a function of both direction and energy.
  • Understanding of solid angle concepts in physics
  • Familiarity with scintillator detectors
  • Knowledge of particle collision dynamics in accelerators
  • Basic grasp of particle energy and detection mechanisms
  • Research the mathematical integration of aperture over solid angles
  • Study the design and function of scintillator detectors
  • Explore the principles of particle detection in accelerators
  • Investigate the relationship between particle energy and detection acceptance
This discussion is beneficial for physicists, particularly those specializing in high energy physics, detector design engineers, and students studying particle physics concepts.
tsinghua
dear all
is there anybody familiar with the definition of the acceptance of detector, especially used in high energy physics? please explain it for me.
Thanks in advance!
If you have two 10-cm diameter scintillators for cosmic rays 1 meter apart, the aperture at zero degrees incidence is about 79 cm2. Also, the maximum detectable angle of incidence is about 0.1 radians (0.01 steradians), but with an elffective aperture of nearly 0 cm2. The most accurate statement of acceptance is an integration of the aperture over the solid angle, giving an answer in cm2-steradians.
In particle accelerators, you usually know where the particles collide. The products of these events can now fly in every direction, but you usually cannot (or do not want) detect all products due to mechanical or cost limitations. The region where the particles can be detected is the acceptance. Sometimes the detection depends on the energy of the particles, too - in this case, your acceptance is not just a function of the direction, but of direction and energy of the particle.
Thank Bob S and mfb so much. Now I understand it.
best,
tsinghua
  • · Replies 24 ·
