What is the Center of Mass of the Earth + Satellite System?
The center of mass of the Earth and a satellite system can be calculated using the formula: Center of mass = (x1m1 + x2m2) / (m1 + m2). In this case, the mass of the Earth is 5.98 x 1024 kg, and the satellite has a mass of 2970 kg, positioned 42400 km above the Earth's surface. The correct calculation shows that the center of mass remains extremely close to the Earth's center, confirming that the satellite's mass is negligible in comparison to the Earth's mass.
  • Understanding of gravitational concepts and center of mass calculations
  • Familiarity with basic algebra and equations involving mass and distance
  • Knowledge of the Earth's mass and radius
  • Basic understanding of satellite orbits
  • Study the concept of center of mass in multi-body systems
  • Learn about gravitational effects of satellites on Earth
  • Explore orbital mechanics and satellite dynamics
  • Investigate the implications of mass distribution in celestial bodies
Students studying physics, particularly those focusing on mechanics and gravitational systems, as well as educators looking for practical examples of center of mass calculations in celestial contexts.
smpolisetti
This problem is driving me crazy!
How far from the center of the Earth (in km) is the center of mass of the Earth + satellite system if the satellite has a mass of 2970 kg and is in orbit 42400 km above the surface of the Earth. The mass of the Earth is 5.98*10^24 and the radius of the Earth is 6370
So:
Mass of earth: 5.98*10^24 kg
Mass of satellite: 2960 kg
Distance of satellite from surface of the earth: 42400
Radius of earth: 6370
Center of mass = (x1m1 + x2m2)/ (m1+m2)
m= mass
x= distance
Here was my attempt
I set up center of mass = [(0km (5.98*10^24)) + (2970kg * 42400km) ] / ((5.98*10^24)+2970)
From that I got 2.106*10-17 km
Which I then added to the radius of the Earth to get 6370 km
But that's wrong, what was my mistake?
All distances in the problem are being measured relative to the centre of the Earth. So, this distance in red should be the distance between the satellite and the centre of the Earth.
Why would you do this? :confused: All distances in this problem are referenced to the centre of the Earth. That means that the answer you get from your equation will be the position of the centre of mass relative to the centre of the Earth, which is exactly what you want. No corrections are necessary.
Also, please THINK about your answers and whether they make sense. Use your intuition. If the satellite weren't there, where would the centre of mass of the Earth be? It would be at the centre of the Earth, right? So, is adding a satellite, an object whose mass is negligible compared to the planet, really going to shift the centre of mass very far away from the centre of the planet?
Thanks a ton!
  • · Replies 21 ·
