What is the coefficient of friction?
The discussion revolves around determining the coefficient of friction for an object on a 30-degree inclined surface. The object has a weight of 6.9N and an applied force of 3.13N, with participants questioning the adequacy of the provided information for solving the problem.
  • Participants discuss the relationship between the applied force, weight, and the coefficient of friction, with some questioning the completeness of the problem statement. There are attempts to clarify whether the object is moving or stationary, and discussions about the implications of a negative coefficient of friction.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have provided insights into the conditions necessary for determining the coefficient of friction, while others express uncertainty about the information available. There is no explicit consensus on how to proceed.
Participants note that the problem lacks a complete statement and that the object is on a high friction surface. There is mention of potential inaccuracies in the angle of the incline, which may affect the results.
g65hy
An object on a 30 degree inclined surface with force applied up the ramp,
weight of object = 6.9N,
applied force on object = 3.13N
My answer was -0.05, but I'm not sure if this is right so I want to make sure with someone's help
Thanks
I'm not sure either. Is there a complete question here?
What's the complete statement of the problem?
yes the information is complete, I had to take it from a table with info in it so there's no complete statement, and btw there's no acceleration
So, these are observed data?
There's no way to know the coefficient of friction, without more information.
You can determine the frictional force -- perhaps -- but not the coefficient .
Ive done it for every other question...but I am in grade 11 and our formula for the coefficient of friction is μ=Ff/Fn
If you don't think there's enough info, could you do just the friction? Thanks
That's IF either of the following is true as well as the direction of the applied force is known.
1. The object is moving at a constant speed. (kinetic friction)
2. The object is stationary, but just on the verge of moving. (static friction.)
1. yes
2. yes
Im only in gr 11 physics so it won't be very complicated
The object is on a high friction surface (sand paper) and is just on the verge of moving at a constant velocity
Negative coefficients of friction do not conserve energy. If you want more help you should post more work.
edit: forgot to hit "post" and didn't see previous help
I got negative because since this was a lab, we tried to make the slope 30 degrees but probably wasnt
Thats why my teach says we may get a negative answer
So could anyone work out either the coefficient of friction or just friction?
  • · Replies 16 ·
  • · Replies 16 ·
