What is the Concept Behind 'Irreversible Adiabatic Process'?
14 replies · 26K views
zorro
What is the concept behind 'irreversible adiabatic process' ? Why is the expression for work done in this case different from that when it is reversible?
Chemistry news on Phys.org
For instance, an irreversible adiabatic compression of a gas would be one where the pressure force exerted on the gas exceeds the pressure of the gas. The work done is different than in a reversible process because the "P" that appears in the PdV expression for the work is actually the external pressure exerted on the gas and not the pressure of the gas itself, so the work would be greater than in the reversible case since the external pressure would need to be greater than the gas pressure to compress it.
What does the 'P' of a reversible adiabatic process stand for? External or Internal Pressure?
In a reversible process the external and internal pressure are the same at every point in time so there is no need to distinguish.
What about the work done in an irreversible adiabatic expansion... is it again greater than that in reversible expansion?
Here the external pressure is less than the internal pressure, so the absolute value of the work done on the system is less, but the work done on the system is negative, so the work done on the system is again greater.
Volume work is not too good an example to exemplify irreversible work (although possible).
Consider instead e.g. stirring where the deposited mechanical energy leads to an increase in internal energy which could have been achieved also by heat transfer.
Is stirring an irreversible process? But the liquid can lose its internal energy on cooling and revert to its original state.
An irreversible process is one where net entropy is created in the universe. It is irreversible because that entropy can never be destroyed. Stirring is irreversible because once the fluid settles down, work has been completely converted into heat, and this increases entropy. The fluid can be brought back to it's original state, but it must be always in a way that does not also bring the surroundings back to their original state.
It's not the clearest example of irreversible work, but I think it is the clearest example to answer the second part of the question about why the expression for the work differs from the reversible case, since there is no reversible stirring except of an inviscid fluid that retains the kinetic energy imparted by the stirrer forever, which is not usually what is thought of by stirring work.
How can it loose its internal energy if the process is adiabatic?
One remark on the original question: It is not possible to connect the same initial and final states by both a reversible and an irreversible adiabatic process. If one of the two is adiabatic, the other one has to be non-adiabatic.
You did not mention that the process is adiabatic :frown:
For a reversible A.P.,
Work done in expansion = -PextΔV
For an irreversible A.P.,
In both the cases Pext is same. So the difference in work done arises due to this Pext or a difference in volume change?
The difference arises because the external pressure is different. In a reversible expansion or compression the external pressure equals the pressure of the system. In an irreversible one it does not.
No, I didn't consider it necessary as you were asking explicitly about adiabatic processes.
