craigfperry
- 9
- 0
that uses a parachute type seal.
The discussion revolves around determining the appropriate grit hone for an air cylinder that utilizes a parachute type seal, particularly in the context of airguns. Participants explore various aspects of honing, surface texture, and seal lubrication, with a focus on the implications for performance and wear.
Participants do not reach a consensus on the ideal grit for honing, with multiple competing views on the appropriate grit and its implications for seal performance and wear. The discussion remains unresolved regarding the best approach for honing in this specific application.
Participants mention various parameters related to surface texture, such as Ra, RMS, and the need for lubrication in the crosshatch, indicating that the discussion is nuanced and dependent on specific conditions and definitions.
He is out of commission with a severe back injury. Are you going to do the repairs yourself?craigfperry said:thanks for the links this gives me a place to start.
i do know that i do need some lube to remain in the crosshatch to lube the seal.
these seals are for a pellet gun, the maker is Jim Maccari.
What is the barrel made out of? It seems like the surface hardness of the bore is too low.craigfperry said:the other thing that puzzles me is with the 400 grit crosshatch after a few hundred rounds thru the gun the crosshatch is gone and the cylinder walls are polished to a mirror finish.
