What is the Correct Minimum Force to Move a Ladder Against a Wall?
  • Thread starter Thread starter bnoone
    Equilibrium
The problem involves a uniform ladder leaning against a frictionless wall, with a focus on determining the minimum force required to move the ladder. The ladder's dimensions and weight are specified, and the scenario includes applied forces and friction considerations.
  • Participants discuss the summation of forces and torques, questioning the relationships between the applied force, normal forces, and friction. There are attempts to clarify the correct equations and the role of angles in torque calculations.
Some participants have provided guidance on correcting equations and interpreting the problem setup. There is ongoing exploration of the correct application of torque principles, with multiple interpretations of the lever arm and its implications for the calculations.
Participants note potential confusion regarding the definitions and calculations of lever arms, as well as the implications of using angles versus trigonometric ratios in their calculations. There is also mention of homework constraints that may limit the exploration of certain methods.
bnoone
A uniform ladder is 10 m long and weighs 180 N. In the figure below, the ladder leans against a vertical, frictionless wall at height h = 8.0 m above the ground. A horizontal force is applied to the ladder at a distance 1.0 m from its base (measured along the ladder).
(a) If F = 50 N, what is the force of the ground on the ladder, in unit-vector notation?
(b) If F = 150 N, what is the force of the ground on the ladder, in unit-vector notation?
(c) Suppose the coefficient of static friction between the ladder and the ground is 0.38; for what minimum value of F will the base of the ladder just start to move toward the wall?
∑[itex]\tau[/itex] = r x F and ∑F = ma
I got both parts (a) and (b) right so I don't need those.
For part (c), I summed the horizontal forces: ∑F[itex]_{x}[/itex] = 0 = -F[itex]_{f}[/itex] + F[itex]_{A}[/itex] - N[itex]_{W}[/itex]
where F[itex]_{A}[/itex] is the applied force, F[itex]_{f}[/itex] is the frictional force, and N[itex]_{W}[/itex] is the normal force from the wall.
Then I summed the vertical forces: ∑F[itex]_{y}[/itex] = 0 = N - W
Then I summed the torques using the base of the ladder as the axis of rotation: ∑[itex]\tau[/itex] = 0 = Fsin(53) + 5(180)sin(37) - 10N[itex]_{W}[/itex]sin(53)
Then I used N[itex]_{W}[/itex] = μmg - F[itex]_{A}[/itex] and substituted it into the torque equation and then plugged in all my numbers to solve for F.
I got F = 133 N, which is wrong and I'm not sure what I'm doing wrong.
This equation NW = μmg - Ff is not consistent with your earlier relationship. It should read:
NW = FA-μmg
Okay so after fixing that I have ∑[itex]\tau[/itex] = 0 = F[itex]_{A}[/itex]sin(53) +5(180)sin(37) - 10(F[itex]_{A}[/itex] - (.38)(180))
Solving for F[itex]_{A}[/itex], I got 118.23 N which is still wrong. Did I make a mistake in summing the torques?
There's no value in determining the angle. Just work with its trig ratios. These are handily rational here.
FAsin(53) +5(180)sin(37) - 10(FA - (.38)(180))
Think again about that 10.
You left out sin(53) from the last term.
And better to use the ratios as haruspex said. Taking the angle 53° means a big rounding error.
ehild
Should I use 6 (the horizontal distance from the base of the ladder to the wall) instead?
No. What is the leve[STRIKE]l[/STRIKE]r arm for NW?
ehild
ehild said:
No. What is the level arm for NW?
ehild
"Level arm"? I'm unfamiliar with the term, so bnoone might be too.
bnoone, NW acts horizontally. What is its distance from the point you're taking moments about?
Yes, I mistyped it...
ehild
Isn't it just the length of the ladder?
Torque = force * perpendicular distance. Is the ladder perpendicular to NW?
Ohhh okay that makes sense. I forgot to include the sine of the angle between them. Thank you!
  • · Replies 20 ·
  • · Replies 23 ·
15K
