What is the correct solution for the temperature expansion problem?
bolzano95
A steel container is filled with alcohol. For how much kelvins we have to raise the temperature for the pressure to be raised by 6 bar?
Compressibility of alcohol is
[tex] \kappa=1.15 \cdot 10^{-4} bar^{-1}[/tex]
temperature coefficient of volume expansion of alcohol is
[tex] \beta_a= 7.5 \cdot 10^{-4} K^{-1}[/tex]
temperature coefficient of length expansion of steel is
[tex] \alpha_s= 1.2 \cdot 10^{-5} K^{-1}[/tex]
Look at attempt at solution.
I solved this problem like this:
[tex] \frac{\Delta V}{V}=(\beta_a-3\alpha)\Delta T\\<br /> \frac{\Delta V}{V}=\kappa\Delta p\\<br /> \frac{\kappa\Delta p}{\beta_a-3\alpha}=\Delta T= 0.97K\\[/tex]
But the solution is wrong. The correct answer is 9.7K. I'm interested where I made a mistake.
It looks like your answer is off by a factor of 10. This may be due to a typo or an error in the conversion of compressibility units to bar-1.
I checked and get 0.97K. Do you think the solving process is correct?
The method is correct. If you are certain that the input numbers are also correct, then the answer in the back of the book may be a typo.
