What is the difference between potential difference and potential?
2 replies · 2K views
sgstudent
For conventional current, they say that it moves from high potential to low potential. What does this mean? pd at a point is the potential at the further end minus the closer end. So what does it mean? Thanks for the help!
You cannot talk about the potential difference at a point. It is only defined along a path. The main difference between potential difference and the potential itself is that potential difference can be measured, while the potential itself cannot. In fact, you are free to place the zero of the potential at any point you please. However, this will not change the potential difference between different points.
That "current moves from high potential to low potential" is a qualitative description of this fact. The more precise meaning is that the current carriers will accelerate in the direction of steepest (greatest negative) instantaneous potential difference.
In this context, you could say that potential is simply potential difference from a point to the reference point or ground, i.e., the point in your circuit where you define the potential to be zero. Potential difference is the difference in potential between two given points, neither one of which is the reference point
Explaining this with an analogy using gravity, things would go something like this.
Let's say we are standing at ground level and so we declare the ground to have zero potential energy. Ground is our reference, any mass that we raise above ground level will acquire a potential energy of mgh. mgh is your potential. If you have two of the same objects at difference heights, the potential difference would be mgh1 - mgh2, if h2 is lower than h1, then you have a positive potential difference...this could drive a "current" from point at h1 to point in h2...in other words, if you take a table and raise one end to a height of 24 inches and the other end to a height of just 12 inches...and you put a ball on the higher end...will it flow to the lower (potential) end? ...what if you put the ball in the lower end, will it climb to the higher end all by itself?
so, yes, current flows from the high potential to the low potential.
And not just current, also heat flows from high temperature to low temperature.
And, so, I simply keep a short statement in my head to remind me of this: Power flows downhill.
