What is the Differential Equation for Velocity with Air Resistance in Free-Fall?
  • Thread starter Thread starter heyjude619
    Diff eq Velocity
The problem involves determining the differential equation for the velocity of an object in free-fall, accounting for air resistance that is proportional to the square of the velocity. The context includes gravitational acceleration and the effects of air resistance on motion.
  • Exploratory, Assumption checking
  • The original poster attempts to formulate a differential equation based on the forces acting on the object, questioning how to incorporate gravitational acceleration and air resistance. Some participants discuss the separation of variables in the ordinary differential equation (ODE) and clarify the role of gravitational acceleration in the context of the problem.
Participants are actively engaging with the problem, with some providing guidance on the formulation of the ODE. There is a clarification regarding the interpretation of gravitational acceleration and its relationship to the forces involved.
There is a mention of the proportionality constant for air resistance and the initial conditions provided in the problem statement. The discussion reflects uncertainty about the correct application of gravitational acceleration in the context of the forces acting on the object.
heyjude619
An object in free-fall has an acceleration (which is the rate of change in velocity with respect to time) of 32.2 feet per second2 downward plus air resistance. The air resistance is proportional to the velocity squared. If the initial velocity is 0 feet per second and the proportionality constant is .0095, write and solve a differential equation that would result the function describing the velocity at any given time.
Ordinary diff eq?
dv/dt = -32.2 + .0095v^2
Tried to solve for v
Can you separate variables in your ODE ?
Ohh, yes, thank you! It's been awhile since I've done a diff eq... But, can I ask your opinion? Since it says the object is free falling, we should assuming it is still being acted upon by the force of gravity, right? So, is the acceleration given, 32.2 ft/s^2, the acceleration of the total force? Like this:
F(total)=F(air)-F(falling)=kv^2-mg
F(total)=ma=m*32.2
Or should I subsitute the 32.2 in for the gravity?
Thanks!
No, the 32.2 ft/s^2 is the value of the gravitational acceleration g.
[tex]\frac{dv}{dt} = 32.20 - k v^2[/tex]
is the ODE to be integrated.
