What is the Expected Value of Rayleigh Distribution?
alman9898
A density function used is:
f(y) = \frac{2y}{\theta}e^{\frac{-y^{2}}{\theta}} y > 0
using method of transformations find:
(a) pdf of U = Y^2
(b) E(Y) and V(Y)
f(u) = f(h^-1(u))*|dh^-1/du|
h^-1(u) = sqrt(u)
The pdf Y^2 ~ exp(theta)
E(Y) = E(U^1/2).
That is:
\int\frac{1}{\theta}u^{1/2}e^{\frac{-u}{\theta}}
So, multiply by sqrt(theta)/sqrt(theta) and group terms...
\frac{\sqrt{\theta}}{\theta}\int\sqrt{\frac{u}{\theta}}e^{\frac{-u}{\theta}}
The integral is the Gamma function with parameter 3/2. So I get...
sqrt(PI/THETA)/2 as the answer...but a little internets research reveals the expected value *should* be sqrt(PI * THETA)/2. I can't find out where my math went wrong, it's something stupid but I've been stuck for a whole day...
Try changing the variable from u to s by letting s = u/\theta,\ du = \theta ds:
\int_0^\infty\frac 1 \theta e^{-\frac u \theta}\, du=<br /> \int_0^\infty\frac 1 \theta(\theta s)^{\frac 1 2}e^{-s}\theta\, ds =<br /> \int_0^\infty\sqrt{\theta}s^{\frac 1 2}e^{-s}\,ds = \sqrt\theta\ \Gamma(\frac 3 2)
That helps alot, but if it wasn't for checking my work I would've been surely wrong. Any idea why my method didn't work; it's a trick my professor uses to solve problems with 'known' solutions.
It's because the gamma function is the integral of sqrt(v)*exp(-v)*dv. Or the integral of sqrt(u/theta)*exp(-u/theta)*d(u/theta). Not the integral of sqrt(u/theta)*exp(-u/theta)*du. The last one is what you were putting to be gamma(3/2). That's not right. You are off by a factor of theta because you didn't change the integration variable. Probably happened because you were omitting the d(something) after your integrals.
Ok I understand it now. That clears up a lot, and explains the missing term I needed to make things all nice. (I would have another theta term in the numerator to cancel the one out in the denominator).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
