What is the Factor of Safety for Overlapping Bolted Metal Plates with 12 Bolts?
  • Thread starter Thread starter sl8rbaby
    Safety
The discussion revolves around calculating the factor of safety for overlapping bolted metal plates using 12 bolts, focusing on the application of shear stress and the relevant equations. Participants explore the mathematical approach to determine the factor of safety based on given parameters.
  • Homework-related
  • One participant presents a calculation for the factor of safety using the ultimate shear stress and the total force on the joint, leading to a preliminary result of 28.42.
  • Another participant points out an error in squaring Pi in the area calculation and questions whether the factor of safety should have units.
  • A subsequent reply clarifies the correct formula for the area of a circle and emphasizes the importance of parentheses in mathematical expressions.
  • Another participant recalculates the maximum force based on the corrected area and derives a new factor of safety of 9.05, suggesting this as the final answer.
  • One participant expresses uncertainty about the correctness of their solution and seeks confirmation from others.
  • A later reply suggests that the original poster may not return, and encourages others to ask the question anew in a separate thread for more personalized assistance.
Participants express differing views on the calculations, with some pointing out errors and others proposing alternative solutions. There is no consensus on the final answer, as multiple calculations and interpretations are presented.
Participants highlight potential issues with the use of mathematical notation and the interpretation of units in the context of the factor of safety. There are unresolved aspects regarding the accuracy of the calculations and the assumptions made in the problem.
Students or individuals working on similar engineering problems involving bolted joints and the calculation of safety factors may find this discussion relevant.
sl8rbaby
Two overlapping metal plates are bolted together with 12 bolts. The diameter of each bolt is 8mm. If the ultimate shear stress of the bolt material is 300MPa determine what factor of safety applies if the total force to be carries by the joint is 20kN.
Stress = force/area
factor of safety = ultimate stress/actual stress (I think)
stress=force/area
stress=20kn/∏r^2 x 12
stress=20,000N / (∏ X 0.004)^2 X 12
= 10.55 MN/m^2
factor of safety = 300MPa/10.55 MN/m^2
= 300 x 10^6 / 10.55 x 10^6
= 28.42
Is this correct, cause I am not that confident? also what is the unit? is there one?
Your equations are good but you squared Pi in error. Would you expect the safety factor to have units? The stress unit N/ m^2 is called a Pascal (Pa).
Thanks for the reply, I thought that to work out the area of a circle which in this case is the bolt, the equation is ∏r^2? or are you saying I only need to square the radius first then times it by pi?
and no I assume there's no units as its a ratio
ok think I've sussed it:
300,000,000 x ∏ x 0.004^2 x 12 = 180,955 = max force
max force / actual force = factor of safety
180,955 / 20000 = 9.05
I sure that's the final answer!
Yes, you have to be careful with use (or non-use) of parentheses when writing equations. The area of a circle is ∏r^2 or ∏(r^2) or (∏)r^2 or (∏)(r^2) or ∏*r^2, but it is not (∏r)^2. Also when you wrote "stress=20kn/∏r^2 x 12" , that should have read ""stress=20kN/12∏r^2" or some correct variation thereof. The way you wrote it implies you are multiplying by 12 instead of dividing by 12.
And no I assume there's no units as its a ratio
correct
Well, OK, but you should round it off to 9 (one significant figure).
Did you ever find the correct solution to this question? I am currently stuck on the same one
sl8rbaby never came back again so you are unlikely to get a direct answer .
You can have some help on this problem though - ask the question afresh in a new thread here on homework section .
Best to give us your own statement of the question and your own attempts at solution rather than just copy what was originally posted .
11K
12K
  • · Replies 29 ·
