What is the geometric interpretation of a \centerdot c = 0?
  • Context: MHB
  • Thread starter Thread starter GreenGoblin
    Vector
The discussion revolves around the geometric interpretation of the equation \( r \centerdot c = 0 \) within the context of solving simultaneous vector equations involving cross and dot products. Participants explore the implications of the conditions given in the problem, particularly focusing on the distinctions between cases where \( a \centerdot c = 0 \) and \( a \centerdot c \neq 0 \).
  • Some participants note that since \( a \centerdot b = 0 \), vectors \( a \) and \( b \) are orthogonal, which is a key aspect of the problem.
  • There is uncertainty about how to isolate \( r \) as a function of the other variables and what the formal requirements for "distinguishing" cases mean in this context.
  • One participant suggests that the vector \( c \) seems disconnected from the rest of the problem, raising questions about potential missing information or typos.
  • Another participant proposes a method to express \( r \) as a linear combination of known vectors, leading to further substitutions into the equations.
  • Concerns are raised about the implications of substituting values into the equations, particularly regarding the relationship between \( c \) and \( \alpha \) and how they affect the solution.
  • Participants discuss the geometric interpretation of the case when \( a \centerdot c = 0 \), considering it may lead to \( \lambda \) being undefined or requiring a different interpretation of \( r \).
Participants generally agree on the orthogonality of vectors \( a \) and \( b \) and the need to distinguish between the two cases regarding \( a \centerdot c \). However, there is no consensus on how to proceed with the problem or the implications of the conditions given, leading to multiple competing views and unresolved questions.
There are limitations in the problem's setup, particularly regarding the role of vector \( c \) and its relationship to the other variables. Participants express uncertainty about the completeness of the information provided and the implications of the mathematical steps taken.
GreenGoblin
I am assigned the following problem,
"Solve the simultaneous vector eqs. for r:
[tex]r \times a = b, r \centerdot c = \alpha[/tex]
given that [tex]a \centerdot b = 0[/tex] and [tex]a \neq 0[/tex]
Distinguish between [tex]a \centerdot c[/tex] equal 0 and not equal 0, and give geometrical interpretation on this."
OK then. First problem.. is it not obvious [tex]a \centerdot b = 0[/tex]? Since b is the cross-product of r and a. We know already that a and b are perpendicular.
SO. Main problem.. I don't know what I am actually looking to solve here. Should I be aiming to isolate r as a function of these assorted other things? IS that the form of the solution required?
AS WELL. What does distinguish mean in a mathematical context? How can I, in a formal manner, 'distinguish' something?
Gracias,
Green Goblin
TESTTESTTESTTESTTESTTESTTESTTESTTESTTEST
Hi GreenGoblin! :)
Yep. You're right.
Yep. That would be the form of the solution required.
There is something funny with your problem though.
The vector c is hanging in the air.
It is not properly connected to the rest of the problem.
Can it be that there is more information for the problem?
Or that there is a typo?
Perhaps c is supposed to be the third vector in a basis or something like that?
They mean that you should distinguish 2 cases.
First assume that [tex]a \centerdot c = 0[/tex], and try to find r from there.
Then assume that [tex]a \centerdot c \ne 0[/tex], and try to find r from there.
Hi, there is no further information. Does this problem not have a chance to be solved then? I don't know if there is a chance of a typo. I have no opportunity to correspond with the problem setter.
Ah well, it can still be solved.
Let's see what we have.
[1] $\mathbf r \times \mathbf a = \mathbf b$
[2] $\mathbf r \cdot \mathbf c = \alpha$​
We have 1 variable, which is $\mathbf r$.
All other symbols are considered known constants.
From [1] we know that the vectors $\mathbf a$ and $\mathbf b$ are orthogonal.
To get a complete orthogonal basis we need a 3rd vector perpendicular to both a and b.
That would be $(\mathbf a \times \mathbf b)$.
So our known orthogonal basis is: $\{\mathbf a,\mathbf b, (\mathbf a \times \mathbf b) \}$.
From [1] we already know that $\mathbf r$ is perpendicular to $\mathbf b$.
That means that $\mathbf r$ is a linear combination of the other 2 basis vectors $\mathbf a$ and $(\mathbf a \times \mathbf b)$.
Let's introduce the new unknown variables $\lambda$ and $\mu$ and say that:
[3] $\mathbf r = \lambda \mathbf a + \mu (\mathbf a \times \mathbf b)$​
Can you substitute [3] in [1] and deduce something about $\lambda$ and/or $\mu$?
And substitute [3] in [2] and again deduce something about $\lambda$ and/or $\mu$?
If we have both $\lambda$ and $\mu$, we have $\mathbf r$.$\qquad \blacksquare$
Thanks,
If we plug (3) into (1), [tex]\lambda(a\times a) + \mu(a \times b)\times a=b[/tex]. The first term dies. But then I don't know what to do with the following. Am I missing an important identity? I don't see that there's anything to work with that I can make the next step. If [tex]\mu (a \times b)\times a = b[/tex] how can you find [tex]\mu[/tex]. And then if you stick that into (2), like you said, [tex]c[/tex] and [tex]\alpha[/tex] are unrelated to anything else so how can it be solved? If [tex]\mu = \frac{1}{|a|^{2}}[/tex] then I can make sense of it. If not I am back to square one. Either way I am at a brick wall for finding lambda
GreenGoblin said:
Thanks,
The vector $(\mathbf a \times \mathbf b)\times \mathbf a$ is in the same direction as $\mathbf b$, since they form an orthogonal basis.
Since all vectors are orthogonal, its length is just the product of the lengths involved.
In other words, yes, [tex]\mu = \frac{1}{|a|^{2}}[/tex].
What did you get when you substituted [3] in [2]?
Thanks a lot. Thanks a lot.
A complete mess..
and nothing really meaningful at all. Other putting it in directly, [tex]\lambda(a \centerdot c) + \frac{1}{|a|^{2}}(a \times b) \centerdot c = \alpha[/tex]. I can't go further.
A complete mess..
You could do
$$\lambda \, | \mathbf{a}| \, | \mathbf{c}|\,\cos(\varphi)
= \alpha- \frac{| \mathbf{b}| \, | \mathbf{c}|}{| \mathbf{a}|}\, \cos( \theta) \, \sin( \psi),$$
where $\theta$ is the angle between $\mathbf{a}\times\mathbf{b}$ and $\mathbf{c}$, $\psi$ is the angle between $\mathbf{a}$ and $\mathbf{b}$, and $\varphi$ is the angle between $\mathbf{a}$ and $\mathbf{c}$. Then solve for $\lambda$. Naturally, you'd like to have a better handle on those angles. I suppose you do know that $\psi=\pi/2$. So it simplifies down to
$$\lambda \, | \mathbf{a}| \, | \mathbf{c}| \, \cos(\varphi)
= \alpha- \frac{| \mathbf{b}| \, | \mathbf{c}|}{| \mathbf{a}|}\, \cos( \theta).$$
A complete mess..
What's the problem? They are all constants. ;D
[tex]\lambda = {\alpha - \frac{1}{|a|^{2}}(a \times b) \centerdot c \over (a \centerdot c)}[/tex]
It is already given that $a \ne 0$, so what's left is $(a \cdot c)$, which is either non-zero in which case you have your solution, or it is zero, and then you have to figure out what that means geometrically...
You know I have tendency to overcomplicate things. Sometimes I cannot accept the simplest answer because subconsciously maybe I suspect I am being asked a little more than I really am. Thank you very much you've been very helpful. I could get that far for sure, but I suspected I had to use a few identities and simplify things more. I'm spending time looking for things that aren't there. But I suppose that's a skill in itself one must hone.
Then again there is the question of the geometric interpretation. So in the case of [tex]a \centerdot c = 0[/tex] you are dividing by zero and you have that lambda is undefined (or simply [tex]\lambda a = 0[/tex] since you couldn't then divide through? In which case, r only has the mu term? What is giving a geometric interpretation really asking here? I can note a few consequences as I have done but I don't know what kind of answer is appropriate.
Yep. For myself I have spent a lot of time learning how to make and keep things simple. :D
As for the geometrical interpretation, let's draw a picture.
http://www.mathhelpboards.com/attachment.php?attachmentid=605&stc=1
The vector r is a linear combination of a and (axb).
And if (a.c)=0, that means that c is perpendicular to a.
This means that c is a linear combination of b and (axb).
As we have seen, in that case it is impossible to find $\lambda$.
That is because no matter how much the vector a contributes to r, we get the same dot product $(r \cdot c)=\alpha$.
When c is not a linear combination of b and (axb), the contribution of a to r can be determined uniquely.
  • · Replies 16 ·
