What is the impact of changing the reference angle in a static friction problem?
  • Thread starter Thread starter Jzhang27143
    Disk String
The discussion revolves around a static friction problem involving a disk held by a string, where participants explore the implications of changing the reference angle for tension calculations. The problem is situated within the context of statics and friction, specifically focusing on how the angle affects the tension in the string.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants examine the relationship between the reference angle and the resulting tension in the string, questioning whether changing the angle impacts the direction of inequalities in tension equations. There is a discussion about the implications of defining angles differently and how this affects the bounds on tension.
Some participants have provided insights into the relationship between positive and negative angles, suggesting that the direction of inequalities should be reconsidered. There appears to be a productive exploration of how different angles influence the tension calculations, with some participants clarifying the bounds for tension based on angle sign.
Participants note discrepancies in problem wording and references, which may affect their understanding and approach to the problem. There is also mention of the need for graphical representation to clarify the relationship between tension and angle.
Jzhang27143
A disk of mass M and radius R is help up by a massless string. Let there now be friction between the disk and the string, with coefficient u. What is the smallest possible tension in the string at its lowest point?
The problem is problem 8 from here: http://www.personal.kent.edu/~fwilliam/Chapter 1 Statics.pdf
Fnet = 0 at equilibrium. fs <= uN
I understand how to do the problem when the angle theta is defined to be 0 at the lowest point and pi/2 at the right end. In this case, the result is T(0) >= Mg/2 e^(-u*pi/2). However, I wanted to see what would happen when theta is 0 at the right end and -pi/2 at the lowest point since it shouldn't matter. As in the solutions, the equation for tension as a function of theta should still be T(theta) <= T(0) e^(u*theta). In this case, T(0) = Mg/2 so T(theta) <= Mg/2 e^(u*theta). So if you plug in theta = -pi/2, T(-pi/2) <= Mg/2 e^(-u*pi/2). But here, the direction of the inequality is different. Was I supposed to switch the sign somewhere?
Jzhang27143 said:
The wording of problem 8 appears to be different. It says..
8. Tetherball *
A ball is held up by a string, as shown in Fig. 1.12, with the string tangent to the ball. If the angle between the string and the wall is µ, what is the minimum coefficient of static friction between the ball and the wall, if the ball is not to fall?
I believe it's problem 8 in section 1.4 rather than 1.3.
Ok forget that. I see there is another Problem 8 on page I-13.
Are you sure that the direction of the inequality is correct for negative values of θ? A graph of ##T(0) e^{\mu \theta}## for both positive and negative θ might help.
Ok I see that the direction should be flipped since theta is negative. That would give me T(theta) >= T(0) e^(u*theta). So is this the lower bound for T(theta) and the solution's T(theta) is the upper bound?
For negative Θ, T(0) eμΘ is a lower bound for the tension. For positive Θ, T(0) eμΘ is an upper bound for the tension.
See the plot of T vs Θ shown below for the case where T(0) = 1 unit. The red curve is a plot of T(0) eΘ for μ = 1 and represents the tension when the static friction is at its maximum. The blue horizontal line is the tension as a function of Θ when there is no friction. If you now add another curve that represents friction acting at less than its maximum it would need to lie between the red and blue graphs, like the dotted curve. Note the difference for positive and negative Θ.
  • · Replies 24 ·
  • · Replies 21 ·
  • · Replies 103 ·
15K
  • · Replies 18 ·
