What is the impulse exerted by a bullet on a block?
20 replies · 3K views
NasuSama
A bullet of mass m = 17.6 g traveling horizontally at speed vo = 565 m/s strikes a block of mass M = 678 g sitting on a frictionless, horizontal table. This time, however, it comes out the other side of the block at speed v = 524 m/s.
Calculate J, the magnitude of the impulse exerted by the bullet on the block.
Hm...
Impulse = Momentum = Ft = mv_f² - mv_i²
I think that the impulse is same as the momentum. I think that is...
Impulse = (M + m)v_f² - mv_i²
But it seems like I'm on the wrong path.
The momentum is mV. When a force F acts for time Δt on a point mass m the momentum will change and the change of momentum equals to the impulse of the force: FΔt=mVf-mVi
ehild
ehild
Does this means that only the mass of the bullet takes in account of this situation?
It means that the momentum is proportional to the velocity instead of the square of the velocity as you wrote.
ehild
Hm...
Impulse = Momentum = Ft = mv_f - mv_
Impulse = (M + m)v_f - mv_i
This is the revised work.
ehild
You didn't answer my question. Does the mass of the bullet takes in account of the momentum or the mass of both objects?
Lacking approach and explanation here. Not helpful. -__-
Sorry.
ehild
Waiting for other response. Otherwise, it seems that I need to answer myself.
bdh2991 said:
Did you try using I = pfinal - pinitial?
Yes, I did, but it seems that I made the wrong approach. I believe that is...
(m + M)v_f² - (m + M)v_i²
= - (m + M)v_i²
It doesn't state that part of the mass of the block sticks to the bullet so you should just be able to use the bullet mass and the final and inital velocities for change in momentum
Then, it's mv_f - mv_i, where m is the mass of the small bullet.
Then, this is the negative impulse. We have m(v_f - v_i)
This is what I have:
I = mv_f - mv_i
If I only use the mass of the bullet as the part of this equation, then we have...
I = 0.0176 * (524 - 565) = -0.722
Is that true?
I = mv_f - mv_i
Is that true?
All you were supposed to calculate was I = Δp , where Δp is linear momentum and I is impulse...
Your work seems correct to me. Mass of the block was only to confuse you. This is because from the given parameters , you cannot solve for deceleration in bullet and time period..
But it seems that the answer is not right. I entered it, but not right.
Well consider right x-axis to be positive and left to be negative. (Choice of sign convention lay in user's choice , but then he has to stick to that convention throughout the problem.) So by Newton's third law , force which block exerts on bullet will be equal and opposite to force exerted by bullet on block. Since Δt is constant , so impulse exerted by block on bullet will be negative of that by bullet on block. Thus I=Δp , simply.
Why you say , this isn't correct ?
Based on what I know, impulse can't be negative. It's force times time. Even though impulse is same as the momentum, impulse can't have negative magnitude. I spoke with my instructor about this, and he said that impulse can't be negative.
Adding into what I said before, impulse is Force times time. Though it's the same as momentum, the impulse can't be negative. That is what is different from the momentum.
Of course , impulse can be negative if you consider its direction based on your sign convention. Impulse is a vector quantity , and vector quantities can be negative , although its magnitude is always positive.
http://answers.yahoo.com/question/index?qid=20080113150901AAmY7fE
http://answers.yahoo.com/question/index?qid=20100303191234AAUuV5V
http://www.thestudentroom.co.uk/showthread.php?t=912889
Also consult professor google...
