What is the magnitude of the electric field?
The discussion centers on calculating the electric field generated by three point charges: q1 = -4.19 nC, q2 = 5.41 nC, and q3 = 2.51 nC, positioned along the x-axis. The electric field at the point (0, 2.02) is determined using the formula E = kq/r², where k is the electrostatic constant. The horizontal component of the electric field (Ex) is calculated to be -0.3276 N/C, while the vertical component (Ey) is 7.88 N/C, resulting in a net electric field magnitude of 7.88 N/C. The direction of the electric field components is crucial, with the negative charge attracting the field towards itself and the positive charges repelling it.
  • Understanding of Coulomb's Law and electric fields
  • Familiarity with vector components in physics
  • Knowledge of the electrostatic constant (k)
  • Ability to perform trigonometric calculations for angles
  • Study the concept of electric field directionality in relation to charge types
  • Learn about vector addition of electric fields from multiple charges
  • Explore the implications of charge placement on electric field strength
  • Investigate the effects of distance on electric field calculations
Students studying electromagnetism, physics educators, and anyone interested in understanding electric field calculations involving multiple point charges.
n_h0987
Three point charges, q1 = -4.19 nC, q2 = 5.41 nC and q3 = 2.51 nC are aligned along the x-axis as shown in the figure below.
[URL]http://imgur.com/RaRML[/URL]
Assume that L1 = 0.496 m and L2 = 0.816 m. Calculate the electric field at the position (0, 2.02).
E = kq/r^2
Horizontal electric field = Ex = k(-4.19*10^-9)cos76/2.08^2 + k(2.51*10^-9)cos68/2.18^2 = -0.3276 N/C
Vertical electric field = Ey = k(-4.19*10^-9)sin76/2.08^2 + k(5.41*10^-9)/2.02^2 + k(2.51*10^-9)sin68/2.18^2 = 7.88 N/C
Net field = square root of Ex^2 + Ey^2 = 7.88 N/C
Please help! :(
E = kq/r^2
That equation gives the magnitude of the electric field, but not its direction. To tell what direction it points in, use the rule the E points away from positive charges or towards negative charges.
You're close. Here are two questions for you:
In what direction does the horizontal part point due to the -4.19 nC charge? (Hint, E points towards this negative charge, therefore it's in the (+x, -x?) direction.)
In what direction does the the horizontal part point due to the +2.51 nC charge? (Hint, E points away from this positive charge, therefore it's in the (+x, -x?) direction.)
Please help! :(
The components of the negative charge point in the opposite direction relative to the two positive charges, right? So the horizontal part of the negative charge points in the -x direction while that of the positive charge points in the +x direction. Isn't that accounted for with the negative sign in front of the 4.19 nC charge? So I ended up subtracting the magnitudes of the negative charge's components from those of the positive charges...is that not right?
Since the point in question is to the left of the positive charge q3, and E points away from positive charges, then the horizontal component of E due to q3 points to the left, i.e. it's negative also.
If you still don't see that, label the point (0, 2.02) in the diagram. Then draw a vector pointing directly away from charge q3. In what direction is the horizontal component of this vector?
  • · Replies 23 ·
