What is the mass of 55 Cancri in kg and solar masses?
  • Thread starter Thread starter Lauren0619
    Mass
The mass of 55 Cancri was calculated using the average values of R^3/T^2 from three orbiting planets, resulting in an initial estimate of 1.73 x 10^31 kg. After recalculating the average to 3.13 x 10^18, the corrected mass was found to be 1.85 x 10^30 kg. This value is confirmed to be in kilograms, with no additional conversions needed. The conversion to solar masses yielded a result of approximately 0.93 Ms. The calculations and conversions were deemed reasonable based on the provided data.
Lauren0619
I have to find the mass of 55 Cancri in kg using the average orbits of 3 orbiting planets. Specifically, "Using the average of the values of R^3/T^2 that you filled in just for planets c, f, and d in #2, approximately what is the mass of 55 Cancri in kg?
planet c = 3.14 x 10^18
planet f = 3.16 x 10^18
planet d = 3.10 x 10^18
Then to convert the mass in kg to solar masses.
M=(4pi^2/G)(R^3/T^2) With T equaling the period
(3.14 x 10^18) + (3.16 x 10^18) + (3.10 x 10^18) / 3 = 7.3 x 10^31
M= (4pi^2/6.67x10^11)(7.3x10^18) = 1.73x10^31 kg
Is this correct? Or is this value in another form that I need to convert to kg?
And then would it convert to 8.70 Ms (solar masses)?
Please help! Thank you all!
All of your data values are close to 3 x 1018, so I would expect their average to be similar. Check your average calculation.
Likes Lauren0619
Thanks gneill! I redid the calculations. You were right. For my average I got 3.13x10^18. I plugged that into the formula to calculate mass and got 1.85x10^30 kg. Is this correct?
Yes, that looks much better.
Likes Lauren0619
Cool! And just to be sure, this is in kilograms, right? I wasn't sure if there was a conversion that I needed to do that was missing.
Also, I redid the conversion to solar masses from kilograms and got .93Ms.
Your problem statement didn't mention what units the R^3/T^2 values were given in so I can't say decisively, but it would make sense that they'd be in ##m^3/s^2##, giving you a result in kg.
That looks reasonable.
Likes Lauren0619
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
