What Is the Mass of the More Massive Block?
The discussion focuses on solving a physics problem involving two blocks of different masses connected by a rope over a frictionless pulley. The total mass of the blocks is 14.0 kg, and after the more massive block descends 1.30 m, it reaches a speed of 3.50 m/s. The key equations used include the conservation of energy and the kinematic equation v² = u² + 2as. By calculating the force required to accelerate the mass and using the difference in weights, participants derive the mass of the more massive block through simultaneous equations.
  • Understanding of Newton's Second Law (F = ma)
  • Familiarity with kinematic equations (v² = u² + 2as)
  • Knowledge of gravitational force (weight = mass * gravitational field strength)
  • Ability to solve simultaneous equations
  • Study the principles of conservation of energy in mechanical systems
  • Learn more about kinematic equations and their applications in physics
  • Explore the concept of forces in equilibrium and dynamics
  • Practice solving simultaneous equations in physics problems
This discussion is beneficial for physics students, educators, and anyone interested in understanding mechanics involving pulleys and mass dynamics.
kdizzle711
Two blocks with different mass are attached to either end of a light rope that passes over a light, frictionless pulley that is suspended from the ceiling. The masses are released from rest, and the more massive one starts to descend. After this block has descended a distance 1.30 m, its speed is 3.50m/s .
If the total mass of the two blocks is 14.0 kg, what is the mass of the more massive block?
(1/2)mv1^2+mgy1=(1/2)mv2^2+mgy2
Can someone help me get started with this problem? I'm not sure I am using the right equation or approaching it correctly
Since you know that a 14 Kg mass has been accelerated from rest to 3.50 m/s over a distance of 1.30 m, you can detemine the acceleration from the equation:
v^{2} = u^{2} + 2as
From there you can calculate the force required to accelerate the mass at that rate with:
F = ma
That will give you the difference in the weights of the two masses.
What does u^2 stand for?
v is the final velocity, u is the initial velocity. Perhaps you use a different type of notation. The same formula is listed last here in a different notation.
I found that the F=ma is 65.94N, but where do I go from there?
Like I said, that's the difference in their weights (though I actually get 65.96 N). You can divide that by g to find the difference in their mass since weight = mass * gravitational field strength.
If you call the two weights a and b, that will give you:
a - b = 65.96/g
You also have
a + b = 14
Now you have to solve the simultaneous equations.
Thanks, I got it. You guys are amazing
Nah, not amazing just ... yeah OK, amazing. :wink:
Happy to help. :smile:
This appears to be a common question. I got the same thing with different values, but the formulae here worked!
  • · Replies 18 ·
  • · Replies 21 ·
10K
  • · Replies 25 ·
