What is the maximum reflection angle in the Chandra X-ray telescope optics?
The discussion revolves around determining the maximum reflection angle in the optics of the Chandra X-ray telescope, which operates within the 0.1-10 keV range. The problem involves parameters such as the focal length and mirror radius, prompting participants to explore geometric relationships in the context of X-ray optics.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the relevance of the wavelength and whether to apply formulas for concave mirrors. There are suggestions to simplify the problem using geometry and to consider the setup of the telescope's mirrors. Some participants express uncertainty about the geometry involved and the necessary angles for reflection.
The discussion is ongoing, with participants providing hints and guidance on how to approach the problem geometrically. There is an acknowledgment of the need to clarify the setup and angles involved, but no consensus has been reached on a specific method or solution.
Some participants note that the telescope's mirrors differ from those in traditional optical telescopes, which may affect the approach to solving the problem. There is also mention of the participant's previous experience with similar calculations, indicating a potential gap in knowledge that could influence their understanding of the current problem.
ExoP
Hi!
I'm having a problem with one assignment and I would really need som help. The question is:
The Chandra X-ray telescope is used for observations in the 0.1-10 keV range. Focal
length is 10 m, max mirror radius is 0.6 m. What is the largest reflection angle in the optics
(assuming that both reflections are of the same size)?
I started first to find the wavelength by using the E=hc/λ formula. I got 12,4082 nm. After that, I'm stuck. Should I use a formula for concave mirrors? If yes, which one? I think that you need to place something in front of it to be able to calculate the angle. Glad if anyone could help :)
The telescope does not have mirrors in the same way optical telescopes use them. Wikimedia has a diagram of this.
I think this is simple geometry - the length and the radius are given, you can probably assume that the length of the mirrors is small compared to 10m. For X-rays that are parallel to the telescope axis, which deflection angle do you need per mirror?
I have actually no idea. From now, I only have the wavelength which I calculated, the eV range, the focal length and mirror radius. I'm stuck.. :/
Did you draw a sketch?
Can you solve it with a single mirror?
The wavelength is not relevant here, this is really just geometry.
It's hard to see the two reflections there (are there two?), but the basic idea is good.
Do you have any idea of the geometry, how to solve this problem maybe? :)
It's not rocket science...
Add angles to the sketch, find out which angles you know (and what you know about angles at mirrors), solve, done.
Yes, I just don't remember that much about this since it was 4 years ago that I calculated anything similar to this. Thanks!
  • · Replies 16 ·
