What is the net torque about the axle?
The net torque about the axle of a 19.6 cm diameter disk is calculated using the forces F1=22.8 N, F2=32.5 N, F3=32.5 N, and F4=22.8 N, with a distance d=4.60 cm. The calculations for torque yield T2=6.37 Nm, T3=-1.057 Nm, and T4=-1.0488 Nm, leading to a net torque (Tnet) of 4.26 Nm. The error identified in the discussion was the incorrect use of diameter instead of radius in torque calculations, which is critical for accurate results.
  • Understanding of torque calculations using the formula Torque = F r sin(angle)
  • Knowledge of basic physics concepts, including forces and rotational motion
  • Familiarity with the significance of counterclockwise and clockwise torque conventions
  • Ability to perform calculations involving trigonometric functions, specifically sine
  • Review the principles of rotational dynamics and torque calculations
  • Study the impact of using radius versus diameter in torque equations
  • Learn about the effects of different forces acting on a rotating object
  • Explore advanced torque problems involving multiple forces and angles
Students studying physics, particularly those focusing on mechanics and rotational motion, as well as educators looking for examples of torque calculations and common mistakes in problem-solving.
a.a
The 19.6 cm diameter disk rotates on an axle through its center. F1=22.8 N, F2=32.5 N, F3=32.5 N, F4=22.8 N, and d=4.60 cm. What is the net torque about the axle?
Torque = F r sin (angle)
F = m g
I found all the torques acting on the center, disregarded T1 because its sort of passing through the center and isn't really shown on the diagram.
T1 = 0
T2= (32.5)(0.196) = 6.37 Nm
T3= -(32.5)(sin 45)(0.046)= -1.057 Nm (counterclockwise)
T4= (22.8)(0.046)= -1.0488 (counterclockwise)
Tnet = 4.26 Nm
This isn't the right answer, can someone please help and explain where I am going wrong..
For a standard coordinate axis, counter-clockwise is usually taken as positive.
Re-check the calculation for T2 .
T2 looks fine to me (with the exception of the sign minus of course).
Shouldn't he multiply the force with the radius (as opposed to the diameter)?
Of course he should. And I should pay more attention :redface:
wow.. thanks.. that was a dumb mistake...
10K
20K
21K
34K
