What is the Optimal Ramp Angle for a Bus Jumping a Gap?
The discussion revolves around determining the optimal ramp angle for a bus to successfully jump a gap, based on projectile motion principles. The known parameters include the bus's velocity and the distance of the gap, with the landing surface being level with the takeoff point.
  • Participants discuss the use of the range formula for projectile motion and question the correctness of the original poster's equation. There is exploration of multiple angle solutions that yield the same range, and some participants express uncertainty about the expected angle values.
Participants are actively engaging with the problem, providing alternative approaches and confirming calculations. There is recognition of multiple valid angles for the ramp, and some guidance has been offered regarding the interpretation of the results.
There is mention of potential confusion due to the lack of provided equations in the homework context, and participants are navigating through assumptions about the expected ramp angle based on their reasoning.
patv
[SOLVED] Projectile Motion - Ramp Angle
Good evening everyone!
This is a classic ramp angle question. I am trying to find the angle of a ramp in order for a bus to complete the gap (Yes, this is from the film Speed, and I have searched, but haven't found a solution.)
Known:
Velocity = 31.29 m/s
Distance of gap = 15.24 m
The landing part of the road is level with the take off.
θ = (1/2) sin^-1 (fg x d / v2).
θ = (1/2) sin-1 (9.81 x 15.24 /31.292)
θ = (1/2) sin-1 (149.5044 / 979.0641)
θ = (1/2) sin-1 (0.1527)
θ = (1/2) (8.7834)
θ = 4.3917 degrees.
This answer does not quite seem right. I have gone through my calculations, but I cannot find an error. Perhaps my equation is wrong, I am not sure.
I am still puzzled by this.
Could someone help me determine whether or not I am using the correct equation?
I see that you are using the range formula. Make sure the distance is in meters. Also remember that sin(x) = sin(180 - x), so there are two solutions for the angle that yield the same range. One of the angles is 4.39 degrees while the other angle is 85.6 degrees.
Thank you. I converted the distance to meters. I doubt the angle of the ramp would have to be 85.6, so you would say 4.39 is correct?
I was expecting a number closer to around 25 degrees, but that was pure guessing.
The range equation is
[tex]R = \frac{v^2}{g}\sin{2\theta}[/tex]
rearranging
[tex]\sin{2\theta} = \frac{Rg}{v^2}[/tex]
There are two solutions for theta
[tex]\theta = \frac{1}{2} \sin^{-1}\frac{Rg}{v^2}[/tex]
or
[tex]\theta = \frac{1}{2}[180 - \sin^{-1}\frac{Rg}{v^2}][/tex]
Plugging in all the numbers, you get
[tex]\theta = 4.39^\circ[/tex]
or
[tex]\theta = 85.61^\circ[/tex]
Any value of theta between those two will make the jump (since at either of those values, the bus barely makes it)
rearranging
or
or
Thank you very much, sir.
This question had me second guessing myself because we were not given the equation, I had just found it somewhere online.
Cheers!
  • · Replies 29 ·
  • · Replies 26 ·
