What Is the Percent Yield of Al2O3 in This Reaction?
The discussion revolves around calculating the percent yield of Al2O3 from a reaction involving aluminum and oxygen. Participants are addressing the theoretical and actual yields, as well as the stoichiometry involved in the reaction.
  • Homework-related
  • One participant presents a balanced chemical equation for the reaction and attempts to calculate the percent yield using given masses of reactants and products.
  • Another participant emphasizes the importance of identifying the limiting reagent between aluminum and oxygen in the reaction.
  • Concerns are raised regarding the accuracy of conversion factors used in the calculations, specifically the molar mass of aluminum.
  • A clarification is made that the 108 g mentioned refers to the mass of 4 moles of aluminum, not 1 mole, and that the stoichiometric coefficients are correctly applied in the conversion factors.
Participants generally agree on the need to identify the limiting reagent and the correct application of stoichiometry, but there is disagreement regarding the accuracy of the conversion factors used in the calculations.
There are unresolved issues regarding the correct molar mass of aluminum and the implications of the limiting reagent on the percent yield calculation.
priscilla89
If the reaction of 2.5 g of Al with 2.5 g of O2 produced 3.5 g of Al2O3, what is the percent yield of Al2)3? Be sure to write and balance equation.
Percent Yield = (actual yield / theoretical yield ) x 100
4Al + 302 ---> 2Al2O3
2.5 g Al x (1 mol Al / 108 g) x (2 mol Al2O3 / 4 mol Al) = .0115 mol Al2O3
.0115 mol Al2O3 (204 g Al2O3 / 1 mol Al2O3) = 2.36 Al2O3
Percent Yield = (2.36 / 3.50) X 100 = 67 %
Two things:
1: Don't forget to verify which reagent (Al or O2) is the limiting reagent.
2: Your conversion factors are wrong. For instance - there aren't 108g of Al in 1 mol of Al.
108g is a mass of 4 moles of Al, not of 1 mole. 4 is a stoichiometric coefficient, and it is already - correctly - present in your
conversion coefficient.
methods
p21bass said:
Two things:
Okay, then it would be
2.5 g Al x (1 mol Al / 27 g) x (2 mol Al2O3 / 4 mol Al)
Much better now.
11K
17K
