What Is the Physical Meaning of Curvature in General Relativity?
  • Context: High School
  • Thread starter Thread starter Megaton
    Curvature Physical
The discussion revolves around the physical meaning of curvature in General Relativity (GR), exploring the nature of space and spacetime, and how curvature relates to gravity and the motion of test particles. Participants are attempting to clarify concepts related to intrinsic and extrinsic curvature, and the mathematical descriptions involved, such as the Riemann curvature tensor.
  • Some participants propose that space does not actually curve, suggesting that the physical meaning of curvature relates to test particles tracing their world lines in different contexts.
  • Others argue that spacetime does curve, which is described by the Riemann tensor, and that this curvature is essential to understanding gravity as per Einstein's theory.
  • A participant notes that the distinction between Euclidean and non-Euclidean spaces is significant, particularly in how geodesics behave differently in curved spacetime compared to flat spacetime.
  • Another point raised is the difference between intrinsic and extrinsic curvature, with intrinsic curvature being relevant to GR and how mass influences the geometry of spacetime.
  • One participant critiques the common analogy of a planet in a dent on a rubber sheet, stating it oversimplifies the concept by focusing only on spatial curvature and neglecting the importance of time-like curvature.
  • There is a discussion about the implications of curvature on the motion of objects, including how geodesic paths are affected by gravitational fields.
Participants express differing views on whether space or spacetime is what actually curves, with no consensus reached. The discussion contains multiple competing perspectives regarding the interpretation of curvature in GR.
Some limitations in the discussion include the potential confusion between intrinsic and extrinsic curvature, and the challenges in visualizing spacetime geometry accurately. The empirical meaning of certain statements about curvature remains unresolved.
Megaton
I'm new at this, trying to understand the overall picture of GR
From what I understand space does not actually curve but rather test particles tracing out their world lines in Euclidean space as compared to ones tracing out their world lines near a source of gravity is the physical meaning of curvature? And this is described mathematically using the Riemannian-curvature tensor?
Is this correct at all, I'm just trying to understand the overall idea of GR before trying to attempt the complex math
Thanks
From what I understand space does not actually curve...
Space(time!) does curve. It's what Einstein calls 'gravity'. The curvature of spacetime is described by the Riemann tensor. The Einstein equations put on a constraint on this Riemann tensor, describing the gravitational field (= spacetime geometry).
Thanks
I wouldn't say that "space does not actually curve". But when I think about the statement, I'm not sure how to disprove it. Which is an indication that it doesn't have a well defined empirical meaning, if it did, it'd be testable.
Test particles do trace out world lines in both Euclidean spaces and non-Euclidean spaces, but this doesn't distinguish one from the other.
What distinguishes the Euclidean space from the non-Euclidean one is that particles following geodesics in the flat Euclidean space-time don't change their relative separation, but particles following geodesics in a curved space-time do. This is called geodesic deviation.
Of course, you need to have some idea of what a geodesic is to make sense of this notion. For the purposes of understanding GR, it's sufficient to regard a geodesic as the shortest distance between two nearby points, though this is somewhat oversimplified, especially the "nearby" part. But it should give you some idea of what a geodesic is. Alternatively, you can define a geodesic more generally by the notion of parallel transport, but that may be more abstract and less familiar. And for GR it won't make much difference, but in some other theories, it matters.
It's also helpful to consider the meaning of curvature as applied to space and not space-time as a warm-up exercise. A plane is flat, the surface of a globe is curved. Parallel lines drawn on a plane never intersect and keep a constant distance. On a sphere, the equivalent of straight lines (great circles) must intersect, and in general parallel lines don't maintain a constant distance on a curved surface.
So yet another way of thinking about non-Euclidean geometry is to look at Euclid's parallel postulate.
Thanks
There are two types of "curvature" involved.
When GR people talk about "curvature", they usually mean intrinsic curvature which is caused by the presence of mass. Intrinsic curvature is like the fact that if you go round a closed path within the surface of a ball, the total angle you have turned through in the plane of the surface is not exactly 360 degrees. According to the Einstein Field Equations, this curvature is zero except at the location of some mass or equivalent energy. The resulting distortions mean that it is impossible to map local space-time in the vicinity of a mass directly to a conventional Euclidean coordinate system, in the same way that the surface of the Earth cannot be represented on a flat map without distorting scale factors, angles or both. In this sense, space-time really is curved.
They also explain free fall motion (geodesic motion) by a different sort of curvature, like the curvature of an orbit. This is the curvature of a geodesic path relative to a chosen practical coordinate system. An object which starts at rest has a path which starts off parallel to the time axis and then curves in the direction of the gravitational field. An object which moves sideways relative to a gravitational field also has its path curved by the curvature of space, so the rate of change of direction is proportional to the speed and the resulting acceleration is proportional to the square of the speed. The curvature with respect to time and space in conventional coordinates is approximately equal for weak fields, and is equivalent to the Newtonian expression ##g/c^2## where ##g## is the Newtonian gravitational field. The resulting acceleration for a particle moving at speed ##v## perpendicularly to the field is ##g (1 + v^2/c^2)##, which is why light is deflected twice as much by the sun as would be predicted from the Newtonian acceleration. This second form of curvature can be transformed away by looking at the situation from the point of view of the falling object, but if one is calculating orbits or similar that point of view is not very useful.
As haushofer has said, it is wrong (or, at least, critically incomplete) to say that space curves - spacetime curves. That's not pedantry, because the curvature in time-like directions is important to understanding why things at rest with respect to a gravitating body start moving.
I think you might be referring to the classic (and unhelpful) picture of a planet sitting in a dent on a plane. Partly this is unhelpful because it's showing spatial curvature only. But it is also mixing up intrinsic curvature (which is what GR cares about) and extrinsic curvature (which has no application in GR). What am I talking about?
That rubber sheet is a 2d surface embedded in a 3d Euclidean space. It can have intrinsic curvature, which means that the geometry of the surface is non-Euclidean. For example, straight parallel lines on the surface might cross if they pass near the dent (pervect's example of great circles on the surface of a 2-sphere is better). But the surface can also have extrinsic curvature, which is to say that lines in the surface are not straight lines in terms of the 3d space. For example, a straight line in 3d Euclidean space cannot lie in the surface of a 2-sphere.
Things with intrinsic curvature must have extrinsic curvature if they are embedded in a Euclidean space (I think...). But the reverse is not true. I can roll a piece of paper (the archetypal Euclidean plane) into a cylinder. The cylinder has extrinsic curvature in any direction except its axial direction, but the intrinsic curvature is still zero - triangle angles add to 180, ##c=2\pi r##, etc. The only oddity is that features are periodic in one direction, which is a topological oddity not a geometric one.
In GR we only care about intrinsic curvature because there's no evidence of anything outside the spacetime for spacetime to be embedded in, so nothing to measure extrinsic curvature with respect to. That's possibly what you mean by "not really curved". Spacetime is really curved in the intrinsic sense (and this is what the Riemann tensor describes, yes). It can be dangerous to visualise a slice through spacetime embedded in 3-space because one can visualise (e.g.) the cylinder and think that it's obviously curved when it isn't in the relativistic sense.
To check whether a spacetime is curved you do need to examine geodesics, or (better) compute curvature invariants, or otherwise do experiments that rely wholly on measurements made inside the spacetime you are considering.
It's probably worth noting something that Peter mentioned the other day - at least one candidate for a quantum gravity theory says that spacetime is flat, and that all the curvature effects are simply our interpretation of a spin-2 quantum field. So maybe spacetime doesn't "really" curve. But for the purposes of GR you can say that it does really curve, as long as you are careful about what you mean by "curve".
Is this correct? I thought that the vacuum solution permitted non-zero Weyl curvature. For example Wikipedia cites a non-zero Kretschmann scalar everywhere in a Schwarzschild spacetime.
https://en.m.wikipedia.org/wiki/Kretschmann_scalar
By the "curvature" in the context of the Einstein Field Equations I was of course referring to the (trace-reversed) Ricci tensor, not the full Riemann curvature. Close enough?
Where is that thread? Do you know which theory he was referring to?
Sorry for the pedantry, but I think if the OP is asking about curvature being "actual" or not, we need to be a bit careful.
OP: The Riemann tensor describes curvature. It can be split up and/or summarised in various meaningful ways. The Ricci tensor is one such summary, and it is, as Jonathan says, zero everywhere the stress-energy tensor is zero. But parts of the Riemann that are lost in that particular summary can be non-zero, and that can be reflected in other summaries of the Riemann, such as the Weyl tensor and Kretschmann scalar that I mentioned.
I'm well outside the bounds of a "B" thread here, so I'll just say that "curvature" unqualified can mean a lot of different things, some of which are relevant to GR, and some of which aren't, and some of which can be zero even when others aren't. Fun, isn't it?
Wow thanks for all your answers, boy GR is weird...weird but true
No, because the "Euclidean space" you are referring to does not exist, so there's no way to make the comparison you describe.
Physically, spacetime curvature is tidal gravity. So if you think about how you would observe tidal gravity, that is how you would observe spacetime curvature. (Pervect mentioned geodesic deviation, which is another way of saying tidal gravity.)
Not if we're considering timelike geodesics, which are the ones we need to consider if we're talking about geodesic deviation for test objects, i.e., tidal gravity. A timelike geodesic is the longest "distance" (proper time) between nearby points (events).
This doesn't change anything with regard to the topic of this thread, because the flat background spacetime in this theory is unobservable; the spacetime geometry we actually observe is the curved geometry that results from the effects of the spin-2 field.
Understood. What I was getting at was what you wrote at the bottom of this post (now my search seems to be working better). I took that to mean that curvature wasn't "real" in the quantum theory of gravity that you refer to in that post, but on a re-read just now I think you may have been making a slightly more general point (related to the first paragraph of pervect's #3 above), that curvature is arguably only an interpretation of the maths, albeit definitely the most popular and probably the most straightforward.
It's called massless Fierz-Pauli theory. See e.g. Hinterbilcher's notes on massive gravity, or Ortin's "gravity and strings".
A stringy analog I like is the idea of a laserbeam being a coherent state of photons. Similarly, in string theory (or the iteration of Fierz-Pauli) you get a coherent state of gravitons resulting in spacetime geometry at the classical scale. Geometry is as such an emergent effect, similar to LQG.
No.
Yes. "Spacetime curvature" is a way of describing tidal gravity, which is something we observe directly. But there's nothing that requires us to use that particular description. We use it because it works and because it has proven very fruitful.
This is great. Do you mean Riemannian geometry can be interpreted as other than curved, or are you referring to a quantum theory? Doesn't Riemann geometry forces us to accept that curvature is the only interpretation?
No. Riemannian geometry is a mathematical model. A mathematical model can never force you to adopt it as an interpretation of physical observations.
Yes, but isn't Riemannian geometry exclusively about curved spaces? Do you mean within its framework there are other possible ways to interpret the geometry in a way that doesn't involve curves?
No. But nothing forces you to use Riemannian geometry to interpret the physical observation of tidal gravity.
But if I were to use Riemannian geometry to describe tidal gravity, does it force me to use curves and nothing else?
If I understand correctly, if you attempt to draw a triangle near a massive body, you will find that the angles do not add to 180. The GR interpretation of that is that spacetime is curved and there's no such thing as a straight line in this context. The flat space plus quantum gravity field interpretation is that the gravity field always curves any attempt at a straight line. There is nothing gravitationally neutral that you can use to follow a straight line so you're stuck with curves - although straight lines do, in principle, exist.
Think of drawing a large "triangle" on a globe. Then represent it on a Mercator projection. The angles sum to the same (>180). The first drawing, a "triangle" made of great circles, is GR. The second, a "triangle" made of curved lines (curved because of interaction between the lines and the gravity field) is this quantum gravity interpretation. There's no experimental way to differentiate them within the domain of applicability of GR and the maths is the same.
Please bear in mind that this is no more than (my understanding of) pervect's post that I linked in #9, and I don't know any more than that. If this is a helpful analogy I'd wait for the nod from someone who actually knows what they're talking about before assuming it's right...
But not in the context of general relativity, correct?
Correct - there is no flat background there. My reading of what Peter and pervect said about the quantum theory on a flat background is that you can at least conceptualise straight lines on the flat background, but you could never verify whether or not you were following one.
As before, I'm simply paraphrasing what I've read on this thread and the post of pervect's that I linked, because I think your question was more "how can a field cause effects we can take to be geometry" than the interpretation issue I think Peter was adressing. Don't assume I'm right about any of it (except the GR has no straight lines - I'm sure about that bit).
More or less, yes.
I believe I have read you and others in this site remark that: a) curvature is an invariant therefore something observable and physical in that sense , b) the only difference between SR and GR is the presence of curvature spacetime in the latter. If I get you right you are now saying that curvature is part of a mathematical model that can never be forced to be taken as what is behind the observation of physical phenomenology related with gravitation and that one might just as well interpret the physics of gravity in a flat background with a force field.
It seems to me that this would blur any difference between SR and GR then if we take seriously assertion b), and also weaken any physical property we could attribute to invariance as per a).
The physical content one need to experimentally measure curvature is to be able to measure the infinitesimal distance (for solid geometry) or Lorentz interval (for space-time geometry) between two nearby points. This is a mathematical model, but it's physically motivated by the physical notions of distance, or Lorentz interval. Once one has this mathematical model that represents distance (or the Lorentz interval for space-time geometry) one can compute the curvature mathematically with no ambiguity.
Example. Thorne's exposition in "Curving", http://www.eftaylor.com/pub/chapter2.pdf "Distance Determines Geometry".
Nothing is more distressing on first contact with the idea of curved space-
time than the fear that every simple means of measurement has lost its
power in this unfamiliar context. One thinks of oneself as confronted with
the task of measuring the shape of a gigantic and fantastically sculptured
iceberg as one stands with a meterstick in a tossing rowboat on the surface
of a heaving ocean.
Were it the rowboat itself whose shape were to be measured, the proce-
dure would be simple enough (Figure 1). Draw it up on shore, turn it
upside down, and lightly drive in nails at strategic points here and there
on the surface. The measurement of distances from nail to nail would
record and reveal the shape of the surface. Using only the table of these
distances between each nail and other nearby nails, someone else can
reconstruct the shape of the rowboat. The precision of reproduction can be
made arbitrarily great by making the number of nails arbitrarily large.
The detailed steps that one takes are to first get the metric, a mathematical model that represents the physical measurements of the distance between nearby points, the nails in Taylor's rowbaot. For space-time geometry, one instead finds the Lorentz interval between two nearby points. By taking the limit of sufficiently close points, there is no need to know the curvature to measure the distance, the procedure is the same as it would be in flat space time.
Given the metric, one can perform mathematical manipulations on the metric to compute the Riemann curvature tensor. If any component of the tensor is non-zero, the surface (or more generally, the manifold) is curved.
Note that if the tensor is zero, it will be zero regardless of one's choice of coordinates, i.e. how one places the nails on Taylor's rowboat.
One does need to know how to measure distance, though, to compute the curvature. If one assumes a manifold structure without a metric, one cannot talk about whether or not the mainfold is curved. The metric is essential.
The mathematical manipulations to get the Riemann from the metric are non-trivial, but I think it'd be a digression to get into those details.
This seems simple to me, but since basically the same question keeps coming up with some posters (like Rocky), I assume they/he has some issue with it. What that issue might be, I really don't know.
Yes, if the word "curvature" is taken to mean "tidal gravity". Tidal gravity is what we actually observe.
Yes, if the word "curvature" is taken to mean "the Riemann tensor in differential geometry".
This is why you have to be very careful using ordinary language to talk about physics.
Yes, as long as you understand that the flat background is unobservable and that all physical predictions are exactly the same as if spacetime were curved and there were no force field. In other words, this is an interpretation: the two different ordinary language descriptions--curved spacetime vs. flat spacetime with a force field--are not two different possible ways the universe could be and we have to choose between them. They are just two different ways of describing the same physics--the same experimental results--in ordinary language.
No, because SR requires that there is no "force field" of the kind that gravity is in the "flat spacetime with a force field" interpretation. Flat spacetime, period, where the flatness is directly observable, is not the same thing, physically, as flat spacetime with a force field that makes the flatness unobservable. They are two different sets of physical properties and they result in two different sets of experimental results.
Ok, so in your revised view your former claim that SR only differs from GR only in that it is not set in curved spacetime must be further qualified if we use the alternative heuristic interpretation without curvature. And in the revised form one should say that the difference between SR and GR is that in the former flatness is directly observable while in GR flatness is not directly observable due to the presence of a gravity force field. Correct?
I'm afraid this would introduce more confusion than any improvement in terms of interpretational clarity it could bring.
First of all it is not clear at all in what sense you say that flatness can be directly observable(at least I haven't been able to directly observe flatness) while curvature is not directly observable.
The presence of the force fields that are usually present in SR don't seem to cause any problems for you to directly observe flatness, but the gravity force field that in the linearized form of GR that is referred to when using the force field heuristic for gravity isn't very different from the force fields of the rest of the interactions seems to make flatness unobservable(whatever that means).
Second I followed the link provided by Ibix to an earlier thread where you mentioned that this heuristic that equates interpretations based or not based on curvature can be traced to a Kip Thorne pop science book. I fear that your point of view is coming solely from this pop science book that only talks about physics using ordinary language with the loose care pop science books traditionally use, even if you ironically stressed for three times that:
  • · Replies 29 ·
  • · Replies 52 ·
  • · Replies 62 ·
  • · Replies 58 ·
  • · Replies 27 ·
  • · Replies 48 ·
