What is the significance of the Poynting vector for EM waves?
The Poynting vector, defined as \(\mathbf S = \mathbf E \times \mathbf H\), represents the electromagnetic energy current density in electromagnetic waves. Its derivation involves manipulating Maxwell's equations to show that it plays a role similar to current density in a continuity equation, indicating the flow of energy. This equation highlights the non-conservation of electromagnetic energy, as energy can appear or disappear in the system. Additionally, the Poynting vector is linked to the momentum of the electromagnetic field. Understanding the Poynting vector is crucial for interpreting energy transfer in electromagnetic waves.
Ahmad Kishki
i need an interpretation for the poynting vector, and its derivation for EM waves (sinusoidal)
Consider the two "curly" Maxwell's equations!(
Dot the first one with \mathbf H and the second one with \mathbf E and then subtract the second from the first. Using some vector calculus identities, You'll get the following:
<br /> \frac{\partial}{\partial t} \frac 1 2 (\mathbf E \cdot \mathbf D+\mathbf B \cdot \mathbf H) + \mathbf \nabla \cdot (\mathbf E \times \mathbf H)=-\mathbf E \cdot \mathbf J_f<br />
which is of the form \frac{\partial u}{\partial t}+\mathbf \nabla \cdot \mathbf K=G, i.e. is a continuity equation.
Where u is the density of "something", \mathbf K is the current density of that "something"(amount of "something" passing from a unit cross section in the unit of time) and G is the generation of "something" per volume.
For the present case, that something is energy and so the equation is describing the (non-)conservation of electromagnetic energy(which can appear or disappear since its only one of the energy forms present!).
As you can see, the quantity \mathbf S=\mathbf E \times \mathbf H(Poynting vector) is playing the role of \mathbf K and so is the electromagnetic energy current density.
Alternatively, the Poynting vector is associated with the momentum of the EM field.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 38 ·
  • · Replies 29 ·
  • · Replies 16 ·
