Seta
- 5
- 1
Summary:: I need to know the preheat temperature of the water entering the gas boiler (which i think is the outlet temperature of the cold water Tc,o leaving the heat exchanger)
Hi, I'm doing a design project of a hairpin heat exchanger. The problem is:
In a public shower, the city water is heated in a gas boiler from 15 °C to 43 °C at an average flow rate of 2 kg/s. In an attempt to save energy consumption, it is proposed to collect the lukewarm water drained at the temperature of 38 ° C and pass it through a heat exchanger to preheat the incoming cold water (which is at 15 °C). If the dimensions of the space in which the heat exchanger will be installed are 1m x 3m x 1m, design a hairpin-type heat exchanger which must properly perform this task.
From here, i have to do a schematic diagram of the water circuit with different devices (position of the HX, pumps, valves, boiler,...), and do the different calculations.
My problem is, i couldn't calculate the preheat temperature of the water leaving the HX.
I've done the schematic diagram, is this the right way to do it, and should i add or remove something from it ?
