What is the probability that the Universe is absolutely flat?
The discussion centers on the probability that the universe is absolutely flat, exploring theoretical implications, statistical interpretations, and the constraints provided by observational data. Participants examine the implications of various equations from cosmological studies, particularly in relation to the Hubble constant and matter density, and how these relate to the flatness of the universe.
  • Some participants question the interpretation of the "95%" confidence level in the context of the equations presented, with one suggesting it refers to both the mean value and the error range being accurate.
  • There is a proposal that the final statement regarding "a 1σ accuracy of 0.25%" implies specific probability statements about the matter density parameter, with one participant asserting that these statements are true.
  • One participant seeks scientifically reliable sources that support a statement about the probability of the universe being perfectly flat, suggesting that existing distributions do not adequately support such claims.
  • A thought experiment is presented, involving measurements of cosmic background radiation (CBR) temperatures, to explore the feasibility of deriving a reliable statement about the universe's flatness based on angular measurements.
  • Another participant introduces a new value for the Hubble constant and questions its implications for the curvature parameter, indicating a potential shift in understanding based on recent findings.
  • Discussion includes the distinction between Frequentist and Bayesian statistics, with emphasis on the latter's role in cosmology and the implications of prior assumptions on probability assessments.
Participants express differing views on the interpretation of statistical data and the implications for the universe's flatness. There is no consensus on the correct interpretation of the equations or the validity of the proposed thought experiment, indicating ongoing debate and exploration of the topic.
Participants acknowledge limitations in current measurement techniques and the assumptions underlying statistical models, which may affect the conclusions drawn about the universe's flatness.
  • #61
metastable said:
Is it necessary or only convenient to reference a 3-space?
I define an arc with n=arbitrarily high # turns. I make a straight line from point t=0 to point t=1. Next I bisect line t=0, t=1 creating a point A. The vector is created first by a line from point A, through the referenced spiral point B to point C, a point in space. Points in space are referenced as Vector: t=0.14563... Distance: 686,739,974.97969...km
PeterDonis said:
If we're talking about the universe, then yes, since spatial slices of the universe are 3-spaces.
I don't know what you're trying to get at with the arcs.
wolframalpha.com:
ParametricPlot3D [ { [//math:cos(2*pi*10^27*t)*sin(pi*t)//] , [//math:sin(2*pi*10^27*t)*sin(pi*t)//] , [//math:cos(pi*t)//] } , { t , [//number:0//] , [//number:1//] } ]
if on this scale 1 = Earth radius, loops = 10^27
unless I've made a mistake in my calculation we have:
~0.000020037... femtometers position specification accuracy & separation distance between loops at Earth radius
244376
Space news on Phys.org
  • #62
...so you are trying to use distance along your spiral to specify angular position and radius as in regular spherical polars? How do you specify a point that does not lie on a line through your spiral?
  • #63
^With a point A at the bisection of a straight line from point t=0 to t=1
  • #64
  • #65
George Jones said:
And thus to be consistent with known data, models of inflation must work in universes that have negative spatial curvature.
PeterDonis said:
However, that appears to be a moot point for inflation models, since the reference you give notes that they do in fact work with either positive or negative spatial curvature.
Hi George and Peter:
I apologize for my error. My bad. My previous careless exposure to discussions of inflation have involved explanatory pictures of finite shapes getting bigger. I failed to realize that the metaphor in the pictures intended the inclusion of both kinds of non-flat universes.
http://www.ctc.cam.ac.uk/outreach/origins/inflation_zero.php
Regards,
Buzz
  • #66
And the position of A along that line is your third number.
  • #67
Buzz Bloom said:
The above quote is the definition of ΩM.
Please see
in the section Density parameter.
I'm not sure how you come to this conclusion. This article states "The density parameter (useful for comparing different cosmological models) is then defined as:" ... and describes thereafter ##\Omega## as the ratio of the actual density to the critical density.
If ##\Omega## in the expression in brackets (post #60) were ##\Omega_m## then how could this expression be identical zero in case of exact flatness?
  • #68
Are you saying if I want to specify 3 chosen subsequent particle positions it would take me more than 6 numbers? (3 spiral points and 3 distances from point A)
  • #69
Yes. Because you cannot specify a position that does not lie on a line through your spiral.
  • #70
In a 3 space can I specify any irrational position?
  • #71
timmdeeg said:
k=0 requires Ω=1
timmdeeg said:
If Ω in the expression in brackets (post #60) were Ωm then how could this expression be identical zero in case of exact flatness?
Hi timmdeeg:
It is Ωk = k = 0 then
Ωm = 1, and the universe is flat.​
When Ωm > 1,
k=+1 and Ωk < 0.​
The universe is then finite and hyperspherical.​
When Ωm < 1,
k=-1 and Ωk > 0.​
The universe is then infinite and hyperbolic.​
Regards,
Buzz
  • #72
timmdeeg said:
No, ##\Omega## in ##(\Omega^{-1}-1)\rho{a}^2=-\frac{3c^2}{8\pi{G}}k## (post #13) is the ratio of the actual density to the critical density.
Please see
I agree with @timmdeeg
In this section, density is given by
$$\rho = \rho_r + \rho_m + \rho_\Lambda$$
and
$$\begin{align} \Omega &= \frac{\rho}{\rho_c} \nonumber \\
&= \frac{\rho_r + \rho_m + \rho_\Lambda}{\rho_c} \nonumber \\
&= \frac{\rho_r}{\rho_c} + \frac{\rho_m}{\rho_c} + \frac{\rho_\Lambda}{\rho_c} \nonumber \\
\Omega &= \Omega_r + \Omega_m + \Omega_\Lambda . \nonumber
\end{align}$$
  • #73
If you can specify the irrational number you mean, then sure. ##(x,y,z)=(\pi,e,\sqrt{2})##, for example.
  • #74
Can I write a complete list of the x,y,z positions an electron had as it traveled a meter, even in principle?
  • #75
ρ=ρrmΛ
and
Ω=ρrmΛc
rcmcΛc
Ω=ΩrmΛ.​
Hi George:
I edited the format of quote so that I could read it more clearly.
I confess I was not previously familiar with this usage of Ω, but I now see at the bottom of the Wiki section:
Ω0,k - 1-Ω0.​
So I yield, and I am now convinced I was previously mistaken. Thank you for pointing out my error.
Regards,
Buzz
  • #76
Hi @metastable:
I am puzzled by the figure with a spiral on a sphere in your post #35. Please explain in words what this is intended to represent.
Regards,
Buzz
  • #77
Buzz Bloom said:
Hi @metastable:
Regards,
Buzz
In rough terms: suppose you take a standard desk globe of the earth, and you attach a motorized gantry to the arch which supports it at the poles, and you spin the globe at a constant velocity, and you move the gantry from the north pole to the south pole at constant angular speed, with a pen attached to it, the pen will trace out this spiral on the globe depending on the relative speeds of the gantry and the globe.
  • #78
What does this have to do with the thread topic?
  • #79
I was asking if 3 spaces are necessary or only convenient, because I thought, via the illustration, I could specify an infinite subset points in space, not all along the same plane, with only 2 dimensions: 1) distance along spiral from pole and distance along straight line from point A through 1)
  • #80
Since the motion in your scenario is restricted to the surface of a 2-sphere, obviously it is only describing points in a space with 2 dimensions, since a 2-sphere is a 2-dimensional manifold. The fact that you are describing the 2-sphere using its embedding in 3-dimensional space does not change that.
  • #81
Is the spiral not 1 dimensional since no area no volume?
  • #82
##\vec r(t)=\int_0^t\vec v(t')dt'##
And a critical problem with your approach is that you cannot use calculus to describe motion across the grain of your spiral because you don't have a smooth map from space to your coordinate system. So you've gone a long way towards disabling the only tool you can use to describe things moving in rigorous mathematical terms. And you haven't achieved your goal of specifying points in 3-space using two numbers because it's impossible to do so.
  • #83
After specifying a position, I was toying with the idea in my head of describing its heading with a second spiral at the specified point and its instantaneous motion as a curve which would be represented by the circumference of a circle with a specified radius and orientation, but I am far from claiming any of this represents reality, but I mention it because you mentioned not being able to use calculus with the approach and I wondered if specifying instantaneous motions as such curves could work with calculus?
  • #84
Hi metastable:
I am wondering why you associate this concept with the topic of this thread?
Regards,
Buzz
  • #85
Then you have three numbers to specify positions in 3d space. Inevitably. I suspect there's more than one way to identify a location using this system, so this has nasty mathematical properties. But knock yourself out.
  • #86
Buzz Bloom said:
Hi metastable:
Regards,
Buzz
That's a good question. I'll stop contributing to this hijack now.
  • #87
Buzz Bloom said:
Hi metastable:
Regards,
Buzz
^I was trying to ascertain whether "3 spaces" are a "requirement" & "necessary" to describe the universe or merely "mathematically convenient."
  • #88
These "3 spaces" can be shown mathematically to be the only cosmological spaces that are both spatially isotropic and spatially homogeneous, but the mathematics (of Killing vectors) is appropriate for a thread that has an "A" label.
More spaces result if one/both of these conditions is/are relaxed.
  • #89
And I already answered that way back in post #36. Please do not discuss this question, or your questions about whether it takes 3 numbers to specify a point in 3-space (it does), any further in this thread.
  • #90
George Jones said:
And thus to be consistent with known data, models of inflation must work in universes that have negative spatial curvature. The Lyth and Liddle reference that I gave above explicitly notes that inflation smooths inhomogeneities in both ##\Omega > 1## and ##\Omega < 1## universes.
So regardless the global curvature locally the universe can have small areas like our observable universe which are positively or negatively curved depending on local inhomogeneities?
If this is correct so far would some kind of averaging over local curvatures in principle yield the global curvature? It would also mean that even exact knowledge about local curvature provides no clue to global curvature.
  • · Replies 20 ·
  • · Replies 52 ·
  • · Replies 57 ·
  • · Replies 29 ·
