What is the relationship between the length and height of a cable?
The discussion focuses on the challenges of adjusting the height of a zip cable at an outdoor facility, emphasizing the need for precision due to safety concerns. The user has determined that pulling one foot of cable affects the height by approximately 2.5 feet, but seeks a formula for more accurate adjustments. Suggestions include using a turnbuckle for easier tension adjustments, although the user expresses difficulty with the current anchoring system. The conversation highlights the importance of exact measurements and the complexities involved in cable tensioning. Overall, the need for a reliable method to achieve the desired height remains a priority.
nea_nemesis
Hi, everybody, I really hope you can help me out with this one.
I work for an outdoor facility, and we were just replacing our zip cable. Due to major safty issues, we need to get it at the exact height it used to be at, and that's kind of tough.
After a few trial-error sessions, we managed to get it within inches, but now it's down to details. I know that pulling about a foot (~30cm) on the end of the cable changes the height of it for about 2,5 feet (70-80cm). Since we're talking galvanized aircraft cable here, you understand why I want a formula before we fit it for two more inches in height...
The cable is about 200 yards (~200m) long I'd say. I can get exact (or close to exact) measurements, probably the weight of the cable, tension and such things, but I don't have them now.
Why don't you just use a turnbuckle?
What's a turnbuckle? (non-native English speaker over here...)
It's an in-line device commonly used to adjust the length and/or the tension in a cable:
http://en.wikipedia.org/wiki/Turnbuckle
The two screws on the ends of the turnbuckle have opposite threads, so that turning the center portion pulls them in or pushes them out.
Because the anchoring system is different (looped cable with a thimble locked in place with serving sleeves, clipped into a rapid link that's attached to an eye-bolt).
So the adjustable part is the piece of cable that goes through the thimble and back into a serving sleeve, and that's a hassle to loosen and tighten.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
