What is the resultant vector electric field at the point P?
The resultant electric field at point P, located at (b,a), is calculated using the superposition principle for three point charges, each denoted as q. The electric field due to a point charge is given by the formula E = q/(4πε₀r²). The correct approach involves calculating the individual electric fields from each charge and summing them vectorially, taking into account their directions. The final expression for the electric field at point P is E = q/(4πε₀(1/a² + 1/b² + 1/(a² + b²))), with the direction determined by the vector sum of the individual fields.
  • Understanding of Coulomb's Law and electric fields
  • Familiarity with vector addition and vector components
  • Knowledge of the superposition principle in electrostatics
  • Basic skills in calculus for handling vector magnitudes
  • Study vector addition in physics to enhance understanding of electric field direction
  • Learn about the superposition principle in electrostatics for multiple charges
  • Explore the concept of electric field lines and their representation
  • Investigate the effects of charge configuration on resultant electric fields
Students studying electromagnetism, physics educators, and anyone interested in understanding electric fields generated by multiple point charges.
Freya
There are 3 charges, each denoted q, the first at (0,a), the second at (0,0) and finally one at (b,0). What is the resultant electric field at point P, (b,a)?
E[/B]=q/(4πεo r2) for a point charge
So I know I need to use the superposition principle and sum the fields caused by the individual charges but I'm not sure whether I need to consider the fact that their fields won't necessarily be in the same direction.
My attempt gave me
E= q/(4πεo (1/a2 + 1/b2 + 1/(a2 + b2)) in the direction the same as sqrt(a2 + b2).
Thanks for any help, I've been debating this with friends.
Hello again,
You really need to make a drawing. ##\vec E## is a vector, as is ##\vec F = q\vec E##. Fields add up, so you can calculate the forces separately and then add them up. Vector-wise, as is the habit when dealing with forces !
Oh, and ##\sqrt{a^2+b^2}## has no direction! It's a number, a scalar.
Oh, and E ##\propto## 1/r2, not 1/ ( 1/r2 )
  • · Replies 68 ·
